Excel Macro
Excel Macro
CHAOS ::
Kako excel prepricam, da mi prekopira sledece:
For i = 1 To 501
Range("A[2*i-1]:C[2*i-1]").Select
Selection.Copy
Range("H[i]:J[i]").Select
ActiveSheet.Paste
Range("D[2*i]:F[2*i]").Select
Application.CutCopyMode = False
Selection.Copy
Range("H[2*i]:J[2*i]").Select
ActiveSheet.Paste
Next i
Se pravi, da imam 6 stolpcev od katerih zelim zadnje tri prekopirat v novo vrstico, tako da na koncu dobim podatke s samo tremi stolpci. Tnx vsem ze v naprej. :D
'They have computers, and they may have other weapons of mass destruction.'
Tutankhamun ::
Nimam lih excella ampak:
Pri vsakem Range bi jest tko naredu: primer za prvega
Range("A" & 2*i-1 & ":" & "C" & 2*i-1).Select
če pa to ne dela pa probi tko:
myRange = "A" & 2*i-1 & ":" & "C" & 2*i-1
Range(myRange).Select
In potem še za vse druge.
CHAOS ::
Tnx Tutan :D Sicer, kar sem napisal je bilo malo nesmiselno, vendar je glavna bila sintaksa. :) No, to je to kar sem hotel narediti. Mogoce bo se kdo kdaj rabil:
For i = 1 To 502
Range("A" & (i) & ":" & "C" & (i)).Select
Selection.Copy
Range("H" & (2 * i - 1) & ":" & "J" & (2 * i - 1)).Select
ActiveSheet.Paste
Range("D" & (i) & ":" & "F" & (i)).Select
Selection.Copy
Range("H" & (2 * i) & ":" & "J" & (2 * i)).Select
ActiveSheet.Paste
Next i
Word 2003 VBA problem
Oddelek: Programska oprema
101360 (1247) mimax
access -> word ali excel
51567 (1508) zavajon
[Excel] problem z makrojem, visual basic (strani: 1 2 )
Oddelek: Programiranje
586768 (6231) steev
Excel - klic podatkov iz druge datoteke
91871 (1710) pirat
Kako v excelu shraniti kot sliko?
263126 (2825) Slavček
