KDE emerge problem
KDE emerge problem
alexb ::
Sicer je ze podobna tema, a da je ne bom ukradel avtorju...
Ko dam emerge kde se zgodi tole:
pride do tretjega paketa..
>>> emerge (3 of 75) media-libs/jpeg-6b-r4 to /
>>> md5 src_uri ;-) jpegsrc.v6b.tar.gz
>>> Unpacking source...
>>> Unpacking jpegsrc.v6b.tar.gz to /var/tmp/portage/jpeg-6b-r4/work
* Applying uClibc/libtool patches ...
* Fixing ${S}/ltconfig... [ ok ]
* Applying jpeg-6b-gentoo.patch ... [ ok ]
>>> Source unpacked.
* econf: updating jpeg-6b/config.guess with /usr/share/gnuconfig/config.guess
* econf: updating jpeg-6b/config.sub with /usr/share/gnuconfig/config.sub
./configure --prefix=/usr --host=i686-pc-linux-gnu --mandir=/usr/share/man --infodir=/usr/share/info --datadir=/usr/share --sysconfdir=/etc --localstatedir=/var/lib --libdir=/usr/lib --enable-shared --enable-static
checking for gcc... gcc
checking whether the C compiler (gcc -O2 -march=pentium4 -pipe ) works... yes
checking whether the C compiler (gcc -O2 -march=pentium4 -pipe ) is a cross-compiler... no
checking whether we are using GNU C... yes
checking how to run the C preprocessor... gcc -E
checking for function prototypes... yes
checking for stddef.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for size_t... yes
checking for type unsigned char... yes
checking for type unsigned short... yes
checking for type void... yes
checking for working const... yes
checking for inline... __inline__
checking for broken incomplete types... ok
checking for short external names... ok
checking to see if char is signed... yes
checking to see if right shift is signed... yes
checking to see if fopen accepts b spec... yes
checking for a BSD compatible install... /bin/install -c
checking for ranlib... ranlib
checking host system type... i686-pc-linux-gnu
checking for gcc option to produce PIC... -fPIC
checking if gcc PIC flag -fPIC works... ./ltconfig: line 556: test: -fPIC: integer expression expected
yes
checking if gcc static flag -static works... -static
checking whether ln -s works... yes
checking for ld used by GCC... /usr/lib/gcc-lib/i686-pc-linux-gnu/3.3.5/../../../../i686-pc-linux-gnu/bin/ld
checking if the linker (/usr/lib/gcc-lib/i686-pc-linux-gnu/3.3.5/../../../../i686-pc-linux-gnu/bin/ld) is GNU ld... yes
checking whether the linker (/usr/lib/gcc-lib/i686-pc-linux-gnu/3.3.5/../../../../i686-pc-linux-gnu/bin/ld) supports shared libraries... yes
checking for BSD-compatible nm... /usr/bin/nm -B
checking command to parse /usr/bin/nm -B output... yes
checking how to hardcode library paths into programs... immediate
checking for /usr/lib/gcc-lib/i686-pc-linux-gnu/3.3.5/../../../../i686-pc-linux-gnu/bin/ld option to reload object files... -r
checking dynamic linker characteristics... Linux ld.so
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... yes
checking for objdir... .libs
creating libtool
checking libjpeg version number... 62
creating ./config.status
creating Makefile
creating jconfig.h
libtool --mode=compile i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jcapimin.c
libtool --mode=compile i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jcapistd.c
mkdir .libs
mkdir .libs
mkdir: cannot create directory `.libs': File exists
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jcapimin.c -fPIC -DPIC -o .libs/jcapimin.o
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jcapistd.c -fPIC -DPIC -o .libs/jcapistd.o
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jcapistd.c -o jcapistd.o >/dev/null 2>&1
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jcapimin.c -o jcapimin.o >/dev/null 2>&1
libtool --mode=compile i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jctrans.c
libtool --mode=compile i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jcparam.c
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jctrans.c -fPIC -DPIC -o .libs/jctrans.o
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jcparam.c -fPIC -DPIC -o .libs/jcparam.o
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jctrans.c -o jctrans.o >/dev/null 2>&1
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jcparam.c -o jcparam.o >/dev/null 2>&1
libtool --mode=compile i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jdatadst.c
libtool --mode=compile i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jcinit.c
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jdatadst.c -fPIC -DPIC -o .libs/jdatadst.o
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jdatadst.c -o jdatadst.o >/dev/null 2>&1
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jcinit.c -fPIC -DPIC -o .libs/jcinit.o
libtool --mode=compile i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jcmaster.c
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jcinit.c -o jcinit.o >/dev/null 2>&1
libtool --mode=compile i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jcmarker.c
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jcmaster.c -fPIC -DPIC -o .libs/jcmaster.o
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jcmarker.c -fPIC -DPIC -o .libs/jcmarker.o
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jcmaster.c -o jcmaster.o >/dev/null 2>&1
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jcmarker.c -o jcmarker.o >/dev/null 2>&1
libtool --mode=compile i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jcmainct.c
libtool --mode=compile i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jcprepct.c
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jcmainct.c -fPIC -DPIC -o .libs/jcmainct.o
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jcprepct.c -fPIC -DPIC -o .libs/jcprepct.o
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jcmainct.c -o jcmainct.o >/dev/null 2>&1
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jcprepct.c -o jcprepct.o >/dev/null 2>&1
libtool --mode=compile i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jccoefct.c
libtool --mode=compile i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jccolor.c
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jccoefct.c -fPIC -DPIC -o .libs/jccoefct.o
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jccolor.c -fPIC -DPIC -o .libs/jccolor.o
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jccoefct.c -o jccoefct.o >/dev/null 2>&1
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jccolor.c -o jccolor.o >/dev/null 2>&1
libtool --mode=compile i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jcsample.c
libtool --mode=compile i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jchuff.c
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jcsample.c -fPIC -DPIC -o .libs/jcsample.o
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jchuff.c -fPIC -DPIC -o .libs/jchuff.o
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jcsample.c -o jcsample.o >/dev/null 2>&1
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jchuff.c -o jchuff.o >/dev/null 2>&1
libtool --mode=compile i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jcphuff.c
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jcphuff.c -fPIC -DPIC -o .libs/jcphuff.o
libtool --mode=compile i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jcdctmgr.c
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jcdctmgr.c -fPIC -DPIC -o .libs/jcdctmgr.o
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jcphuff.c -o jcphuff.o >/dev/null 2>&1
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jcdctmgr.c -o jcdctmgr.o >/dev/null 2>&1
libtool --mode=compile i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jfdctfst.c
libtool --mode=compile i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jfdctflt.c
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jfdctfst.c -fPIC -DPIC -o .libs/jfdctfst.o
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jfdctflt.c -fPIC -DPIC -o .libs/jfdctflt.o
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jfdctfst.c -o jfdctfst.o >/dev/null 2>&1
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jfdctflt.c -o jfdctflt.o >/dev/null 2>&1
libtool --mode=compile i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jfdctint.c
libtool --mode=compile i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jdapimin.c
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jfdctint.c -fPIC -DPIC -o .libs/jfdctint.o
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jdapimin.c -fPIC -DPIC -o .libs/jdapimin.o
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jfdctint.c -o jfdctint.o >/dev/null 2>&1
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jdapimin.c -o jdapimin.o >/dev/null 2>&1
libtool --mode=compile i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jdapistd.c
libtool --mode=compile i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jdtrans.c
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jdapistd.c -fPIC -DPIC -o .libs/jdapistd.o
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jdtrans.c -fPIC -DPIC -o .libs/jdtrans.o
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jdapistd.c -o jdapistd.o >/dev/null 2>&1
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jdtrans.c -o jdtrans.o >/dev/null 2>&1
libtool --mode=compile i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jdatasrc.c
libtool --mode=compile i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jdmaster.c
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jdatasrc.c -fPIC -DPIC -o .libs/jdatasrc.o
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jdmaster.c -fPIC -DPIC -o .libs/jdmaster.o
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jdatasrc.c -o jdatasrc.o >/dev/null 2>&1
libtool --mode=compile i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jdinput.c
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jdmaster.c -o jdmaster.o >/dev/null 2>&1
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jdinput.c -fPIC -DPIC -o .libs/jdinput.o
libtool --mode=compile i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jdmarker.c
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jdinput.c -o jdinput.o >/dev/null 2>&1
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jdmarker.c -fPIC -DPIC -o .libs/jdmarker.o
libtool --mode=compile i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jdhuff.c
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jdhuff.c -fPIC -DPIC -o .libs/jdhuff.o
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jdhuff.c -o jdhuff.o >/dev/null 2>&1
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jdmarker.c -o jdmarker.o >/dev/null 2>&1
libtool --mode=compile i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jdphuff.c
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jdphuff.c -fPIC -DPIC -o .libs/jdphuff.o
libtool --mode=compile i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jdmainct.c
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jdphuff.c -o jdphuff.o >/dev/null 2>&1
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jdmainct.c -fPIC -DPIC -o .libs/jdmainct.o
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jdmainct.c -o jdmainct.o >/dev/null 2>&1
libtool --mode=compile i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jdcoefct.c
libtool --mode=compile i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jdpostct.c
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jdcoefct.c -fPIC -DPIC -o .libs/jdcoefct.o
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jdpostct.c -fPIC -DPIC -o .libs/jdpostct.o
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jdpostct.c -o jdpostct.o >/dev/null 2>&1
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jdcoefct.c -o jdcoefct.o >/dev/null 2>&1
libtool --mode=compile i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jddctmgr.c
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jddctmgr.c -fPIC -DPIC -o .libs/jddctmgr.o
libtool --mode=compile i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jidctfst.c
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jddctmgr.c -o jddctmgr.o >/dev/null 2>&1
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jidctfst.c -fPIC -DPIC -o .libs/jidctfst.o
libtool --mode=compile i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jidctflt.c
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jidctfst.c -o jidctfst.o >/dev/null 2>&1
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jidctflt.c -fPIC -DPIC -o .libs/jidctflt.o
libtool --mode=compile i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jidctint.c
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jidctflt.c -o jidctflt.o >/dev/null 2>&1
libtool --mode=compile i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jidctred.c
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jidctint.c -fPIC -DPIC -o .libs/jidctint.o
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jidctred.c -fPIC -DPIC -o .libs/jidctred.o
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jidctint.c -o jidctint.o >/dev/null 2>&1
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jidctred.c -o jidctred.o >/dev/null 2>&1
libtool --mode=compile i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jdsample.c
libtool --mode=compile i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jdcolor.c
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jdsample.c -fPIC -DPIC -o .libs/jdsample.o
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jdcolor.c -fPIC -DPIC -o .libs/jdcolor.o
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jdsample.c -o jdsample.o >/dev/null 2>&1
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jdcolor.c -o jdcolor.o >/dev/null 2>&1
libtool --mode=compile i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jquant1.c
libtool --mode=compile i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jquant2.c
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jquant1.c -fPIC -DPIC -o .libs/jquant1.o
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jquant2.c -fPIC -DPIC -o .libs/jquant2.o
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jquant1.c -o jquant1.o >/dev/null 2>&1
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jquant2.c -o jquant2.o >/dev/null 2>&1
libtool --mode=compile i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jdmerge.c
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jdmerge.c -fPIC -DPIC -o .libs/jdmerge.o
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jdmerge.c -o jdmerge.o >/dev/null 2>&1
libtool --mode=compile i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jcomapi.c
libtool --mode=compile i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jutils.c
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jcomapi.c -fPIC -DPIC -o .libs/jcomapi.o
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jcomapi.c -o jcomapi.o >/dev/null 2>&1
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jutils.c -fPIC -DPIC -o .libs/jutils.o
libtool --mode=compile i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jerror.c
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jutils.c -o jutils.o >/dev/null 2>&1
libtool --mode=compile i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jmemmgr.c
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jerror.c -fPIC -DPIC -o .libs/jerror.o
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jerror.c -o jerror.o >/dev/null 2>&1
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jmemmgr.c -fPIC -DPIC -o .libs/jmemmgr.o
libtool --mode=compile i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jmemnobs.c
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jmemnobs.c -fPIC -DPIC -o .libs/jmemnobs.o
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jmemmgr.c -o jmemmgr.o >/dev/null 2>&1
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jmemnobs.c -o jmemnobs.o >/dev/null 2>&1
libtool --mode=compile i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./cjpeg.c
libtool --mode=compile i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./rdppm.c
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./cjpeg.c -fPIC -DPIC -o .libs/cjpeg.o
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./rdppm.c -fPIC -DPIC -o .libs/rdppm.o
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./rdppm.c -o rdppm.o >/dev/null 2>&1
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./cjpeg.c -o cjpeg.o >/dev/null 2>&1
libtool --mode=compile i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./rdgif.c
libtool --mode=compile i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./rdtarga.c
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./rdgif.c -fPIC -DPIC -o .libs/rdgif.o
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./rdgif.c -o rdgif.o >/dev/null 2>&1
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./rdtarga.c -fPIC -DPIC -o .libs/rdtarga.o
libtool --mode=compile i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./rdrle.c
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./rdrle.c -fPIC -DPIC -o .libs/rdrle.o
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./rdtarga.c -o rdtarga.o >/dev/null 2>&1
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./rdrle.c -o rdrle.o >/dev/null 2>&1
libtool --mode=compile i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./rdbmp.c
libtool --mode=compile i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./rdswitch.c
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./rdbmp.c -fPIC -DPIC -o .libs/rdbmp.o
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./rdswitch.c -fPIC -DPIC -o .libs/rdswitch.o
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./rdbmp.c -o rdbmp.o >/dev/null 2>&1
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./rdswitch.c -o rdswitch.o >/dev/null 2>&1
libtool --mode=compile i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./cdjpeg.c
libtool --mode=compile i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./djpeg.c
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./cdjpeg.c -fPIC -DPIC -o .libs/cdjpeg.o
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./djpeg.c -fPIC -DPIC -o .libs/djpeg.o
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./cdjpeg.c -o cdjpeg.o >/dev/null 2>&1
libtool --mode=compile i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./wrppm.c
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./wrppm.c -fPIC -DPIC -o .libs/wrppm.o
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./wrppm.c -o wrppm.o >/dev/null 2>&1
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./djpeg.c -o djpeg.o >/dev/null 2>&1
libtool --mode=compile i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./wrgif.c
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./wrgif.c -fPIC -DPIC -o .libs/wrgif.o
libtool --mode=compile i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./wrtarga.c
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./wrgif.c -o wrgif.o >/dev/null 2>&1
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./wrtarga.c -fPIC -DPIC -o .libs/wrtarga.o
libtool --mode=compile i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./wrrle.c
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./wrtarga.c -o wrtarga.o >/dev/null 2>&1
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./wrrle.c -fPIC -DPIC -o .libs/wrrle.o
libtool --mode=compile i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./wrbmp.c
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./wrrle.c -o wrrle.o >/dev/null 2>&1
libtool --mode=compile i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./rdcolmap.c
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./wrbmp.c -fPIC -DPIC -o .libs/wrbmp.o
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./rdcolmap.c -fPIC -DPIC -o .libs/rdcolmap.o
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./wrbmp.c -o wrbmp.o >/dev/null 2>&1
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./rdcolmap.c -o rdcolmap.o >/dev/null 2>&1
libtool --mode=compile i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jpegtran.c
libtool --mode=compile i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./transupp.c
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jpegtran.c -fPIC -DPIC -o .libs/jpegtran.o
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./transupp.c -fPIC -DPIC -o .libs/transupp.o
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./jpegtran.c -o jpegtran.o >/dev/null 2>&1
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./transupp.c -o transupp.o >/dev/null 2>&1
libtool --mode=compile i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./rdjpgcom.c
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./rdjpgcom.c -fPIC -DPIC -o .libs/rdjpgcom.o
libtool --mode=compile i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./wrjpgcom.c
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./rdjpgcom.c -o rdjpgcom.o >/dev/null 2>&1
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./wrjpgcom.c -fPIC -DPIC -o .libs/wrjpgcom.o
libtool --mode=link i686-pc-linux-gnu-gcc -o libjpeg.la jcapimin.lo jcapistd.lo jctrans.lo jcparam.lo jdatadst.lo jcinit.lo jcmaster.lo jcmarker.lo jcmainct.lo jcprepct.lo jccoefct.lo jccolor.lo jcsample.lo jchuff.lo jcphuff.lo jcdctmgr.lo jfdctfst.lo jfdctflt.lo jfdctint.lo jdapimin.lo jdapistd.lo jdtrans.lo jdatasrc.lo jdmaster.lo jdinput.lo jdmarker.lo jdhuff.lo jdphuff.lo jdmainct.lo jdcoefct.lo jdpostct.lo jddctmgr.lo jidctfst.lo jidctflt.lo jidctint.lo jidctred.lo jdsample.lo jdcolor.lo jquant1.lo jquant2.lo jdmerge.lo jcomapi.lo jutils.lo jerror.lo jmemmgr.lo jmemnobs.lo \
-rpath /usr/lib -version-info 62
i686-pc-linux-gnu-gcc -O2 -march=pentium4 -pipe -I. -c ./wrjpgcom.c -o wrjpgcom.o >/dev/null 2>&1
libtool --mode=link i686-pc-linux-gnu-gcc -o rdjpgcom rdjpgcom.lo
i686-pc-linux-gnu-gcc -o rdjpgcom .libs/rdjpgcom.o
libtool --mode=link i686-pc-linux-gnu-gcc -o wrjpgcom wrjpgcom.lo
g++ -shared -nostdlib /usr/lib/gcc-lib/i686-pc-linux-gnu/3.3.4/../../../crti.o /usr/lib/gcc-lib/i686-pc-linux-gnu/3.3.4/crtbeginS.o .libs/jcapimin.o .libs/jcapistd.o .libs/jctrans.o .libs/jcparam.o .libs/jdatadst.o .libs/jcinit.o .libs/jcmaster.o .libs/jcmarker.o .libs/jcmainct.o .libs/jcprepct.o .libs/jccoefct.o .libs/jccolor.o .libs/jcsample.o .libs/jchuff.o .libs/jcphuff.o .libs/jcdctmgr.o .libs/jfdctfst.o .libs/jfdctflt.o .libs/jfdctint.o .libs/jdapimin.o .libs/jdapistd.o .libs/jdtrans.o .libs/jdatasrc.o .libs/jdmaster.o .libs/jdinput.o .libs/jdmarker.o .libs/jdhuff.o .libs/jdphuff.o .libs/jdmainct.o .libs/jdcoefct.o .libs/jdpostct.o .libs/jddctmgr.o .libs/jidctfst.o .libs/jidctflt.o .libs/jidctint.o .libs/jidctred.o .libs/jdsample.o .libs/jdcolor.o .libs/jquant1.o .libs/jquant2.o .libs/jdmerge.o .libs/jcomapi.o .libs/jutils.o .libs/jerror.o .libs/jmemmgr.o .libs/jmemnobs.o -L/usr/lib/gcc-lib/i686-pc-linux-gnu/3.3.4 -L/usr/lib/gcc-lib/i686-pc-linux-gnu/3.3.4/../../.. -lstdc++ -lm -lc -lgcc_s /usr/lib/gcc-lib/i686-pc-linux-gnu/3.3.4/crtendS.o /usr/lib/gcc-lib/i686-pc-linux-gnu/3.3.4/../../../crtn.o -Wl,-soname -Wl,libjpeg.so.62 -o .libs/libjpeg.so.62.0.0
g++: /usr/lib/gcc-lib/i686-pc-linux-gnu/3.3.4/../../../crti.o: No such file or directory
g++: /usr/lib/gcc-lib/i686-pc-linux-gnu/3.3.4/crtbeginS.o: No such file or directory
g++: /usr/lib/gcc-lib/i686-pc-linux-gnu/3.3.4/crtendS.o: No such file or directory
g++: /usr/lib/gcc-lib/i686-pc-linux-gnu/3.3.4/../../../crtn.o: No such file or directory
make: *** [libjpeg.la] Error 1
make: *** Waiting for unfinished jobs....
i686-pc-linux-gnu-gcc -o wrjpgcom .libs/wrjpgcom.o
!!! ERROR: media-libs/jpeg-6b-r4 failed.
!!! Function src_compile, Line 43, Exitcode 2
!!! make failed
!!! If you need support, post the topmost build error, NOT this status message.
No potem sem ugotovil, da do istega problema pride tudi pri emerg links. Hoce potegniti dol tale
media-libs/jpeg-6b-r4 in popolnoma enak error.
CFLAGS="-O2 -march=pentium4 -pipe"
CHOST="i686-pc-linux-gnu"
CXXFLAGS="${CFLAGS}"
MAKEOPTS="-j2"
USE="-gtk -gnome qt kde dvd alsa cdr"
Ostalo vse na defaultu.
alexb ::
Problem je ocitno bil, ker sem po namestitvi pognal upgrade sistema in dobil novejsi gcc..
Na gentoo forumu sem potem nasel post, ki je odpravil problem in ga prilagam spodaj, ce bo komu pomagalo.
it is wise (but very time consuming, and by some users not needed and/or extreme) to recompile your toolchain (and packages) whenever there's a (big) gcc update.
this way, you will have a rock solid OS (and minimize compile failures you experienced).
I think you installed your gentoo with gcc 3.3.4, and then updated your gcc to 3.3.5. Now you have mixed packages on your system (ones compiled with 3.3.4 and newer with 3.3.5).
In order to have your toolchain and system in order do:
[optional] i think this is in your example not needed (but this is what I do when theres a gcc version update)
Code:
emerge gcc-config glibc binutils gcc
[/optional]
Check your gcc
Code:
gcc-config -l
be sure to have this:
Code:
[1] i686-pc-linux-gnu-3.3.5 *
[2] i686-pc-linux-gnu-3.3.5-hardened
[3] i686-pc-linux-gnu-3.3.5-hardenednopie
[4] i686-pc-linux-gnu-3.3.5-hardenednossp
if gcc 3.3.4 is still selected do
Code:
gcc-config (number)
to select appropriate gcc (gcc 3.3.5)
Then
Code:
emerge glibc binutils gcc
This will compile your toolchain again with gcc 3.3.5
After that
Code:
emerge -e system
to compile all your system packages with gcc 3.3.5, or
Code:
emerge -e world
to compile everything with gcc 3.3.5
As i said this is time consuming, but it really is the best way to keep your system in good shape and consistent.
There is more on this on this forum.
moj_nick ::
emerge -e world delati je bedarija. Če se kaj noče kompajlati, pač ponovno emerge-aš tiste dependency-je, ki povzročajo probleme.
110111001001010001010000
mysql 5.0.16 gentoo
Oddelek: Operacijski sistemi
101649 (1567) yimi
K3B problem
71692 (1570) theD3viL-
gentoo stage 1 install
101617 (1503) zee
unmergal sem gcc
422342 (2088) borchi
Gentoo Linux & nov KDE problem!
101673 (1613) Tarzan
