Scribus na Slackware Linuxu
klevic ::
Lep pozdrav
Imam Linux Slackware 10.0 in problem z instalacijo Scribusa 1.1.2 .
Ko pozenem configure datoteko dobim:
FreeType2 installed: Yes
CUPS installed: Yes
LittleCMS installed: Yes
TiffLib installed: Yes
Ko pozenem make dobim:
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1330: error: syntax
error before `->' token
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1331: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1332: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1333: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1334: error: ISO C++
forbids declaration of `T6_Preview' with no type
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1334: error: `int
Preferences::T6_Preview' is not a static member of `class Preferences'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1334: error: invalid use
of member `Preferences::ToolFrame6'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1335: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1336: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1337: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1338: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1339: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1340: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1341: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1342: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1343: error: `
QSpacerItem*Preferences::T6_spacer3' is not a static member of `class
Preferences'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1344: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1345: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1346: error: `
QSpacerItem*Preferences::T6_spacer2' is not a static member of `class
Preferences'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1347: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1348: error: ISO C++
forbids declaration of `UpdatePreView' with no type
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1349: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1351: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1353: error: ISO C++
forbids declaration of `tab_5' with no type
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1353: error: `int
Preferences::tab_5' is not a static member of `class Preferences'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1353: error: invalid use
of member `Preferences::TabWidget3'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1354: error: ISO C++
forbids declaration of `tabLayout_5' with no type
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1354: error: `int
Preferences::tabLayout_5' is not a static member of `class Preferences'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1354: error: invalid use
of member `Preferences::tab_5'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1355: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1356: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1358: error: ISO C++
forbids declaration of `Saving' with no type
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1358: error: `int
Preferences::Saving' is not a static member of `class Preferences'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1358: error: invalid use
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1359: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1360: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1361: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1362: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1363: error: ISO C++
forbids declaration of `SavingLayout' with no type
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1363: error: `int
Preferences::SavingLayout' is not a static member of `class Preferences'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1363: error: invalid use
of member `Preferences::Saving'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1364: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1365: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1366: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1368: error: ISO C++
forbids declaration of `SaveAtQuit' with no type
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1368: error: `int
Preferences::SaveAtQuit' is not a static member of `class Preferences'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1368: error: invalid use
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1369: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1370: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1371: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1373: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1375: error: ISO C++
forbids declaration of `Preview' with no type
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1375: error: `int
Preferences::Preview' is not a static member of `class Preferences'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1375: error: invalid use
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1376: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1377: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1378: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1379: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1380: error: ISO C++
forbids declaration of `PreviewLayout' with no type
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1380: error: `int
Preferences::PreviewLayout' is not a static member of `class Preferences'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1380: error: invalid use
of member `Preferences::Preview'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1381: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1382: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1383: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1385: error: ISO C++
forbids declaration of `TextLabelP' with no type
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1385: error: `int
Preferences::TextLabelP' is not a static member of `class Preferences'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1385: error: invalid use
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1386: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1387: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1389: error: ISO C++
forbids declaration of `PreviewSize' with no type
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1389: error: `int
Preferences::PreviewSize' is not a static member of `class Preferences'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1389: error: invalid use
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1390: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1391: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1392: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1393: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1406: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1408: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1410: error: ISO C++
forbids declaration of `Frame6' with no type
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1410: error: `int
Preferences::Frame6' is not a static member of `class Preferences'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1410: error: invalid use
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1411: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1412: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1413: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1415: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1416: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1418: error: ISO C++
forbids declaration of `tab_6' with no type
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1418: error: `int
Preferences::tab_6' is not a static member of `class Preferences'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1418: error: invalid use
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1419: error: ISO C++
forbids declaration of `tabLayout_6' with no type
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1419: error: `int
Preferences::tabLayout_6' is not a static member of `class Preferences'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1419: error: invalid use
of member `Preferences::tab_6'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1420: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1421: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1422: error: ISO C++
forbids declaration of `GroupBox10' with no type
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1422: error: `int
Preferences::GroupBox10' is not a static member of `class Preferences'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1422: error: invalid use
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1423: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1424: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1425: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1426: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1427: error: ISO C++
forbids declaration of `GroupBox10Layout' with no type
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1427: error: `int
Preferences::GroupBox10Layout' is not a static member of `class Preferences'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1427: error: invalid use
of member `Preferences::GroupBox10'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1428: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1429: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1430: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1431: error: ISO C++
forbids declaration of `FramesVisible' with no type
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1431: error: `int
Preferences::FramesVisible' is not a static member of `class Preferences'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1431: error: invalid use
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1432: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1437: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1438: error: ISO C++
forbids declaration of `SidebySide' with no type
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1438: error: `int
Preferences::SidebySide' is not a static member of `class Preferences'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1438: error: invalid use
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1439: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1444: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1446: error: ISO C++
forbids declaration of `Layout_6b' with no type
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1446: error: `int
Preferences::Layout_6b' is not a static member of `class Preferences'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1446: error: invalid
conversion from `QHBoxLayout*' to `int'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1447: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1448: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1449: error: ISO C++
forbids declaration of `GroupBox20a' with no type
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1449: error: `int
Preferences::GroupBox20a' is not a static member of `class Preferences'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1449: error: invalid use
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1450: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1451: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1452: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1453: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1454: error: ISO C++
forbids declaration of `GroupBox20aLayout' with no type
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1454: error: `int
Preferences::GroupBox20aLayout' is not a static member of `class Preferences
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1454: error: invalid use
of member `Preferences::GroupBox20a'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1455: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1456: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1457: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1458: error: ISO C++
forbids declaration of `TextLabel4a' with no type
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1458: error: `int
Preferences::TextLabel4a' is not a static member of `class Preferences'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1458: error: invalid use
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1459: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1460: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1461: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1462: error: ISO C++
forbids declaration of `PapColor' with no type
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1462: error: `int
Preferences::PapColor' is not a static member of `class Preferences'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1462: error: invalid use
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1463: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1464: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1465: error: `QPixmap
Preferences::pm1a' is not a static member of `class Preferences'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1466: error: parse error
before `if'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1469: error: ISO C++
forbids declaration of `Cpaper' with no type
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1469: error: `int
Preferences::Cpaper' is not a static member of `class Preferences'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1469: error: `ap' was
not declared in this scope
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1470: error: parse error
before `}' token
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1474: error: ISO C++
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1474: error: `int
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1475: error: parse error
before `}' token
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1476: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1477: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1478: error: ISO C++
forbids declaration of `TextLabel4b' with no type
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1478: error: `int
Preferences::TextLabel4b' is not a static member of `class Preferences'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1478: error: invalid use
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1479: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1480: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1481: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1482: error: ISO C++
forbids declaration of `RandColor' with no type
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1482: error: `int
Preferences::RandColor' is not a static member of `class Preferences'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1482: error: invalid use
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1483: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1484: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1488: error: ISO C++
forbids declaration of `Crand' with no type
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1488: error: `int
Preferences::Crand' is not a static member of `class Preferences'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1488: error: `ap' was
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1489: error: parse error
before `}' token
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1493: error: ISO C++
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1493: error: `int
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1494: error: parse error
before `}' token
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1495: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1496: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1497: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1498: error: `
QSpacerItem*Preferences::spacer2' is not a static member of `class
Preferences'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1499: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1500: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1501: error: ISO C++
forbids declaration of `RandFarb' with no type
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1501: error: `int
Preferences::RandFarb' is not a static member of `class Preferences'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1501: error: invalid use
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1502: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1507: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1508: error: ISO C++
forbids declaration of `UsePDFTrans' with no type
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1508: error: `int
Preferences::UsePDFTrans' is not a static member of `class Preferences'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1508: error: invalid use
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1509: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1510: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1511: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1513: error: ISO C++
forbids declaration of `CaliGroup' with no type
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1513: error: `int
Preferences::CaliGroup' is not a static member of `class Preferences'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1513: error: invalid use
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1514: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1515: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1516: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1517: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1518: error: ISO C++
forbids declaration of `CaliGroupLayout' with no type
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1518: error: `int
Preferences::CaliGroupLayout' is not a static member of `class Preferences'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1518: error: invalid use
of member `Preferences::CaliGroup'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1519: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1520: error: ISO C++
forbids declaration of `CaliText' with no type
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1520: error: `int
Preferences::CaliText' is not a static member of `class Preferences'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1520: error: invalid use
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1521: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1522: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1523: error: ISO C++
forbids declaration of `CaliRuler' with no type
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1523: error: `int
Preferences::CaliRuler' is not a static member of `class Preferences'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1523: error: invalid use
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1524: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1525: error: ISO C++
forbids declaration of `DrawRuler' with no type
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1526: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1527: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1528: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1529: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1530: error: ISO C++
forbids declaration of `layout15ca' with no type
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1530: error: `int
Preferences::layout15ca' is not a static member of `class Preferences'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1530: error: invalid
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1531: error: ISO C++
forbids declaration of `CaliSlider' with no type
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1531: error: `int
Preferences::CaliSlider' is not a static member of `class Preferences'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1531: error: invalid use
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1532: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1533: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1534: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1535: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1536: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1537: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1538: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1539: error: ISO C++
forbids declaration of `CaliAnz' with no type
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1539: error: `int
Preferences::CaliAnz' is not a static member of `class Preferences'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1539: error: invalid use
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1540: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1541: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1542: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1544: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1546: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1547: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1548: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1550: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1551: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1553: error: ISO C++
forbids declaration of `Layout3' with no type
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1553: error: `int
Preferences::Layout3' is not a static member of `class Preferences'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1553: error: invalid
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1554: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1555: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1556: error: `
QSpacerItem*Preferences::spacer' is not a static member of `class
Preferences'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1557: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1558: error: ISO C++
forbids declaration of `buttonOK' with no type
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1558: error: `int
Preferences::buttonOK' is not a static member of `class Preferences'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1558: error: invalid use
of `this' at top level
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1559: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1560: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1561: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1562: error: `
QSpacerItem*Preferences::spacer_2' is not a static member of `class
Preferences'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1563: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1564: error: ISO C++
forbids declaration of `buttonCancel' with no type
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1564: error: `int
Preferences::buttonCancel' is not a static member of `class Preferences'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1564: error: invalid use
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1565: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1566: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1567: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1568: error: `
QSpacerItem*Preferences::spacer_3' is not a static member of `class
Preferences'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1569: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1570: error: syntax
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1573: error: invalid use
of member `Preferences::minColor'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1573: error: ISO C++
forbids declaration of `connect' with no type
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1573: error: `int
Preferences::connect' is not a static member of `class Preferences'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1573: error: initializer
list being treated as compound expression
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1574: error: invalid use
of member `Preferences::MaxColor'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1574: error: ISO C++
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1574: error: `int
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1574: error: initializer
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1575: error: invalid use
of member `Preferences::PapColor'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1575: error: ISO C++
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1575: error: `int
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1575: error: initializer
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1576: error: invalid use
of member `Preferences::RandColor'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1576: error: ISO C++
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1576: error: `int
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1576: error: initializer
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1577: error: invalid use
of member `Preferences::GuideColor'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1577: error: ISO C++
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1577: error: `int
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1577: error: initializer
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1578: error: invalid use
of member `Preferences::buttonOK'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1578: error: ISO C++
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1578: error: `int
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1578: error: initializer
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1579: error: invalid use
of member `Preferences::buttonCancel'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1579: error: ISO C++
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1579: error: `int
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1579: error: initializer
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1580: error: `FontComb'
was not declared in this scope
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1580: error: invalid use
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1580: error: ISO C++
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1580: error: `int
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1580: error: initializer
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1581: error: invalid use
of member `Preferences::SizeCombo'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1581: error: ISO C++
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1581: error: `int
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1581: error: initializer
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1582: error: invalid use
of member `Preferences::TextButton'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1582: error: ISO C++
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1582: error: `int
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1582: error: initializer
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1583: error: invalid use
of member `Preferences::RectButton'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1583: error: ISO C++
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1583: error: `int
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1583: error: initializer
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1584: error: invalid use
of member `Preferences::OvalButton'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1584: error: ISO C++
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1584: error: `int
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1584: error: initializer
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1585: error: invalid use
of member `Preferences::LineButton'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1585: error: ISO C++
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1585: error: `int
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1585: error: initializer
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1586: error: invalid use
of member `Preferences::ZoomButton'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1586: error: ISO C++
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1586: error: `int
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1586: error: initializer
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1587: error: invalid use
of member `Preferences::BildButton'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1587: error: ISO C++
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1587: error: `int
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1587: error: initializer
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1588: error: invalid use
of member `Preferences::PolyButton'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1588: error: ISO C++
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1588: error: `int
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1588: error: initializer
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1589: error: `Kette' was
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1589: error: invalid use
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1589: error: ISO C++
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1589: error: `int
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1589: error: initializer
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1590: error: invalid use
of member `Preferences::XScale'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1590: error: ISO C++
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1590: error: `int
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1590: error: initializer
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1591: error: invalid use
of member `Preferences::YScale'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1591: error: ISO C++
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1591: error: `int
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1591: error: initializer
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1592: error: invalid use
of member `Preferences::UnitCombo'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1592: error: ISO C++
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1592: error: `int
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1592: error: initializer
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1593: error: invalid use
of member `Preferences::Shorty'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1593: error: ISO C++
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1593: error: `int
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1593: error: initializer
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1594: error: invalid use
of member `Preferences::T6_Faktor'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1594: error: ISO C++
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1594: error: `int
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1594: error: initializer
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1595: error: invalid use
of member `Preferences::T6_Slider1'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1595: error: ISO C++
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1595: error: `int
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1595: error: initializer
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1596: error: invalid use
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1596: error: ISO C++
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1596: error: `int
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1596: error: initializer
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1597: error: invalid use
of member `Preferences::T6_Faktor2'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1597: error: ISO C++
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1597: error: `int
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1597: error: initializer
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1598: error: invalid use
of member `Preferences::T6_Slider2'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1598: error: ISO C++
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1598: error: `int
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1598: error: initializer
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1599: error: invalid use
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1599: error: ISO C++
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1599: error: `int
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1599: error: initializer
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1600: error: invalid use
of member `Preferences::T6_Ecken'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1600: error: ISO C++
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1600: error: `int
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1600: error: initializer
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1601: error: invalid use
of member `Preferences::T6_Konvex'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1601: error: ISO C++
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1601: error: `int
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1601: error: initializer
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1602: error: `Breite'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1602: error: invalid use
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1602: error: ISO C++
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1602: error: `int
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1602: error: initializer
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1603: error: `Hoehe' was
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1603: error: invalid use
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1603: error: ISO C++
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1603: error: `int
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1603: error: initializer
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1604: error: `TopR' was
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1604: error: invalid use
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1604: error: ISO C++
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1604: error: `int
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1604: error: initializer
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1605: error: `BottomR'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1605: error: invalid use
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1605: error: ISO C++
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1605: error: `int
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1605: error: initializer
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1606: error: `LeftR' was
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1606: error: invalid use
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1606: error: ISO C++
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1606: error: `int
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1606: error: initializer
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1607: error: `RightR'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1607: error: invalid use
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1607: error: ISO C++
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1607: error: `int
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1607: error: initializer
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1608: error: invalid use
of member `Preferences::GZComboO'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1608: error: ISO C++
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1608: error: `int
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1608: error: initializer
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1609: error: invalid use
of member `Preferences::GZComboF'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1609: error: ISO C++
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1609: error: `int
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1609: error: initializer
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1610: error: invalid use
of member `Preferences::Doppelseiten'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1610: error: ISO C++
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1610: error: `int
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1610: error: initializer
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1611: error: invalid use
of member `Preferences::FreeScale'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1611: error: ISO C++
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1611: error: `int
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1611: error: initializer
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1612: error: invalid use
of member `Preferences::FrameScale'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1612: error: ISO C++
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1612: error: `int
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1612: error: initializer
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1613: error: invalid use
of member `Preferences::FileC'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1613: error: ISO C++
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1613: error: `int
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1613: error: initializer
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1614: error: invalid use
of member `Preferences::CaliSlider'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1614: error: ISO C++
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1614: error: `int
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1614: error: initializer
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1615: error: invalid use
of member `Preferences::TabListe'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1615: error: ISO C++
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1615: error: `int
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1615: error: initializer
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1616: error: ISO C++
forbids declaration of `setSize' with no type
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1616: error: `int
Preferences::setSize' is not a static member of `class Preferences'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1617: error: ISO C++
forbids declaration of `setOrien' with no type
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1617: error: `int
Preferences::setOrien' is not a static member of `class Preferences'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1618: error: ISO C++
forbids declaration of `UnitChange' with no type
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1619: error: parse error
before `}' token
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp: In member function `
void Preferences::ChangeScaling()':
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1644: error: `Kette'
undeclared (first use this function)
void Preferences::setBreite(int)':
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1678: error: `RightR'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1678: error: `Breite'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1678: error: `LeftR'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1680: error: `TopR'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1680: error: `Hoehe'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1680: error: `BottomR'
void Preferences::DefKB()':
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1889: error: `KeyManager
' undeclared (first use this function)
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1889: error: `dia'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1889: error: parse error
before `(' token
void Preferences::SetSample()':
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1898: error: `fon'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:1898: error: `FontComb'
void Preferences::UnitChange()':
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:2012: error: `SpinBox1'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:2013: error: `SpinBox2'
/root/scribus/scribus-1.0.1/scribus/libprefs/prefs.cpp:2014: error: `SpinBox2g'
make[3]: *** [prefs.lo] Error 1
make[3]: Leaving directory `/root/scribus/libprefs'
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory `/root/scribus'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/root'
make: *** [all] Error 2
Ko pozenem make install dobim:
before `}' token
before `(' token
make[2]: *** [prefs.lo] Error 1
make[2]: Leaving directory `/root/scribus/libprefs'
make[1]: *** [install-recursive] Error 1
make[1]: Leaving directory `/root/scribus'
make: *** [install-recursive] Error 1
root@localhost:~#
Kaj vse je narobe. V instalacijski datoteki je posopek tocno taksen.
ps> Sorry za dolg post.
www.gwost.com
klevic ::
Urejeno.
www.gwost.com
  • spremenil: klevic ()
Program za izdelavo pohval - priznanj
Oddelek: Programska oprema
104398 (4302) racunalnicar
[Linux] Program za izdelavo publikacij
172421 (2065) Preseren
Scribus in sumniki
61281 (1236) gapa
Izšel Scribus 1.2
143339 (3339) igzebedze
Gentoo Linux & nov KDE problem!
101673 (1613) Tarzan
