login account
login account
Juventus ::
Kje dobiti scripto za alogin account.
Če se da link dat, ker n ahotscripts nisem našu nič.
Hvala
Baja ::
http://www.hotscripts.com/PHP/Scripts_a...
whooops, jaz pa sem jih nasel 120 !!! predpostavljam da rabis za php.
  • spremenil: Baja ()
Juventus ::
ja to sem našu tud jaz samo login napišeš. Sam ka mi to nuca, ko tu ni nič kar jaz rabim.
Primoz ::
Kaj pa ti rabiš?
There can be no real freedom without the freedom to fail.
tec ::
Tale je cist preprosta, kjer rocno naredis acounte
login.php
session_start();
$geslo["janez"] = "abc";
$geslo["miha"] = "cba";
$fUname = "";
if (array_key_exists("uname", $_POST)) $fUname = $_POST["uname"];
if (array_key_exists("passwd", $_POST)) $fPasswd = $_POST["passwd"];
$fail = false;
if (array_key_exists("Submit", $_POST)){
	foreach($geslo as $xUname => $xPasswd){
		if($fUname == $xUname && $fPasswd == $xPasswd){
			$_SESSION["prijavljen"] = 1;
			header("Location: index.php");
			exit;
	$fail = true;
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<head>
<title>Untitled Document</title>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-2">
</head>
<body>
<form name="form1" method="post" action="">
  <p align="center"> <font size="2" face="Verdana, Arial, Helvetica, sans-serif"><br>
    <strong>Uporabniško ime</strong><br>
    <input name="uname" type="text" id="uname">
    <br>
    <br>
    <strong>Geslo</strong><br>
    <input name="passwd" type="password" id="passwd">
    <br>
    <br>
    <input type="submit" name="Submit" value="Prijava"><br><br>
		if ($fail) echo "<font color=\"red\">Prijava ni uspela!</font>";
	</font> </p>
  </form>
</body>
</html>
login_inc.php
	session_start();
	if (!array_key_exists("prijavljen", $_SESSION) ||$_SESSION["prijavljen"] != 1){
		header("Location: login.php");
		exit;
Potem das pa na zacetek vsakega php fajla, ki ga hoces med pod kljucem: include "login_inc.php";
Pomoč pri kodi
Oddelek: Izdelava spletišč
92313 (1956) root987
problem z phpjem
304852 (4265) snow
preusmeritev
51686 (1603) pepelopez
[php] Problem z dinamično stranjo
111922 (1767) Iskraman
Login script
51971 (1842) tec
