Forum » Operacijski sistemi » PDF Reader in Linux Mandarake
Potegnil sem z adobove strani Acrobat reader 5.09 za Linux.
Razpakiral sem ga znal.
V paketu je INSTALL datoteka ki se mora zalaufati, tako piše v readme datoteki.
Ok do tu vse jasno. Če preko ti. explorerja kliknem na ta install mi javi sledeče :
he filename "INSTALL" indicates that this file is of type "Software installation instructions". The contents of the file indicate that the file is of type "(null)". If you open this file, the file might present a security risk to your system.
Do not open the file unless you created the file yourself, or received the file from a trusted source. To open the file, rename the file to the correct extension for "(null)", then open the file normally. Alternatively, use the Open With menu to choose a specific application for the file.
" Imam samo opcijo cancle.
Če grem v konzolo pa probam zalaufati ta INSTALL mi javi :
[root@gost linux-509]# sh INSTALLMi sicer začne z inštalacijo, toda ko vtipkam agree, ter potrdim direktorij mi javi spodnjo napako :
Directory "/usr/local/Acrobat5" does not exist.
Do you want to create it now? [y] y
Installing platform independent files ... Done
Installing platform dependent files ... Done
INSTALL: line 219: ed: command not found
ERROR installing /usr/local/Acrobat5/bin/acroread
Čeprav sedaj sicer javi da je dokument PDF. Rad bi imel ikonco....
Hvala
Hvala
| » | Skype problemOddelek: Programska oprema | 1851 (1256) | tv6865 |
| » | Šifrirana mapaOddelek: Operacijski sistemi | 2830 (2301) | amigo_no1 |
| » | Mac OS Snow Leopard na PCOddelek: Operacijski sistemi | 5623 (4171) | Gray_Warden_ |
| » | Unencrypt...Oddelek: Pomoč in nasveti | 1637 (1530) | solatko |
| » | Internet explorer se ugasa - sam od sebe... HELP !Oddelek: Pomoč in nasveti | 2086 (1974) | jarni2 |
