P4P800 disketa za SATA
CirCA|PhP ::
Lep pozdrav!
Danes ravno disk notr dal in prejle stvar zaganjam in zberem za dodat SATA/RAID disk. Ampak se mi na smolo ostavi tam, kjer je treba Manufacturer-supplied hardware support disk notr dat. Ga nikjer ne najdem. Ga ma mogoče kdo od vas? Pa bi mi lohk podatke poslal? Je kje na netu? Na Asusovi strani so eni gonilniki, ampak je 7mb vsega skp, kar pa ne gre na disketo...
mohha53 ::
Tile gonilniki za SATA bi morali biti zraven matične plošče.
Po mojem samo tiste z Asusa dolpotegni in instalaj, pa bi moralo biti vse OK. Velikost je prava(če misliš driverje, hehe)!
Myk
MadMax ::
Če maš v BIOSu enejblan S-ATA kontroler, zadeva ne sme zahtevat nič dodatnega, saj ne gre za standalone kontroler, temveč za southbridge (ICH5-R).
/edit:
V najslabšem primeru imaš v tej 7MB veliki pakungi en fajl, MakeDisk.exe , ki ti kreira disketo.
Probaj, pa poročaj!
/edit#2:
Mater kako so eni leni... V tej pakungi je en lep readme.txt . Le zakaj je notri?
Aja, zato ker v njem piše tudi naslednje:
4.2 PRE-INSTALLATION USING THE F6 METHOD FROM A FLOPPY DISK
1. Extract all driver files from the installation package.
See Section 6 for instructions on extracting the files.
2. Create a floppy containing the iaStor.inf, iaStor.sys,
iaStor.cat and TxtSetup.oem files in the root directory.
3. At the beginning of the operating system setup, press F6
to install a third party SCSI or RAID driver.
4. When prompted, select 'S' to Specify Additional Device.
5. When prompted, insert the floppy disk you created and
press enter.
6. At this point you should be presented with a selection
for "Intel(R) RAID Controller". Highlight this selection
and press enter.
7. Press enter again to continue. Leave the floppy disk in
the system until the next reboot as the software will
need to be copied from the floppy disk again when setup
is copying files.
  • spremenil: MadMax ()
frenk ::
kolikor jest vem more bit samo bios updejtan
TribesMan ::
Rabiš disketo z gonilniki za SATA RAID kontroler, ki jo moraš "predložiti" Windowsem ob instalaciji... takoj na začetku ko zbootaš z CDja... Gonilniki so zagotovo na domači strani proizvajalca. Več ti pa ne moremo pomagat.
TribesMan
Problem instalacije XP - SATA disk
162858 (1864) Duhec
Instalacija XP ne najde diska
Oddelek: Operacijski sistemi
416621 (5484) fredyjetle
vista problem
153710 (3369) markk1
RAM problem
252246 (2023) drLinux
Bios 8rda+
Oddelek: Navijanje
71342 (1240) kuglvinkl
