Problem Prenosnik Gericom!!
AnWar ::
Moj Problem, hvala za pomoc..
Napisem v command promt: chkdsk c:
Ter dobim to, deluje pocasi samo ko nalaga windowse po 5 minut....
The type of the file system is NTFS.
WARNING! F parameter not specified.
Running CHKDSK in read-only mode.
CHKDSK is verifying files (stage 1 of 3)...
File verification completed.
CHKDSK is verifying indexes (stage 2 of 3)...
Deleting index entry INDEX.MAP in index $I30 of file 5065.
Deleting index entry OBJECTS.MAP in index $I30 of file 5065.
Index verification completed.
Errors found. CHKDSK cannot continue in read-only mode.
ter to;
C:\>chkdsk c:
CHKDSK is verifying security descriptors (stage 3 of 3)...
Security descriptor verification completed.
Correcting errors in the Volume Bitmap.
Windows found problems with the file system.
Run CHKDSK with the /F (fix) option to correct these.
10241405 KB total disk space.
6735820 KB in 34695 files.
11540 KB in 1952 indexes.
0 KB in bad sectors.
94973 KB in use by the system.
53264 KB occupied by the log file.
3399072 KB available on disk.
4096 bytes in each allocation unit.
2560351 total allocation units on disk.
849768 allocation units available on disk.
Hvala se enkret za pomoc...
Problem z ramom ali diskom? Prosim za nasvet.
111578 (1480) Duhec
težava z računalnikom (počasno delovanje, brenči...)
162379 (2033) legendary
chkdsk /f problem
201932 (1739) bluefish
Težave z diskom - consistency
71557 (1454) ender
Par problemov z XPji
Oddelek: Operacijski sistemi
343098 (2344) Mercier
