strictom ::
Welcome to Text-Only Counterstrike. You are in a dark, outdoor map.
>GO NORTH
You have been pwned by a grue....
Ka je "grue" pri CS?
sverde21 ::
Nasprotnik?
<?php echo `w`; ?>
strictom ::
A misliš?
OmegaBlue ::
grue ni del CS ;)
Grue (monster) @ Wikipedia malo informacij :D
PrimozR ::
Fak, fak, fak, folk ... zkaj mora obstajat nekdo k ti lahk z dobesednim NIČ zmeša glavo :'(
Ženska? :>
Ziga Dolhar ::
PIP,
pa ti si genij!!!
https://dolhar.si/
mare_ ::
No, teoretično bi bil verjetno lahko tudi tip. Kaj drugega pa že bolj težko.
St@jler ::
shemale? :P
PrimozR ::
Ew.
strictom ::
Grueji so bolj Zork zadeva.
Vam pokažem en primer kako te popwna grue! :D
> go east
You are behind the white house. In one corner of the house
there is a window which is slightly ajar.
> open window
With great effort, you open the window far enough to allow passage.
> go in house
You are in the kitchen of the white house. A table seems to have
been used recently for the preparation of food. A passage leads to
the west, and a dark staircase can be seen leading upward. To the
east is a small window which is open.
On the table is an elongated brown sack, smelling of hot peppers.
A clear glass bottle is here.
The glass bottle contains:
A quantity of water.
> go west
You are in the living room. There is a door to the east. To the west
is a wooden door with strange gothic lettering, which appears to be
nailed shut.
In the center of the room is a large oriental rug.
There is a trophy case here.
On hooks above the mantlepiece hangs an elvish sword of great antiquity.
A battery-powered brass lantern is on the trophy case.
> move rug
With a great effort, the rug is moved to one side of the room.
With the rug moved, the dusty cover of a closed trap door appears.
> open trap door
The door reluctantly opens to reveal a rickety staircase descending
into darkness.
> go down
It is pitch dark. You are likely to be eaten by a grue.
> go north
There is a wall there.
> go south
Oh, no! You walked into the slavering fangs of a lurking grue.
> strictom rules
I don't understand that.
  • spremenila: strictom ()
mavec ::
Fine novice.
Dobil Chronicles of Riddick UNRATED DVD iz ZDA. Včeraj pa sem izvedel, da je prišel še PITCH BLACK UNRATED.:O :D
  • spremenil: mavec ()
Looney ::
Jej.
mavec ::
Jap, res je in to 3x jej.8-O Drugje nikjer ni dobit polnih UNRATED izdaj.;((
Poslusam Virgin radio, ki v zivo oddaja Isle of Wight Festival. Evo se shoutcast za festival.
iggy ::
tinkec == Mtosev ?? :D
Hey, you're fat!
mavec ::
iggy, v isti kos me ni treba dajat.;)
Poslusajte ta festival. Sami dobri bandi igrajo.
Tic ::
persona civitas ;>
r5r ::
Testiraš novi grelec?
And it makes me wonder.
Pyr0Beast ::
Vent zaribal ?
strictom ::
A koga zanima od česa vsega je odvisna hitrost kemijske reakcije?
mare_ ::
Od temperature, koncentracije reaktantov, površine reaktantov in katalizatorja. :D
strictom ::
Kemija sux!
mare_ ::
Nisi ti 3. letnik?
PrimozR ::
2. je :> Jest se grem pa napiflat celo knjigo za slovnico 3. letnik na pamet da jutri pišem 4 (yeah right) in imam slovenščino 3 (PHA!) in tako obdržim šanse za prav dober uspeh pri življenju (pa kaj je s tem tipom??? :>)
iNooby ::
P|P ti si bad boy ker si prav dober
Haters gonna hate...
mare_ ::
aja, 2.... pa vseeno, hitrost reakcije? ni to še 1. letnik? :D
P|P... če te kaj tolaži, poznam še nekoga, ki ima tudi podobne težave s slovenščino ;)
strictom ::
mare_, 2. letnik, 1. konferenca!
GenZNPC ::
nvem če sem vam mojo novo kreacijo že pokazal ampak vseeno :D
najbolj suksa madžarščina in to na maturitetnem nivoju verjemite mi.... povprečje mam 1,6 še moram literarni esej popravt pa mi zaključi dva... mislu sem da bo lažje pa niiii :(
skibidi
Orchestra ::
Poznate tist vic o Hasotu, ki se preimenuje v Janeza, pa pol reče, da je sam 1 uro slovenc pa ma že probleme s čefurji?Sam sem čefur pa me nekako zanima kaj je fora tega vica :D ???
Azrael ::
Ti bom poskusil odgovoriti z vicem:
Mali Mustafa je šel v OŠ. Tam jin njegovo ime nikakor niso mogli zapomniti ne sošolci ne učitelji in so mu predlagali, če ga lahko imenujejo Janezek. Mali se je seveda strinjal.
Po šoli je šel domov in se igral na dvorišču. Ko ga starša kličeta Mustafa kosilo, se ni zmenil zanju in se igral dalje. Oče in mama prideta do njega in ga vprašata, kaj je narobe.
Mali odgovori: Jaz nisem več Mustafa, jaz sem Janezek! Pričakovano je dobil batine.
Popoldne ga sošolec vpraša, kako mu je kaj všeč ime Janez? Mustafa/Janezek odgovori: Meni je zelo vseč, samo sta me zato že nalomila dva čefurja...
Nekoč je bil Slo-tech.
Im back from the US!! :D
r5r ::
Sedaj pa trikrat vdihni in pokaži slike.
Pyr0Beast ::
.. in zadrži dih. :D
OrkAA ::
mtosev je nazaaaaaaaaaaaaaaaaaaaaaaaaj!!!!!!!!!!
mavec ::
A US sploh obstaja? :D
Evo, da se mal mtoseva zdrazm. ;>
  • zavaroval slike: OmegaBlue ()
Tic ::
Ne, to ni super grelec, tudi zariban ventilator ni, to je superman!!
Resno, 7600gt pasivno hlajena po igranju TMN.
EDIT
"Pa da ne bo spet vika in krika o nelegali. Stran je legalna. Nekatere serije, filmi, clipi so zastonj, za druge je treba plačat."
Se pravi, če odprem stran s torrenti in naredim plačljivo registracijo, je potem to legalno. Jupi, this time next year, I'll be a millionare! - OF&H
persona civitas ;>
  • spremenil: Tic ()
mare_ ::
Right. Medtem ko mi prijazna teta v srebrni škatlici govori, da naj čez 250 metrov zavijem desno, se peljem mimo hiše, pred katero en deklič sedi na travi in vneto tipka po svojem macbooku, nasproti pa se pripeljeta dva strica na segwayu. V kateri državi sem že? :D
  • spremenil: mare_ ()
Bedna je, če je imela navaden Macbook, morala bi imeti PRO-ja. :D jok3
strictom ::
Tam za devetimi gorami, morji sedmimi, živela je cvetlica z listki zelenimi ... v Republiki Sloveniji, lajlalajlalalaj lajlalajlala lajlalajlalalaj ...
Bodimo ponosni na našo stvaritev z balkanskimi plačami in srednjeevropskimi cenami!!!
PrimozR ::
Ah, plače so pa ja malce višje od balkanskih :P Sicer je pa hrana in vse to enako, kot v nemčiji oz. Italiji. tam so pač storitve toliko dražje, ter seveda tudi stanovanje (600€ najemnina v Nemčiji).
mare_ ::
Ni res. Pri nas ne tlačimo mehurčkov v vsako stvar, ki je vsaj od daleč malo podobna pijači. In pivo se ne šteje med hrano. In v lokalni štacuni me presneto čudno gledajo, ko jih vprašam, če imajo morda parmezan v še ne naribani obliki.
Vajenc ::
mtosev, kako je bilo v US?
lepoje blo rabilo je vec trajat, porabili 486USD zame :D :D :D
sverde21 ::
Em kaj si reku 8-O ? Se še navajaš na slovenščino al kaj?
<?php echo `w`; ?>
  • spremenil: sverde21 ()
hehe ANG sploh nisem uporabljal tip pri katerem smo bli je iz SLO pa smo se pogovarjali HR ker je htel vadit :D :D :D
iggy ::
Dej mtsoev kšno sliko pliiissss ;)
Hey, you're fat!
John Abruzzi ::
Dej počakte da človk nardi fotomontaže no.
Roadkill ::
Čaki... to so tri al štiri kurbe?... nisem na tekočem z ameriškimi tarifami...
Ü
trdoreh ::
5 s popustom! Jaz sem na tekočem:D
strictom ::
Ma kurac. MP3 player (Creative MuVo V200) mi je razpado! Sem zalepo prej z sekundem pa en kurac kaj drži! A una pištola za lepilo, da bi cevga nafilo, bi blo vredo? Mislim nebi prišlo do kakega kurcšlusa al pa kaj?
sverde21 ::
Od kdaj pa plastika prevaja elektriko :P
<?php echo `w`; ?>
302 / 1180
