RMI
RMI
mov ax 0x7c0 ::
Zdravo!
Rad bi napisal preprost RMI server in Client (no ja, sem jih že). Imam pa problem z zagonom Clienta! Server mi dela! Ko zaženem Client z ukazom:
java -Djava.security.policy="c:\path\"policy Client
mi javi tole izjemo:
HelloImpl err: Error unmarshaling return header; nested exception is:
java.io.EOFException
java.rmi.UnmarshalException: Error unmarshaling return header; nested exception
is:
at sun.rmi.transport.StreamRemoteCall.executeCall(StreamRemoteCall.java:
203)
at sun.rmi.server.UnicastRef.invoke(UnicastRef.java:350)
at sun.rmi.registry.RegistryImpl_Stub.lookup(Unknown Source)
at Client.main(Client.java:15)
Caused by: java.io.EOFException
at java.io.DataInputStream.readByte(DataInputStream.java:333)
189)
... 3 more
kaj to za vraga pomeni?
koda HelloImpl.java:
import java.rmi.RemoteException;
import java.rmi.server.UnicastRemoteObject;
import java.rmi.server.RemoteServer;
import java.rmi.server.ServerNotActiveException;
public class HelloImpl extends UnicastRemoteObject implements Hello
public HelloImpl() throws RemoteException {
super();
public String sayHello(String arg) throws RemoteException {
String client;
try {
client = RemoteServer.getClientHost();
catch (ServerNotActiveException e) {
client = "*unknown*";
System.out.println("Server received from host " + client + " following message: " + arg);
return "Server says hi!";
koda Client.java:
import java.rmi.registry.Registry;
import java.rmi.registry.LocateRegistry;
public class Client
public static void main(String args[]) {
// get host where registry is running
String host = args.length>0 ? args[0] : "localhost";
try {
// get reference to registry
Registry registry = LocateRegistry.getRegistry(host, 5001);
// connect to remote object via registry
Hello obj = (Hello)registry.lookup("/HelloServer");
// invoke remote method
String ret_value = obj.sayHello("Hi from client!");
// print return value
System.out.println("Message from server: " + ret_value);
catch (Exception e) {
System.out.println("HelloImpl err: " + e.getMessage());
e.printStackTrace();
prosim če keri vidi kakšno napako naj pove kaj je! Ker se že Fu**m cel dan s tem, čitam toturiale pa nikjer ni opisam ta problem...
lp, Slavc
Web services - Neveljavni karakterji v XML
Oddelek: Programiranje
316214 (5326) boolsheat
Java - problem povezave na FTP
101501 (1358) igor0203
tomcat in datasource
132637 (2394) infiniteLoop
[JAVA] zaustavitev niti (threadov)
223660 (3660) morbo
Kako pošiljanje datotek v JAVI.
142211 (2082) kopernik
