Forum » Programiranje » Dialog box brez MFC
Dialog box brez MFC
mov ax 0x7c0 ::
Zdravo!
Zanima me kako dostopati do elementov(kera windowska funkcija oz keri message) ki so v dialogu?
Mam nekaj takega:
INT_PTR CALLBACK DialogProc2(HWND hdlg, UINT msg, WPARAM wparam, LPARAM lparam){
HWND edit = ::GetDlgItem(hdlg, IDC_EDIT1);
switch(msg){
case WM_INITDIALOG:
::SetWindowText(hdlg,"Setup");
return TRUE;
case WM_COMMAND:{
switch(LOWORD (wparam)){
case IDOK:
::EndDialog(hdlg, wparam);
break;
case IDCANCEL:
break;
case IDC_BUTTON1:
::MessageBox(hdlg, "asdas", "asd", MB_OK);
::SetDlgItemText(hdlg, IDC_EDIT1, "a");
//nastavim stopnjo
break;
return FALSE;
ampak to mi ne dela!!! Če ve keri zakaj?
lp, Slavko
Mam nekaj takega:
switch(msg){
case WM_INITDIALOG:
return TRUE;
case WM_COMMAND:{
case IDOK:
break;
case IDCANCEL:
break;
case IDC_BUTTON1:
//nastavim stopnjo
break;
return FALSE;
lp, Slavko
| » | C++ programirane v Open GL oz. Direct xOddelek: Programiranje | 3427 (2698) | Vesoljc |
| » | OpenGL problemOddelek: Programiranje | 2915 (2481) | Gundolf |
| » | Win32 API in C++Oddelek: Programiranje | 1950 (1821) | Monster |
| » | OpenGL orr v ansi cOddelek: Programiranje | 2154 (1942) | igor12 |
| » | DirectX, neki ne greOddelek: Programiranje | 1565 (1463) | Senitel |
