nek cuden virus
nek cuden virus
tec ::
Slika pove tisoc besed
Ima kdo idejo kaj bi to bilo?
  • zavaroval slike: Gandalfar ()
Gandalfar ::
pač virus .. klikn na opis pa si poglej kako deluje
WildTHink ::
Zbriš restore file. Če seveda nimaš kakšnih pomembnih stvari.
Drgač se pa ne sikeri prevec zaradtega... Ta virus ti ne bo nč naredu dokler ne boš pognal System restore.
Kako zbrišeš restore datoteke?
To delete your restore files: Right click "My Computer",click "Properties", "Performance", "FileSystem", "Troubleshooting", tick "Disable System Restore". Click "apply", "ok", reboot. This will erase all your restore points. After doing this repeat the above steps but "un-tick" Disable System Restore", click "apply", "ok", and reboot again. Make sure that a new restore point is made after your computer is clean. You may have to do it manually.
Kratek prevod! Odkljukaš Disable System Restore in restartaš. Zbrišeš kljukico, ki si jo naredu in se en restart... in maš zdej clean restore point, seveda če na računalniku nimaš nobenih virusou, trojancev,....
So... are you red or blue?
SSD - kam so izginili GB ?!
184881 (4612) SanAndreas
HP 6735s win Vista - problem update KB935509
61700 (1611) mjk
Ikone v win XP izginile po uporabi programa Spybot Search & Destroy. Kako dobiti ikon
52690 (2646) riba43
WinME dir <B>_Restore</B>
Oddelek: Programska oprema
71564 (1432) Han
winME restore mapa
213138 (2680) Jeronimo
