Forum » Programska oprema » nek cuden virus
nek cuden virus
WildTHink ::
Zbriš restore file. Če seveda nimaš kakšnih pomembnih stvari.
Drgač se pa ne sikeri prevec zaradtega... Ta virus ti ne bo nč naredu dokler ne boš pognal System restore.
Kako zbrišeš restore datoteke?
To delete your restore files: Right click "My Computer",click "Properties", "Performance", "FileSystem", "Troubleshooting", tick "Disable System Restore". Click "apply", "ok", reboot. This will erase all your restore points. After doing this repeat the above steps but "un-tick" Disable System Restore", click "apply", "ok", and reboot again. Make sure that a new restore point is made after your computer is clean. You may have to do it manually.
Kratek prevod! Odkljukaš Disable System Restore in restartaš. Zbrišeš kljukico, ki si jo naredu in se en restart... in maš zdej clean restore point, seveda če na računalniku nimaš nobenih virusou, trojancev,....
So... are you red or blue?
| » | SSD - kam so izginili GB ?!Oddelek: Pomoč in nasveti | 4881 (4612) | SanAndreas |
| » | HP 6735s win Vista - problem update KB935509Oddelek: Pomoč in nasveti | 1699 (1610) | mjk |
| » | Ikone v win XP izginile po uporabi programa Spybot Search & Destroy. Kako dobiti ikonOddelek: Pomoč in nasveti | 2690 (2646) | riba43 |
| » | WinME dir <B>_Restore</B>Oddelek: Programska oprema | 1564 (1432) | Han |
| » | winME restore mapaOddelek: Pomoč in nasveti | 3138 (2680) | Jeronimo |
