Forum » Programiranje » Kje je napaka?
Kje je napaka?
mov ax 0x7c0 ::
Torej začel sem nekaj z okni in sporočili... Rad bi ustvaril čisto navadno win32 aplikacijo(samo eno okence) In sem prišel do tega:
stvar ne dela, pa nikakor ne morem zgruntati zakaj. Ko stvar poženem v debug načino, je lepo razvidno, da nagaja funkcija CreateWindow(), ker vrne vrednost NULL, kar pomeni da se ni pravilno zaključila. Tukaj pa mi ni jasno zakaj tako, saj so vsi zahtevani argumenti te funkcije pravilni, vsaj tako jaz mislim. Prosim če mi lahko kdo pomaga najti napako?
lp, Slavko
#include windows.h
#include stdlib.h
#include memory.h
#include tchar.h
HINSTANCE hinst;
HWND hwndMain;
LRESULT CALLBACK WndProc(HWND, UINT, WPARAM, LPARAM);
int WINAPI WinMain(HINSTANCE hInstance, HINSTANCE hPrevInstance,
LPSTR lpszCmdLine, int nCmdShow)
MSG msg;
WNDCLASS wc;
UNREFERENCED_PARAMETER(lpszCmdLine);
// Register the window class for the main window.
if (!hPrevInstance)
wc.style = 0;
wc.lpfnWndProc = (WNDPROC) WndProc;
wc.cbClsExtra = 0;
wc.cbWndExtra = 0;
wc.hInstance = hInstance;
wc.hIcon = LoadIcon((HINSTANCE) NULL,
IDI_APPLICATION);
wc.hCursor = LoadCursor((HINSTANCE) NULL,
IDC_ARROW);
wc.hbrBackground = (HBRUSH)(COLOR_WINDOW +1);
wc.lpszMenuName = "MainMenu";
wc.lpszClassName = "MainWndClass";
if (!RegisterClass(&wc))
return FALSE;
hinst = hInstance; // save instance handle
// Create the main window.
hwndMain = CreateWindow("MainWndClass", "Sample",
WS_OVERLAPPEDWINDOW, CW_USEDEFAULT, 0,
CW_USEDEFAULT, 0, NULL,
NULL, hinst,NULL);
// If the main window cannot be created, terminate
// the application.
if (!hwndMain)
return FALSE;
// Show the window and paint its contents.
ShowWindow(hwndMain, nCmdShow);
UpdateWindow(hwndMain);
// Start the message loop.
while (GetMessage(&msg, (HWND) NULL, 0, 0))
TranslateMessage(&msg);
DispatchMessage(&msg);
// Return the exit code to the system.
return msg.wParam;
LRESULT CALLBACK WndProc(HWND hwndMain, UINT msg, WPARAM wParam, LPARAM lParam){
PAINTSTRUCT ps;
HDC hdc;
switch(msg){
case WM_PAINT:
hdc = BeginPaint(hwndMain, &ps);
RECT rt;
GetClientRect(hwndMain, &rt);
EndPaint(hwndMain, &ps);
break;
return 0;
lp, Slavko
Vesoljc ::
dej probi tkole:
#include <windows.h>
/* Declare Windows procedure */
LRESULT CALLBACK WindowProcedure (HWND, UINT, WPARAM, LPARAM);
/* Make the class name into a global variable */
char szClassName[ ] = "WindowsApp";
int WINAPI WinMain (HINSTANCE hThisInstance,
LPSTR lpszArgument,
int nFunsterStil)
HWND hwnd; /* This is the handle for our window */
MSG messages; /* Here messages to the application are saved */
WNDCLASSEX wincl; /* Data structure for the windowclass */
/* The Window structure */
wincl.hInstance = hThisInstance;
wincl.lpszClassName = szClassName;
wincl.lpfnWndProc = WindowProcedure; /* This function is called by windows */
wincl.style = CS_DBLCLKS; /* Catch double-clicks */
wincl.cbSize = sizeof (WNDCLASSEX);
/* Use default icon and mouse-pointer */
wincl.hIcon = LoadIcon (NULL, IDI_APPLICATION);
wincl.hIconSm = LoadIcon (NULL, IDI_APPLICATION);
wincl.hCursor = LoadCursor (NULL, IDC_ARROW);
wincl.lpszMenuName = NULL; /* No menu */
wincl.cbClsExtra = 0; /* No extra bytes after the window class */
wincl.cbWndExtra = 0; /* structure or the window instance */
/* Use Windows's default color as the background of the window */
wincl.hbrBackground = (HBRUSH) COLOR_BACKGROUND;
/* Register the window class, and if it fails quit the program */
if (!RegisterClassEx (&wincl))
return 0;
/* The class is registered, let's create the program*/
hwnd = CreateWindowEx (
0, /* Extended possibilites for variation */
szClassName, /* Classname */
"Windows App", /* Title Text */
WS_OVERLAPPEDWINDOW, /* default window */
CW_USEDEFAULT, /* Windows decides the position */
CW_USEDEFAULT, /* where the window ends up on the screen */
544, /* The programs width */
375, /* and height in pixels */
HWND_DESKTOP, /* The window is a child-window to desktop */
NULL, /* No menu */
hThisInstance, /* Program Instance handler */
NULL /* No Window Creation data */
/* Make the window visible on the screen */
ShowWindow (hwnd, nFunsterStil);
/* Run the message loop. It will run until GetMessage() returns 0 */
while (GetMessage (&messages, NULL, 0, 0))
/* Translate virtual-key messages into character messages */
TranslateMessage(&messages);
/* Send message to WindowProcedure */
DispatchMessage(&messages);
/* The program return-value is 0 - The value that PostQuitMessage() gave */
return messages.wParam;
/* This function is called by the Windows function DispatchMessage() */
LRESULT CALLBACK WindowProcedure (HWND hwnd, UINT message, WPARAM wParam, LPARAM lParam)
switch (message) /* handle the messages */
case WM_DESTROY:
PostQuitMessage (0); /* send a WM_QUIT to the message queue */
break;
default: /* for messages that we don't deal with */
return DefWindowProc (hwnd, message, wParam, lParam);
return 0;
BigWhale ::
Presaltaj na linux in uporabi Qt knjiznico!
#include <qapplication.h>
#include <qpushbutton.h>
int main( int argc, char **argv )
QApplication a( argc, argv );
QPushButton yoohoo( "Say hello to my little friend!", 0 );
yoohoo.resize( 300, 30 );
a.setMainWidget( &yoohoo );
yoohoo.show();
return a.exec();
yoohoo.show();
return a.exec();
| » | C++ programirane v Open GL oz. Direct xOddelek: Programiranje | 3427 (2698) | Vesoljc |
| » | OpenGL problemOddelek: Programiranje | 2915 (2481) | Gundolf |
| » | Win32 API in C++Oddelek: Programiranje | 1950 (1821) | Monster |
| » | OpenGL orr v ansi cOddelek: Programiranje | 2154 (1942) | igor12 |
| » | DirectX, neki ne greOddelek: Programiranje | 1565 (1463) | Senitel |
