[Android] od 2027 pristopnina in preverjanje devov
LiquidAI ::
Naslednje leto Google začne pobirat pristopnino in preverjat deve .
Android developer verification
By making Android safer, we're protecting an environment for developers and users to confidently create and connect. This extra layer of security helps deter bad actors and makes it harder for them to repeatedly spread harm.
Choose your verification path
Wherever you choose to distribute your apps, Google supports you in your developer journey. Review the guides to understand your account options and potential fees.
Timeline
We're announcing these changes early and incorporating developer feedback to help keep the Android ecosystem safe and sustainable.
Milestone Details
August 2026 Developer APIs, limited distribution accounts, and power user advanced flow launch.
September 30, 2026 Protections begin for all users who install apps from participating stores in Brazil, Indonesia, Singapore, and Thailand on certified devices running Android 7+.
2027 and beyond Verification capability will be expanded globally for all apps on certified Android devices in 2027.
Workaround https://keepandroidopen.org/en/
Google says "power users" can "still install" unverified apps. Here's what that actually looks like:
Delve into System Settings, find About Phone
Tap the build number seven times to enable Developer Mode
Dismiss scare screens about coercion
Enter your PIN
Restart the device
Wait 24 hours
Come back, dismiss more scare screens
Pick "allow temporarily" (7 days) or "allow indefinitely"
Confirm, again, that you understand "the risks"
Nine steps. A mandatory 24-hour cooling-off period. For installing software on a device you own.
Worse: this flow runs entirely through Google Play Services, not the Android OS. Google can change it, tighten it, or kill it at any time, with no OS update required and no consent needed.
