Hoby Elektronika - Veliki set (RPI, kamere, motorji, vezja, orodja) - 500 EUR skupna vrednost preko 1500
sterling ::
Na slikah in seznamu ni vse. So bolj izpostavljene zadeve motorji, kamere, raspberry PI, vezja, orodja, zasloni in baterije. Prodajam le komponente, ki niso bile rabljne ali so bile minimalno rabljene. Vse baterije so skoraj nove, polne kapacitete z manj kot 5 cikli polnjenja. Zraven je še nekaj PIN, ribbon, USB kablov, pretvornikov itd..
Cena: 500 EUR
040556907, Celje
Motorji in krmilniki
BLDC
2x PICHLER Boost 20 BLDC 1190 kV
2x PICHLER XQ30 ESC za Boost 20
2x Dilwe BLDC 880 kV
2x RUIZHI 40A 2-4S ESC za Dile BLDC
SERVO
6x MG996R servo motor 4.8V -> 7.2V, 10Kg/cm -> 13Kg/cm
2x Miuzei MS62 270* deg 25Kg 4.8V -> 8.4V 20Kg/cm -> 25Kg/cm
2x INJORA 5022 360* deg 22Kg 4.8V -> 6V
2x MG90S 2Kg/cm 4.8V
10x MF90 micro 2Kg/cm 4.8V -> 6V
DC
3x XD-63100 DC 12/24V 3000/5000RPM 2.5Kgf/cm / 5Kgf/cm 150W
4x XD-3420 DC 12/24V 3500/7000RPM 1Kgf/cm / 2Kgf/cm 30W
5x MINI DC 10000 RPM @ 6V
1x Micro DC geared 150 RPM @ 6V
2x RS-555 24V 35000 RPM
3x RS-775 12V / 24V (variable) 10000 RPM -> 20000 RPM
2x RS-895 12 / 24V (variable) 3000 RPM -> 6000 RPM 5.2Kgf/cm -> 10Kgf/cm
3x HS 12V motor 10000 RPM
2x Geartisan - geared 12V 100RPM 15Kgf/cm
1x 90 deg DC 12V 150RPM 5Kgf/cm
2x 90 deg DC 12V 20RPM 10Kgf/cm
1x DC 12V 50RPM 30Kgf/cm
STEPPER
5x NEMA17 42-40 17HS4401 1.5A 3.8V
5x NEMA17 17HE15-1504S
10x 28BYJ-48 MINI
10x 28BYJ-49 MINI DRIVER BOARD
Kamere:
1x Waveshare 1MP 90 FPS Raspberry PI Global Shutter HD kamera
1x SVPro 90-120 FPS 2MP 1200, 1024, 720p Global Shutter USB kamera z 10x Optical Zoom
Vezja, programatorji, krmilniki
1x Raspberry PI 5 8GB
1x Geekworm M2 NVMe adapter
1x Patriot P320128GB SSD NVMe za Raspberry PI 5
1x Raspberry PI 5 Active Cooler Fan
1x Raspberry PI 6 27W USB-C Power Supply
1x 7” (inch) 1024 x 600 HD TFT LCD Touchscreen za Raspberry PI 5
1x Remote keyboard/controller - Bluetooth/WIFI programmable
3x RTC (Real Time Clock) DS3231
1x STM Link V2 Programator
1x STM Basic Programator
3x STM32F401 V3 development board
40x HAL sensor + 40x magnet za HAL
4x IR senzor + 4x LED za senzor
5x ESP32 (2x S3) DevKit-C
9x BTS7960 43A 5.5V -> 27V Dual-H bridge motor driver
7x L298N 2A 5V -> 36V Dual-H bridge motor driver
2x M18 Optical proximity sensor
8x TB6600 9 - 42V 4A stepper motor driver
5x DRV8825 8.2V - 45V, ~3A stepper motor driver
5x DRV8825 heatsink
5x TMC2209 v1.2 5.5V - 28V, ~2A (3A peak) stepper motor driver
5x TMC2209 v1.2 heatsink
5x TMC2208 v1.2 4.75V - 36V, ~2A (3A peak) stepper motor driver
5x TMC2208 v1.2 heatsink
3x XOO1Q Temperature sensor
5x Magnetometer ??????
6x LDC HD44780 I2C 4x20
10x Encoder - variable + 10x plastic button
500x capacitor (various)
3x LM2596 DC-DC converter with LCD 3V : 40V -> 1.5 : 35V
180x PIN button
50x STOP Switch / Button
7x ESP32 TERMINAL Adapter
5x AS5600 3xaxis magnetometer senzor
2x ESP32 S3 DevKit-C
Orodja in mehanski deli
1x DREMEL Gas soldering iron + extra tips
1x Soldering station (electric)
4x 250mm Linear rails + mounting brackets
5x M3 threaded inserts package
1x M5 threaded inserts package
10x ALU mechanical button RS25
1x Aluminum cutter tool
~100 various cable connectors
~100 PIN 1v2, 1v3, 1v4, 1v6 cable HEADERs
~100x M2-M3 threaded spacers
~ 30 GT2 Pulleys, relays, spacers, adapters
10x PTFE Ventili
30x PTFE Spoke
1x 5m PTFE Cevi
1x PowerSupply AC->DC 24V 8.5A
1x PowerSupply AC->DC HDR15-12 12V 10.2A / 11.3A (variable)
1x Parkside 20/40V 2.5/4A Li-ion battery
1x Parkside 20V 2.5A Li-ion battery
1x Parkside Li-ion battery charger
1x C430 Lipo battery charger
10x D-Cell ELB 10000mAh 1.2V battery
1x D-Cell ELB battery charger
~4 pakete krogljičnih ležajev
2x paket 3mm ball bearings
1x Connector set (razni AWG konektorji 2-4PIN) + klešča + spajalnik
1x FixIT set oridja
4x paket M3 vijakov različnih dolžin od 6 - 45mm
7x paket M2 - M5 insert vijakov
1x Gems Li-po 45C 5000mAh 14.8V 4S1P
1x Li-po battery tester
Raspberry PI 5 8GB, 128GB NVMe SSD set + 90FPS Kamera + LCD
200 €
Oddelek: Mali oglasi
0214 (214) sterling
Hoby Elektronika - Veliki set (RPI, kamere, motorji, vezja, orodja) - 750 EUR
750 €
0359 (359) sterling
