P: Cambridge Audio Azure 350A - integriran stereo ojačevalec
strumf666 ::
Prodam brezhiben ojačevalec z daljinskim upravljalnikom.
Specifikacije:
Power Output .................45 watts (into 8 ohms)
THD (unweighted)....................... 0.02%@1kHz, 80% of rated power / 0.15% 20Hz – 20kHz, 80% of rated power
Inputs.................................... 5 inputs, 1 Tape Input, ¼’’ headphone input, 3.5mm MP3 input
Outputs................................. Speaker A & B outputs, 1 Record Output
Frequency response (-1dB)..........................5Hz – 50kHz
S/N ratio (ref 1W) ................................>92dB (unweighted)
Input Impedances............................... 47k ohms
Max. Power Consumption .....................320W
Bass/Treble controls............................ Shelving, ultimate boost/cut +/-10dB @ 20Hz and +/-6dB @ 20kHz
Dimensions (H x W x D)....................... 86 x 430 x 340mm (3.4 x 16.9 x 13.4’’)
Weight............................................. 6.0kg (13.2lbs)
Cena 180€
Kontakt na peter(pika)stampfel(afna)gmail(pika)com ali ZS
LP,
Peter
Member of OC-Lab Team
http://www.oc-lab.si/
P: Črn moški usnjen plašč s snemljivo podlogo
200 €
Oddelek: Mali oglasi
0219 (219) strumf666
P: Asus Zenpad 8.0 Z380M
30 €
0246 (246) strumf666
P: AKG Y50 slušalke z mikrofonom
30 €
0217 (217) strumf666
P: Fujitsu/FSC Lifebook port replikator/dock in polnilec
30 €
0215 (215) strumf666
P: Napajalni modul in napajalnik za raspberry Pi
15 €
0204 (204) strumf666
P: kable hdmi, dp-hdmi
15 €
0198 (198) strumf666
P: 8Gb ddr4 3200
15 €
0193 (193) strumf666
P: 16Gb ddr4 3600
40 €
0192 (192) strumf666
P: HP USB-C Travel Hub G3 - usb-c hub s hdmi portom
60 €
0202 (202) strumf666
P: Lenovo ThinkCentre M92p
60 €
0230 (230) strumf666
P: HP 255 G10 15.6" r5 7530U 16Gb 512Gb Win 11 Pro - 7l6x8et#abd
330 €
0226 (226) strumf666
200 €
0196 (196) strumf666
30 €
0210 (210) strumf666
30 €
0184 (184) strumf666
180 €
0205 (205) strumf666
