Forum » Mali oglasi » P: Dvosistemski zvočniki Dali Concept 1 (100W) - beli
a4si ::
Prodam par dvosistemskih zvočnikov Dali Concept 1 bele barve. Zraven pride tudi svetlo siva sprednja mrežica - nikoli uporabljena.
Cena: 190 Eur
Slike na: https://www.bolha.com/dvosistemski-zvoc...
This incredibly compact and yet powerful loudspeaker is made for those who need full scale sound in smaller rooms. Fits equally perfect into the living room, the young home or the office where quality is a matter of importance. Place it on a book shelf, hang it on the wall or put it on a speaker stand. No matter where - you will be amazed when you start listening. Consider DALI Concept 1 as rear speaker in a 5.1 surround setup or side speaker in a 7.1 system. Concept 1 is a 2-way bass reflex system, magnetically shielded and with gold plated terminals and integrated wall mount bracket.
Frequency range +/- 3dB (Hz) 62.5 - 22500
Crossover frequencies (Hz) 3000
Sensitivity (2.83 V/1m) 87 dB
Nominal impedance 8 Ω
Maximum SPL 106 dB
Recommended amp. power 25 - 100 W
High frequency driver 1 x 1"
Low frequency driver 1 x 5"
Bass reflex tuning frequency 58.5 Hz
Dimensions (HxWxD) (cm) 31 x 17 x 19
Dimensions (HxWxD) (inch) 12.2 x 6.7 x 7.5
Weight 4 kg (8.8 lb)
Sem iz LJ.
Menjave me ne zanimajo
Več info na ZS
Cena: 190 Eur
Maximum SPL 106 dB
Sem iz LJ.
Več info na ZS
