Eksplozije pozivnikov
dronyx je izjavil:
Pozivniki naj bi bili narejeni v Budimpešti in sicer firma BAC Consulting KFT.
Vir? "trust me, bro"?
redtech je izjavil:
Počasi začenjam razmišljat, da je Izrael zrežiral samo-napad oktobra, da izgleda žrtev :D
Tako tard-politikov, kot jih imamo sedaj v zgodovina ne pomne.
Bolj logicna razlaga je, da si antisemit in zacnes vsak premislek z aksiomom: vse so zidje krivi.
dronyx ::
Vir
The AR-924 pagers used by the militants were manufactured by BAC Consulting KFT, based in Hungary’s capital, according to a statement released Wednesday by Gold Apollo.
Ce trditve drzijo, potem imamo znan model, zanimivo bi bilo najti specs od modela (teza, tip baterije ipd.).
AP pise:
"The AR-924 pager, advertised as being "rugged," contains a rechargeable lithium battery, according to specifications once advertised on Gold Apollo's website before it was apparently taken down Tuesday after the sabotage attack. It could receive texts of up to 100 characters.
It also claimed to have up to 85 days of battery life. That would be crucial in Lebanon, where electricity outages have been common after years of economic collapse. Pagers also run on a different wireless network than mobile phones, making them more resilient in emergencies -- one of the reasons why many hospitals worldwide still rely on them."
Ampak najbrž je bil vdor še kak nivo nižje, pri dobavitelju baterij na primer, ali pa pri ekrančku.
  • spremenil: Utk ()
CiClon ::
D3m je izjavil:
Se pravi niso zadeli samo Hezbolah ampak tudi gasilce, zdravstveno osebje, ipd.
Ce bi slovenska vojska narocila pagerje ali mobilne telefone, bi jih talala slovenskim zdravnikom? Ne.
Ce je Hezbolah "drzava", potem ima te zadeve locene. Pocasi se bo potreba sprijazniti, da so vojska in teroristicna organizija. Ali kot se rece politicno korektno: "gibanje".
Med drugim so tudi politična stranka, ki ima 15 sedežev v libanonskem parlamentu. Itd
Utk je izjavil:
Kako v praksi izgleda tak vohunski vdor? :|
dronyx je izjavil:
redtech je izjavil:
Definitivno so Izraelci vedeli, samo so namerno ignorirali... Kdo je pa "res kriv", je pa nemogoče vprašanje. Vsi so, še najbolj pa razne poteze preteklosti. So kolonjalci v preteklosti namerno naredili določene poteze, ki so naredile regijo zelo nestabilno. Praktično večino držav dol je etnično zelo raznolikih. Združuje jih pa le vera. Vladaj s razdorom. In zato dol deluje izključno diktatura, ker drugače se klani koljejo med sabo.
  • spremenil: Magic1 ()
gruntfürmich je izjavil:
kolikor imam v glavi, 1g exploziva lahko uniči sobo.
če je temu res tako, potem gre tu lahko za 1/10 g exploziva
Kot ponavadi, se motis.
0,1g eksplozije C4 proizvede cca. 650J energije, kar je ekvivalent enemu malo bolj nalozenemu pistolskemu naboju. Ki je energetsko efektivno petarda. Strelno orozje to energijo ucinkovito pretvori v kineticno, pri eksploziji na vse strani je rusilni ucinek znatno manjsi.
Pri eksplozivu sta za delanje skode pomembna dva parametra - kolicina eksploziva in hitrost detonacije. Ter seveda, ali je usmerjena, ali ne.
Glede na posnetke je slo za nekaj gramov do nekaj deset gramov eksploziva, odvisno od tega, kaj so uporabili.
CiClon je izjavil:
D3m je izjavil:
Od cca. 128 sedežev.
|HP EliteBook|R5 6650U|
kamiKaZaA je izjavil:
V medijih potrjeno, da je šlo za nastavljen eksploziv.
Nekateri ameriški mediji, kot sta New York Times in CNN, pišejo, da je šlo za skupno operacijo tajne službe Mosad in izraelskih obrambnih sil (IDF) proti šiitski milici. New York Times je poročal, da so izraelski agenti v pozivnike tajvanskega podjetja Gold Apollo vgradili majhne eksplozivne naprave in sprožilce za detonacijo na daljavo. Pozivnike je razneslo istočasno, ko so vsi naenkrat dobili enako sporočilo, in naj torej ne bi šlo za detonacije zaradi pregrevanja litijskih baterij, kot so navajala uvodna poročila. Večina pozivnikov je bila modela AP924, še dodaja New York Times.
Se na tistem posnetku pri blagajni lepo vidi, da tip pogleda na pozivnik, ker je dobil neko sporočilo in nato v sekundi zadeva eksplodira. Tako hitro se nič ne segreva za nekaj 100°.
kamiKaZaA ::
IL_DIAVOLO je izjavil:
Na točno to sem pomislil, ko sem gledal tisti posnetek. Sporočilo, sekunda, dve in bum. Zato je tudi dosti ljudi oslepelo, ker so ob pisku gledali v pager (sporočilo). En vir domneva, da je bilo nameščeno 3g eksploziva, en drugi pa domneva da 10-20g. Nič še torej ni uradno o kakšni količini eksploziva gre. Je pa skrb vzbujajoče, ker so s tem pokazali, da je lahko vsak od nas tarča. 8-O Kakšen problem bo sedaj par gramov eksploziva namestiti v telefon in potem sprožiti, če ne boš po godu oblasti? :|
BBC pa navaja nekega vojaškega strokovnjaka, ki predvideva, da je bil v ponarejeni elektronski komponenti, ki je bila v vsakem pozivniku, skrito od 10- do 20-gramsko razstrelivo.
Če so že tolk shekali stvar, se je lahko začela napravica gret že prej, potem pa šele pokazala sporočilo in kabum.
  • spremenil: Utk ()
dronyx ::
Mogoče bi moral hezbolah nekaj več denarja investirat v pse za odkrivanje eksploziva? Čeprav piše da je bilo tega eksploziva tako malo, da se ga ni dalo detektirat (3 grame).
mojsterleo ::
Sej strategija tovrstnih napadov je jasna. Poškodovanje večjega števila oseb, in s tem obremenjevanje zdravstvenega sistema, ter povzročanje dvomov v opremo in demoraliziranje.
Tipično za netipične metode vojskovanja. Spomni me npr. na: Exploding ammunition @ Wikipedia
Če bi ta napada izvedel Hezbolah, bi bil to teroristični napad.
Ker ga je Izrael, je to pač normalno...
energetik ::
Utk je izjavil:
Če so lahko vgradili eksploziv, sigurno niso šli v neko nezanesljivo gretje baterije, ampak je ob določenem pozivu čipovje dalo signal na izhod na detonator.
vires in numeris
Napadli so vojsko, ki jih raketira. Da je to teroristicni napad, je smesna ideja. Pojdite s temi neumnostmi smetiti druge teme.
mojsterleo ::
10-20g močnega razstreliva je dovolj, da ti odstreli roko ali nogo.
3g oziroma manj je precej bolj realna ocena. Upoštevaj, da se lahko konkretno poškoduješ ali oslepiš že z navadno petardo.
Npr. PFM-1 mine @ Wikipedia v Ukrajini dela dar mar, kdor stopi gor izgubi obe nogi. Je dosti posnetkov na netu. Mina je čisto majhna, praktično nevidna v travi. Vsebuje 30g tekočega razstreliva.
Šit, sam ta PFM-1 je res nasty. To lahko praktično posejejo bojišče od daleč s tem in naredijo neprehodno za pehoto. Seveda za obe strani. To se verjetno naredi za đabe in naredi neko pokrajino neuporabno za zelo dolgo časa.
Comandante je izjavil:
imaš prav, edino to da gledaš energijo ni relevantno. ker to pri explozivu ni toliko pomembno, ker je pomembno (kot si že rekel) hitrost zgorevanja, ki je do 10.000m/s, kar pomeni da mu nudi sam zrak velik upor, dočim smodnik zgoreva do 2.000m/s in mu zrak ne nudi upora in zato ne 'explodira'.
dronyx ::
To je pretiravanje. Včasih so podstavljali pod avtomobile eksplozive in so koga tudi vrgli v zrak, ko je prižgal avto. To se seveda vedno da. Moraš pa vedeti kdo so tvoji sovražniki. Če delaš proti Izraelu je smiselno imeti napisano oporoko, ker z njimi ni zajebancije. To vedo Iran, Hezbolah, Palestinici in vsi ostali. Če Izrael ne bi bil to kar je, ne bi v tistih krajih nikdar kot država obstal. Njim kaj drugega niti ne preostane.
Židi niso niti neumni in tudi jim ne manjka vneme. To da imajo dobro razvito šolstvo, denar, dostop do najnaprednejših tehnologij in industrije, jih naredi še posebno nevarne za nasprotnike.
dronyx ::
Magic1 je izjavil:
Tu po moje ne gre za neko vnemo, ampak za sposobnost preživetja v zelo sovražnem okolju. Do sedaj so si sovražniki Izraela še vedno polomili zobe in tokrat ne bo po moje nič drugače.
kixs ::
Lahko njim, ko imajo ZDA zadaj...
To bi (verjetno) pomenilo, da drzava kupuje pagerje preko Hezbolaha. To ni problem Izraela.
Hezbolah je v Libanonu parlamentarna stranka.
To, in kako usmerjena je energija ob eksploziji.
Verjetno je bila razlika v jakosti poškodbe tudi precej odvisna od tega, kako je pager bil obrnjen v žepu. Jaz nosim telefon z displejem obrnjenim k nogi, da je bolj zaščiten. Glede na to, da je marsikateremu šel vid, je verjetno butnilo iz displeja ven.
  • spremenil: c3p0 ()
kixs ::
Pa zelo verjetno je bila nacrtovana zakasnitev kaksno sekundo, da lahko vzame pager v roko in pogleda sporocilo. Zato toliko poskodb oci, glave, rok.
mojsterleo je izjavil:
Jaz bi sicer rekel, da bo učinek ravno obraten - še več sovraštva do Izraela, še več fanatičnih borcev Hezbolaha, maščevanje...
Ja, jaz tudi malo dvomim, da bojo to Izraelu spregledali...
KobayashiM ::
Okapi je izjavil:
Ki raketira Izrael. Bi bilo bolje da Izrael povprek raketira cel Libanon?
KobayashiM je izjavil:
Okapi je izjavil:
Bolje bi bilo, da bi z njimi sklenil mirovni sporazum. Ker premagati, v smislu, da ne bodo več sovražniki, jih ne more.
KobayashiM ::
Okapi je izjavil:
Okapi je izjavil:
Mirovni sporazum v stilu da naredijo skupinski harakiri? Stokrat deklarirani cilj Hezbolaha je uničenje Izraela in pobitje vseh Judov...
kamiKaZaA ::
Neuradno jim je uspelo dešifrirat sporočilo. Žal pa večina teh iz Hezbolaha ni znala angleško in je do konca gledalo kot tele na nova vrata v to angleško sporočilo:
blay44 ::
Počasi bomo še prišli do vzroka vgrajenih baterij in prepovedi vzhodne krame na zahodu.
Sam brez te tehnologije se bo tretji, pa drugi svet tudi, pogreznil daleč nazaj?
Je pa zanimivo kako se nobeden ne zgraža nad raketnim sistemi in vojaško podzemno infrastrukturo, finacirano z našo humanitarno pomočjo. Vsi pa napadajo "tehnološke rove"?
Če bi ta "humanitarni" denar porabili za izobraževanje evropske mladine bi sigurno bili dve do tri stopnje tehnološko bolj razviti. Je pa res, da se bi/bo tretji svet upiral. Moraš biti kar brihten, da držiš neko razmerje oziroma, mejo.
Se mi pa zdi, da vatli niso enaki?
kamiKaZaA ::
Tako kot je nas strah vsakega bradatega z nahrbtnikom v bližini, da ne izreče magičnih dveh besed, tako bo sedaj vse na bližnjem vzhodu strah zahodne tehnologije.
Okapi je izjavil:
Pa hkrati najmocnejsa vojska v drzavi. Veliko mocnejsa kot uradna vojska.
Okapi je izjavil:
Mirovnega sporazuma noce skleniti Libanon (ki je failed state). Izrael se trudi skleniti mirovni sporazum z vsemi okoliskimi drzavami. Realno je edina ogrozena drzava na tistem obmocju Izrael. Oni se borijo za dolgorocni obstoj.
bm1973 je izjavil:
Ja, Hezbolah je zaostala islamisticna teroristična organizacija, Izrael pa demokratična, civilizirana in tehnološko napredna Zahodna država.
Prvim je cilj poriniti druge v morje. Drugim je cilj preziveti. Bolj cisto bi tezko bilo. Ko se boris za prezivetje nimas dosti manevrskega prostora pri izbiri metod, ce imas opravka z zblaznelimi islamisti.
Ja, če pobiješ ne vem koliko milijon od leta 1948, se res počutiš ogroženega...
Drugače je pa Izrael tam tampon cona, da se Arabci ne silijo preveč na zahod... Po eni teoriji... Zato imajo tudi polno podporo ZDA in EU...
johnnyyy ::
Utk je izjavil:
V praksi imaš toliko faktorjev, da težko rečeš kje je najšibkejši člen. Na koncu se lahko zgodi, da je proizvajalcu pozivnikov nek "novi poštar prinesel baterije". Ali pa je prišlo do nadgradnje pozivnikov ko je bila pošiljka na poti iz Madžarske.
Recimo sam poznam primer, ko je imela firma rok za naročilo in nekih procesorjev na trgu ni bilo in so jih kupili na Kitajskem - prazne, brez silicija. BP lahko nek Mosad pri dobavitelju nabavi precejšnjo količino določenih komponent in dobavitelj je prisiljen iskati alternative. Pa večina materiala gre čez takšna in drugačna skladišča in pitaj boga kaj se tam dogaja.
In pagerji gredo preko Slovenije na ladjo, od tam pa na bližnji vzhod. A je kaka naša firma imela veliko pagerjev za predelat? :))
kixs ::
Delali so nadgradnjo z "vecjo" baterijo.
johnnyyy ::
WizzardOfOZ je izjavil:
Da se ne bo javil kakšen študent, ki je to delal za par €/h, potem pa je šel v LJ protestirat proti Izraelu :D.
floyd1 ::
bm1973 je izjavil:
Zelo ozko gledanje je to. Jaz vem samo, da je tam situacija precej bolj zakomplicirana in manj črno-bela, kot jo poizkušate nekateri tu predstaviti. Z mirno rešitvijo očitno noče nihče več tvegati (zadnjega takega so izraelski ekstremisti takoj spravili v večna lovišča, čeprav je bil njihov, demokratično izvoljen....), trenutna situacija pa paše tako retardirancem v izraelskem vodstvu kot tistim v hezbolahu. Sicer pa v "demokratični in civilizirani" družbi ne podtakneš tisoče eksplozivnih naprav in se požvižgaš na kolateralno škodo. V tem pogledu so povsem enaki kot rezalci glav in samomorilski bombaši.
dronyx ::
Zdaj so lahko rusi dobili kakšno idejo. Odprejo na zahodu firmo za popravilo Himarsov, pošljejo Ukrajincem sporočilo o vpoklicu zaradi serijske napake, potem pa vgradijo kakšen peklenski stroj. Se mi zdi da bodo sedaj dobaviteljske verige kar nastradale, saj bodo nekaj časa vsi paranoični, dokler se tole ne pozabi.
floyd1 je izjavil:
Niti ne. Zadeva je precej enostavna. Vecina narodov, ver ipd. bi sprejeli izgubo vojne. Trenutno se zdi, da Arabci premorejo dovolj verskega fundamentalizma, da bodo raje pobili lastne otroke, kot priznali poraz. Tudi Tamili so se tudi dolgo borili, nato pa le priznali poraz.
Smesno je, da bi imeli Palestinci povsem funkcionalno drzavo, ce bi sprejeli poraz leta 1967, da ne omenimo stanja leta 1948.
Ampak ja, smo sli offtopic. My bad.
NuMaN ::
Ja, že palestinski zarodki so teroristična vojska potencialno ...
Malce si se izpel.
Pustimo to. Mene čudi, da niso pri nabavi vsaj enega razstavili na prafaktorje in ga temeljito pregledali.
Posebej, ker to ni bil prvi tovrstni napad.
  • spremenil: NuMaN ()
Spura ::
Danes lahko pager z enim zelo majhnim cipom implementiras, tako da ostaja veliko prostora v ohisju za kak eksploziv. Dokler dodatna teza ni velika se ne opazi.
Vseeno je Hezbolah pagerje ze nabavljal. Tudi, ce so z novo posiljko dobili izboljsan (heh) model, bi pricakoval da so kaksnega odprli in pogledali, vsaj na hitro.
Ce je Hezbolah pameten, bo pagerje uporabljal se naprej. Le da bodo sedaj preverjali robo. Vse ostalo jim bo zakompliciralo komunikacijo. Je pa res, da bo nekaj tisoc ljudi sedaj imelo PTSD takoj, ko bo kaj zapiskalo.
s1m0n ::
Kdo pa pravi, da jih niso vizualno pregledali? Eksploziv lepo skriješ v samo celico/baterijo na koncu ne zgleda nič bolj sumljivo kot sama baterija...
s1m0n je izjavil:
Tudi sam mislim, da so naredili custom pouch celice. To ni nek baubau, na kitajskem je malo morje firm ki se s tem bavijo. Custom orodje za poljubno obliko celice je par jurijev. Pac so vzeli ploscico eksploziva in navili okoli litijevo baterijo. Nato pa vse skupaj se 1x zavili v folijo ter opremili z oznakami. Morda je proizvajalec vedel, kaj dela, morda ne.
Taksno "baterijo" lahko razrezes, pa ni nujno, da ti bo kaj sumljivo. Razen ce ves, kako tocno more v prerezu izgledati. Lahko jo tudi skuris, ne bo eksplodirala. Potrebuje detonator (razen ce so uporabili inicialni eksploziv, kar pa je skoraj nemogoce, ker je prenevarno).
