Predsedniška debata Trump vs Biden
DarwiN je izjavil:
auč
To ni njeno avtorsko delo.
Je pa povzetek dela njenega govora:
https://x.com/KamalaHQ/status/181551287...
anon17 je izjavil:
Vešda, “ona je glupa”. A imamo kakšne objektivne kriterije ali zgolj ker je ženska, temnopolta in demokratinja?
Obramba na nivoju Stojmenove, "napadate me ker sem čefurka"? Bedastih izjav Kamale imaš na netu za zapolnit popoldne, celo knjiga obstaja na to temo.
Sledi le par cvetk. Za pravi efekt pa še moraš dodat njen random smeh na poljubna mesta:
“So Ukraine is a country in Europe. It exists next to another country called Russia. Russia is a bigger country. Russia is a powerful country. Russia decided to invade a smaller country called Ukraine. So, basically, that’s wrong.”
"The governor and I, we were all doing a tour of the library here and talking about the significance of the passage of time, right, the significance of the passage of time. So, when you think about it, there is great significance to the passage of time in terms of what we need to do to lay these wires. What we need to do to create these jobs. And there is such great significance to the passage of time when we think about a day in the life of our children."
"We will work together, and continue to work together, to address these issues…and to work together as we continue to work, operating from the new norms, rules, and agreements, that we will convene to work together...we will work on this together."
"It is time for us to do what we have been doing. And that time is every day. Every day it is time for us to agree that there are things and tools that are available to us to slow this thing down.”
DarwiN je izjavil:
auč
Ce se ti dvigne zaradi taksne retorike, imas problem.
Seciranje njenih izjav itak ni smiselno. Za vsako bedarijo, ki jo je izrekla, jih lahko pri Trumpu najdemo 10.
Njen problem je:
- nima karizme
- vsi vemo, da je podpredsednica postala zaradi barve koze
Zmajc je izjavil:
Par postov spodaj pa zanimiv posnetek na temo njene sposobnosti in nepokvarjenosti:
https://x.com/DefiyantlyFree/status/181...
Oranžni & co. bodo njeno naklonjenost k zapiranju črnskih mladeničev spretno izrabili.
Ja, ker republikanski tozilci, pa se nikoli niso zaprli crnca, a? :))
So oni predsedniški kandidati? Ko bodo in so to počeli, bo to problem zanje.
Fair enough.
Se potem strinjas, da je problem republikancev, da je Trump spodbujal prevrat, nagovarjal k volilni prevari in da je to problem? Bos konsistenten? Ali so to "obrobni" problemi?
Nikoli nisem bil Trumpov fan in nikoli ne bom. Zaradi mene lahko gre tudi sedet.
Ali pa moram po tvojem enega malo "šinfat" in nato še malo drugega, da bo uravnoteženo?
RdecTelefon je izjavil:
Btw.. ognjena kača, kaj imaš proti babncam? Pa ne nanaša se samo na to tvojo izjavo zgoraj.
Popolnoma in absolutno nič.
Edino take, ki pridejo na položaj zgolj in samo zato, ker imajo fuflje se mi pa gnusijo v dno duše. Do takih pa nimam ne potrpljenja ne spoštovanja.
FireSnake je izjavil:
To je talking point, ki ga uporabijo proti čisto vsaki ženski, ki koga ogroža. Moški imajo lahko 500 ljubic ženske pa je takoj "fufljo nastavila". :D
anon17 ::
c3p0 je izjavil:
anon17 je izjavil:
Razumem, to se ne more primerjat z umotvori oranžnega dementnega ljubitelja plenic:
“I just grab them by the pussy”
“Ted Cruze’s father helped to kill JFK”
“Put UV lights and bleach into people to kill the virus”
To sploh ni primerljivo, Trump je nasral toliko neumnosti v enem dnevu, kot jih naserje povprečni politik v celi karieri.
Trump veliko govori(-či), se hitro odzove v neki situaciji, je populist, bi lahko rekel, da možgani ne dohajajo jezika.
Kamala govori počasneje, malo zmedeno, naivno, glede možganov podobno.
Usa volivec ima zahtevno nalogo koga izbrati, slabo ali slabšo varianto.
MadMicka ::
Dej razlozi fikus, za Trumpa vemo, da je slaba izbira, ker unicuje demokracijo (tako da napada sredstvq javnega obvescanja, sodisca, tozilce, vse, ki niso z njim), da unicuje zaveznistva npr z EU in rusi kolektivno obrambo Zahoda - NATO, se pa dobrika diktaturam ala Severna Koreja, Kitajska, itd. Katera ravnanja in stalisca Kamila Harris pa so tako zelo problematicna?
MadMicka je izjavil:
Ni nastrojena pro-rusko in anti-NATU/EU. To je ta njega no-go. :D
Zmajc spet provociraš!
MadMicka, kaže da si proti Trumpu (tvoja odločitev) in podpiraš Kamalo (tudi OK).
Jaz sem napisal, kaj si mislim o obeh, če te pa kaj napisanega moti, pa lahko debatirava. Vidim, da si napisal nekaj stvari proti Trumpu, OK tvoje mnjenje, me ne gane. Kamala tudi ni nek biser od kandidatke na volitvah. Dvomim v njeno sposobnost vodenja države (sicer vsakemu predsedniku svetujejo ljudje iz ozadja), dvomim, da je sposobna odgovarjati na naključna, nepotrjena novinarska vprašanja.
Eden bolj zgrešenih "odgovorov" je tukaj že objavljen, zakaj je RU kriva za vojno v UA (da se ne boste vpiknili RU je napadla UA in je začela vojno), ... in še kar nekaj cvetk. Pri tem se ji vidi, da o mnogih stvareh nima pojma, zato takšni diletantski odgovori.
Se pravi čakaš, da ti fake news mediji postrežejo dezinformacije o Kamali.. Got it..
Spolno nadlegovala moške; "dokazi" o podkupljivosti ko je delovala kot tožilka; kot podpredsednica si je napolnila žepe; njen sin je peder; foter je sodeloval pri atentatu na JFKja; ima tudi sama neozdravljivo bolezen in so ji šteti dnevi; dokazi o tem, kako sovraži belo raso; Hussein Obama je njen sugar daddy; ima majhno plačo, pa vendar si lasti 15 nepremičnin; itd, itd. 8-)
  • spremenil: DarwiN ()
anon17 ::
hahahaha, go Kamala, grab this pussy by the pussy:
Konc je, dečki. Trump si niti soočit ne bo upal z njo, ker je strahopetec. In ker ga Kamala ima za zajtrk - no, do takrat, ko dementnemu Donnyu zamenjajo pleničko in podrejo kupčka, bo že proti malici.
Tole je teleprompter oz. pripravljen tekst. Podobno je z odzivi. V zivo bo bolj zanimivo.
Saj pravim, Trump je live nepremagljiv.
c3p0 je izjavil:
Pozabljas, da mora na koncu (ameriski) volivec nekoga obkroziti.
lynxslo5 ::
anon17 je izjavil:
A imaš kakšen dokaz, da se Trump ne bo upal soočiti z njo? Demokratski kandidati se na TV upajo soočiti z nasprotnikom vedno samo na TV postajah kjer jim v naprej pripravijo vprašanja. Kamala bo seveda prišla na soočenje s Trumpom na CNN. Na Foxnews pa seveda ne bo upala priti.
Sicer pa zdaj vidimo kje levičarji črpate svoje vire. Od Židovskih vlogerjev ala Cohen.
IL_DIAVOLO je izjavil:
A to je kaksna nova ruska propagandna floskula? V stilu 'Rusija je nepremagljiva'? Trump je v debati seveda premagljiv, in so ga tudi v zivo ze osmesili.
anon17 ::
lynxslo5 je izjavil:
anon17 je izjavil:
O ne, “Židovskih vlogerjev”, zveniš kot kakšen Lavrov z “anglosaksonskimi zarotami proti Slovanom”. Dementni neizobraženi butelj nima za burek proti Kamali. Volijo ga pretežno zgolj najbolj zarukani hillbillyi.
  • spremenil: anon17 ()
Ne vem no, intelektualni domet Kamale je že po načinu govora svetlobna leta pred Donaldom. Zna se pa zgodit, da bo levica (sj vem, wtf je levica v Ameriki) mislila, da je boj itak dobljen, pa se jim ne bo ljubilo na volišča, pa bo potem Donald pobral glasove. Vse je možno.
lynxslo5 ::
anon17 je izjavil:
anon17 je izjavil:
Trumpa bo volil beli delavski razred in lahko je ponosen na to. Ne vem pa zakaj bi bil glas gasilca ali pa delavca v Fordovi tovarni manj vreden od glasu nekega Židovskega bogataša iz Hollywooda, ki bo volil Kamalo Harris.
  • spremenil: lynxslo5 ()
anon17 ::
Sheteentz je izjavil:
Mislim, da se bo demokratska stran vrgla ob tla, da čim več ljudi spravijo na volitve. Ker če bi oranžni dementni prišel na oblast, je konec z demokracijo in svobodo za nekaj časa, kar se bi odrazilo tudi na Evropo in večino ostalega sveta.
anon17 je izjavil:
anon17 je izjavil:
Ne vem zakaj bi katerikoli delavec volil za tega parazita, razen s povdarkom na “beli” - kot rasistični. Ja, KKKjevci pa volijo naciste. Jebiga, edino kar so v življenju dosegli je, da so se rodili z belo kožo, za kar pa itak nimajo nobenih zaslug. Treba druge malo potlačit, da si ohranijo nekaj privilegijev, ki “jim pripada” na tej osnovi. Parazitska logika, kaj čmo.
Ne pozabin na ženske, ki so se jim republikanci zamerili s prepovedjo splava.
Trump ima tradicjonalno največ podpore med razočaranimi moškimi.
Sicer pa ena kalifornija bo skoraj zagotovo za demokrate en teksas pa za republikance.
MadMicka ::
Prav fikus, Kamala je falila, ko je rekla, da je Rusija kriva za vojno v Ukrajini. V resnici je Zahod prisilil Rusijo, da je napadla Ukrajino. Cudno sicer, da Rusija ni napadla se Finske, ki je bila do pred kratkim nevtralna, ampak ok, sej jo lahko se vedno napade, ker je pac jasno, da NATO se ne sme priblizati mejam Rusije, ceprav sta Rusija in ZDA sosedi. Povej se, katere so ostale cvetke Kamale, recimo vsaj dve...
lynxslo5 ::
anon17 je izjavil:
anon17 je izjavil:
anon17 je izjavil:
A misliš, da si napreden in pameten, ko sovražiš samega sebe, ker si belec. Dobro so ti židovski vlogerji, katere spremljaš, sprali možgane.
V ZDA pa danes nimaš nobenih privilegijev, če si belec. Prav nasprotno. Imajo na stotine zakonov, ki diskriminirajo belce in favorizirajo črnce kot je Kamala.
anon17 ::
fikusu ni všeč Kamalin slog, mu je pa ok, da Trump govori stvari, ki so “batshit crazy”. Podrobnosti so važne…:)
MadMicka ::
lynxslo5, ne vem, a ti mogoce ves. a so Zidje belci, ko pravis, da silijo belce, da se soveazijo, ker so belci? Pa povej se a Kamala je crnka, ker je pol Indijka? A v Indiji so prebivalci crnci?
anon17 ::
Zakaj bi sovražil kogar koli? Ne maram nacistov - ne glede na barvo njihove kože. V ZDA so to ponavadi KKKjevci, ki povdarjajo večvrednost arijsk...bele rase. Kreteni torej. In nikoli ne bom podpiral kretenov.
Seveda jih imaš. Privilegiji, ki izhajajo iz generacij kopičenja bogastva, kar je belcem bilo omogočeno, temnopoltim Američanom pa onemogočeno. Belci avtomatsko štartajo iz boljšega položaja v državi, kjer so bili temnopolti prebivalci stoletja zatirani in stigmatizirani.
Tiste malenkosti, ki jim jih dajo, da bi vsaj malo popravili situacijo, niso vredne omembe - razen luzerjem, ki niso sposobni narediti ničesar iz sebe in svojo uspešnost definirajo glede na to, če je kdo še na slabšem od njih in torej potrebujejo nekoga - najboljše, če je vizuelno drugačen od njih - da mu gre slabše kot njim.
lynxslo5 ::
Aškenazi Židje, ki obvladujejo Ameriko niso belci. Oni so turško pleme, ki je v 8. stoletju sprejelo judovsko religijo. BTW, tudi mož od Kamale je aškenazi žid Douglas Emhoff.
Ali je pa Kamala črnka, pa ne vem. Ne vem, kako se ona identificira na popisu prebivalcev. Vem pa, da med črnci v ZDA ni ravno priljubljena.
Ameriko še vedno obvladujeje pretežno wasp.
A zato je leta 2008 Obama na volitvah demokratov premagal Hillary?
Ameriko nobena skupina ne obvladuje popolnoma.
kuglvinkl ::
Intelektualni domet? Ne razumem. Iz katerih podatkovnih tock crpas, ki bi kazale na to, da ima Kamala nek velik intelektualni domet?
Sej vemo da za nekatere je "uspešna ženska=sex za napredovanje", sam to je samo vaš problem. Drugi vemo, da pametne ženske niso neka mitološka, neobstoječa bitja.
Ps, da vas na drugi strani ne moti donny "if you are on a sinking ev boat and there's a shark 10 yards away, what do you do", pa tudi veliko pove.
  • spremenil: TESKAn ()
MadMicka ::
lynxslo5, se pravi, turska plemena niso belci, ampak so kaj?
pripet 30s video
https://x.com/michaeldweiss/status/1815...
Trump has Palin'd himself. Vance has no charisma, is easily mockable and will become a laughing stock in short order.
This is what happens when a bunch of South African tech bros try to grow their own redneck in a lab in California.
anon17 ::
Kaj človek vse ne prebere tukaj, manjka samo še to, da mi en magovc napiše, da Iranci niso arijci :)
Jaz bi jo definiral kot zelo sposobno in pametno osebo, ki bo sfaširala še enega kriminalca. Sicer dementnega, ampak vseeno kriminalca.
  • predlagalo izbris: Kayzon ()
@kamalina barva kože, mama:
Shyamala Gopalan @ Wikipedia
https://x.com/ibramxk/status/1627404987...
In 1958, Shyamala Gopalan arrived in the US from India to pursue her graduate studies in nutrition & endocrinology at Thind's alma mater: UC Berkeley. Gopalan earned her PhD six years later in the 1964. It was the same year she gave birth to a daughter and named her Kamala.
ata:
Donald J. Harris @ Wikipedia
Donald Jasper Harris, OM (born August 23, 1938) is a Jamaican and American economist and professor emeritus at Stanford University, known for applying post-Keynesian ideas to development economics.[1]
ZDA so talilnica narodov.
anon17 ::
Očitno Biden ni edini, ki je dementen.
Ne, zdaj je od obeh kandidatov to samo še Donny.
Donald is her daddy, torej..
Pa ne ta Donald spodaj... Če je že govora o intelektualcih. :D
MadMicka ::
paradajzos, edini arijci so crnci, tisti, ki se niso mesali. To so edini, ki imajo samo clovesko (homo sapiens sapiens)
dnk, ostali, npr. belci imamo primesi dnk neardetalcev, itd.
anon17 ::
ata:
To ni nič, foter od Donnya je bil tip, ki je lastnega sina spravil do samomora, metal iz stanovanj družine z otroci in katerega foter je po pobegu iz Nemčije, da bi se izognil služenju vojske, na divjem zahodu fural svoj bordel.
Donny ima res ugleden rodovnik in izhaja iz zelo intelektualnega in kulturnega miljeja.
Kamala pa, pih, ona ni bela. Ziher je glupa, ane trumptardi?
/s
Pa ne mi zdaj uničevat iluzij, te teorije bo treba prepovedat!
Pol je tudi Kamala pravi klise? Crn oce, ki je zapustil druzino?
Vsa ta obmetavanja z drekom, so brezpredmetna.
lynxslo5 ::
anon17 je izjavil:
KKK je paravojaška organizacija, ki jo je po koncu državljanske vojne ustanovila Demokratska stranka, da bi še naprej ustrahovala črnce na jugu. Res so čudna pota Demokratske stranke. Do 70ih so furali segregacijo in KKK, danes so pa kao progresivna socialistična stranka. Sicer pa je KKK danes v ZDA povsem brez vpliva in marginalen in obstaja samo še v kakšnem hollywoodskem filmu.
anon17 je izjavil:
Tole kar si napisal je kot iz kakšnega kolokvija gender studies iz San Francisca. Open society bi te pa lahko zaposlil v svoji podružnici v Ljubljani.
Daj mi razloži zakaj so Azijski Američani, ki so v ZDA prišli revni, sedaj tako uspešni v ZDA. Zakaj oni lahko premagujejo belce na marsikaterem ekonomskem prodročju, če je v ZDA še vedno rasizem v korist belcev? Zakaj Azijci zmorejo, črnci pa ne zmorejo? Ali je mogoče kriva kultura, delovne navade, vzgoja otrok, ne pa večno izgovarjanje na rasizem v ZDA. Svetujem ti, da prebereš še kakšen članek od Thomasa Sowella, ki je visoko izobražen Afro Američan, ne pa da črpaš svoje znanje od raznih Tyler Cohenov.
Nekatere sektorje gospodarstva kot je recimo Walmart res še vedno obvladujejo waspi, vendar njihov splošen vpliv na Ameriko hitro pada že od konca druge svetovne vojne in so jih sedaj izpodrinili aškenazi židi, ki obvladujejo kompleten finančni sistem, vključno z ameriško centralno banko, ki je zasebna banka in je v lasti velikih židovskih bank.
Večino medijev v ZDA so ustanovili waspi, danes so pa vsi v lasti židov. V politiki pa 90% donacij Demokratski stranki prihaja od židovskih milijarderjev, pri Republikanski stranki pa 50% donacij. V ZDA je Demokratska stranka vedno bila večja in močnejša, in kdor obvladije Demokratsko stranko obvladuje Ameriko.
Vsi vemo, da so turška plemena aziatska.
anon17 ::
Demokratska stranka je danes povsem nekaj drugega, kot je bila, ane. KKK pa samo čaka, da Trump in njegov kult pride na oblast in bo spet dvignil svojo nagnusno glavo.
Kaj imajo gender studies z rasizmom? Nisem ravno na tekočem s temo gender studies, ker glede na procent ljudi, ki se jih to dotika, je fenomen zanemarljiv in ima zanemarljiv učinek - razen v glavah butljev, ki ne zmorejo poleg življenskih izkušenj še procentnega računa.
Daj mi razloži, zakaj so vzhodni Nemci revnejši od zahodnih Nemcev. Isti DNK. Verjetno ne boš razumel primerjave in tudi če jo boš, ne boš sposoben priznati svoje zmote. Trump kult pač.
Šit, moram par svojih znancev prečekirat, če niso črnci. Sem do zdaj mislil, da so klasik Slovenci.
25 / 94
Kognitivne sposbnosti Josepha Bidena (strani: 1 2 )
Oddelek: Problemi človeštva
6819062 (16241) BigWhale
Biden ukazal prvi zračni napad v Siriji (strani: 1 2 3 4 )
19954064 (45862) ajdov2
