Novice » Procesorji » Težave s pregrevanjem Ryzen 7000X3D
Torej so "Proizvajalci" prodajali zlate matične plošče, ki so zadovolile minimalno specifikacijo "na električnem nivoju", ki jo zahteva DDR5, reševali so pa z višjo voltažo.
Bilo bi dobro videti katere rame so plošče podpiral na začetku in koliko so bile voltaže.
Buggy ::
SOC volaze ze na AM4 nabijajo plate obcutno previsoko in s tem nepotrebno grejejo CPU. Sam sem jo na 5800X3D fiksiral na 1100mV, pa se bi sla nizje stable, nakljub -30 na vseh core-ih preko PBO2 tunerja.
https://www.reddit.com/r/Amd/comments/1...
my 7800x3d died after first boot
SPEC:
CPU: 7800x3d
MB: (GIGABYTE) B650M AORUS ELITE AX(REV 1.0) (F2 bios, tried to upgrade to F5 in first boot)
No OC. No EXPO. Factory settings.
SSD: Samsung 990 pro 1T
Memory: G.SKILL Trident Z5 Neo Series AMD EXPO 32GB(F5-6000J3038F16GX2-TZ5N)
Power: Corsair AX850
CPU cooler: Asus rog ryujin 240
GPU: ROG Strix 4090 OC Edition
After installing all the components, the computer was turned on and entered the BIOS. The system passed the self-check by successfully recognizing the 7800x3d.
The initial version of the BIOS displayed as F2, which was then upgraded to the latest version F5a (03/23/2023) using Qflash. The upgrade reached 100%, but then the screen went black and the computer shut down. I assumed the computer would automatically restart, but it did not.
slika cpu, mb
https://preview.redd.it/megathread-for-...
SPEC:
CPU: 7800x3d
slika cpu, mb
- spremenilo: sbawe64 ()
AM4 s tem nima nima nikršnih problemov in MSI plata laufam defult DDR4 3800 CL 16 ob izidu 5800X3D. Razlika v porabi je pa minimalna, ergo nesmiselno.
Soc Voltage (SVI 2 TFN) 1.038V
CPU Core VDI 1.3V
| » | AMD najavil procesorje Ryzen 7000 (strani: 1 2 3 )Oddelek: Novice / Procesorji | 28643 (12049) | D3m |
| » | Težave s pregrevanjem Ryzen 7000X3D (strani: 1 2 )Oddelek: Novice / Procesorji | 14904 (12306) | Mr.B |
| » | Procesorji Ryzen 7000 prispejo konec septembra (strani: 1 2 3 )Oddelek: Novice / Procesorji | 25041 (17653) | FlyingBee |
| » | AMDjevi procesorji Ryzen 5000 pridejo po Intelov skalp 5. novembra (strani: 1 2 3 4 )Oddelek: Novice / Procesorji | 45832 (36137) | GenZNPC |
