Forum » Loža » Ukrajina Part IV
Ukrajina Part IV
VladarP ::
Comandante je izjavil:
Pravkar sem si privoscil ruske ovsene kosmice z domacim kozjim mlekom.
Dobro zate, ce je to najboljse kar Vzhod premore.
Osebno bom raje pohorski ramsteak za kosilo, ampak vsakemu svoje.
Za kosilo žena dela divjega lososa, ko pridem iz baze
Akhmat sila
l0g1t3ch ::
Za kosilo žena dela divjega lososa, ko pridem iz baze![]()
A to je kraj kjer fukate kozle???
Zanimivo poimenovanje "baza"
VladarP ::
Rusofobni nacisti vas pridem ponovno jebat v vase prazne glave v ponedeljek, mi ne pada na pamet, da vikend prezivim z retardiranimi nacisti na forumu. Zakljucim delovne obveznosti, delavce posljem domov, kosilo, nabasemo pajerota in kampirat in plavat v Sistiano.
Ajde Bog praznoglave lepinje
Akhmat sila
- spremenilo: VladarP ()
primoz4p ::
V tej temi je bilo že vse, tudi covid. Čas je da dodam še Chemtrails.
The Spanish Meteorological Agency has confessed that Spain is being sprayed with lead dioxide, silver iodide and diatomite
Spain was the first Western government to officially include 'chemtrail' in its Official Gazette. The Spanish Ministry of Health authorized the NBC (Nuclear, Biological and Chemical) units of the Armed Forces and also the UME to use biocides from the air. A month after the state of alarm was imposed, the Executive justified in the BOE that this technique is one of the "most effective" against the coronavirus since with "nebulization, thermonebulization and micronebulization techniques, all surfaces are reached with speed".
l0g1t3ch ::
Fukat kozle?
tomlin ::
Poglej najprej sskj "deskreditirati"
, potem pa pojej dva fruteka, še bolje tri, za zdravje
BTW,Larry Elliott, avtor članka je velik nasprotnik politike EU, bil je agitator za brexit, s tega zornega kota
se bere ta njegov "privoščljiv prispevek". Ima pa, kar se podatkov tiče in njih razlage precej prav, samo precej
skozi očala anti EU-zagovornika.
Russia is winning the economic war - and Putin is no closer to withdrawing troops
dobr devajo te sankcije matr![]()
Kaj če bi dal konstruktiven komentar, ne pa da znaš samo srati po avtorju in ga s tem poskusiti deskreditirati!
l0g1t3ch ::
P. S.
Pajero pomeni "drkač"
Kako primeren avto voziš
P. P. S
Samo reveži vozijo ta jajca.
P. P. S
- spremenilo: l0g1t3ch ()
Zmanjkalo mi kaviarja, moram it kupit. Ce je kdo preskocil o mojih prehranjevalnih navadah, rad jem Kamcatka kaviar. Cena ni ovira.
Ruska trgovina na bavarcu Hlebsol:
https://hlebosol.eu/sl/eshop/kaviar-los...
U nice, hvala za tole.
Z veseljem. Priporocam tudi drugim, da podprejo ruske trgovine v Sloveniji
Ja, samo je treba paziti, precej izdelkov imajo tudi Ukrajinskih.
Ja pa iz Gruzije. Jaz kupujem samo ruske in armenske produkte v ruskih trgovinah. Pravkar sem si privoscil ruske ovsene kosmice z domacim kozjim mlekom.
Kozjim mlekom? Vidim,da koze uporabljaš na več načinov:D lepo.
Poglej najprej sskj "deskreditirati", potem pa pojej dva fruteka, še bolje tri, za zdravje
Tomlin, si užaljen, ker sem ti nastavil ogledalo?!
Kot kaže pa argumentov tudi ne premoreš!
TezkoDihanje ::
Lahko nehate s tem sranjem, da Rusija zmaguje ekonomsko vojno beboti.
pobrani davki od prodaje
april 2021 : 740mrd rubljev
april 2022 : 400mrd rubljev
vir
2:20
Čisto proteini brez sladkorja in maščobe. Idealno za vse, ki redno telovadimo.
https://ruskatrgovina.si/index.php?id_p...
Naj vas OH ne zavede. OH je gorivo za telo.
V vsakem Hofru jih dobiš po 55 centov za pol kg.
Samo zgleda imaš raje obsevane iz Čeljabinska.
https://www.google.com/search?q=UVELKA
Hočeš postat Hulk?
Child trafficking was discovered between a Ukrainian clinic in Kharkiv and a Ukrainian clinic based in Prague, Czech Republic.
"Three dozen cases of children sold to homosexuals through Prague to #Norway, #Germany, #Greece, #Bulgaria, #US, #China"
#Ukraine
https://twitter.com/O_Apologitis/status...
#Ukraine
|HP EliteBook|R5 6650U|
UkrFTW! ::
Moram reči da jaz EU čedalje težje razumem. Odločili smo (so) se za ekonomsko in proxy vojno z rusijo, zaradi invazije na Ukrajino. V tem priemru bi morali po moje takoj sprejeti tudi zavezujočo direktivo za vse članice EU, po kateri je vsaj prekršek, če že ne kaznivo dejanje vsako simpatiziranje in poveličevanje ruskih vojaških dosežkov. Ko si z nekom v vojni je zadnje kar si želiš, da sovražnik zganja propagando in zaneti notranje spore. Ampak EU se obnaša kot kokoš brez glave. Ali pa še ne razumejo, da smo v vojni?
Torej ti si v vojni in bi se obracunaval z nasprotno mislecimi raje tako povej. Ce si ti v vojni, si tudi legitimna tarca.
Skratka, v posebni operaciji, ki ni vojna, ni legitimnih tarč. Dobro, da si potrdil, da ste rusi fašisti posebne kozjejebe sorte.
tomlin ::
PUTIN SE JE ZAKALKULIRAL, NI ČUDNO DA JE VES ZABUHEL, "ZJEBANO PARKINSONSKI", IN IZGLEDA KOT V TERMINALNI FAZI
RAKA. KDO NE BI BIL PODOBNO "SFUKAN" ČE BI DOŽIVEL TAK DEBAKEL
Zdelo se je, da vodja Kremlja igra na srečo, da bo Zelensky pobegnil iz prestolnice, podobno kot je predsednik
Afganistana , zapustil Kabul le nekaj mesecev prej, in da se bo ogorčenje Zahoda umirilo, čeprav z začasno
bolečino novih sankcij.
100 dni pozneje so načrti, ki jih je Putin morda imel za parado zmage v Kijevu, zadržani za nedoločen čas.
Ukrajinska morala ni padla. Ukrajinske čete, opremljene s sodobnim protitankovskim orožjem, ki so ga dostavile
ZDA in njihovi zavezniki, so uničile ruske oklepne kolone; Ukrajinske rakete so potopile križarko z vodenimi
raketami Moskva , ponos ruske črnomorske flote; in ukrajinska letala so kljub vsemu ostala v zraku.
Konec marca je ruska vojska začela umikati svoje pretepene vojake iz okolice ukrajinske prestolnice , češ da so
se osredotočili na zavzetje vzhodnega Donbasa v državi. Tri mesece po svoji invaziji se zdi, da Rusija ne cilja
več na zmagovito vojno v Ukrajini.
Ukrajinci so uspeli pobiti ruske generale z osupljivo hitrostjo; Moskva je bila po prvotnem neredu prisiljena
reorganizirati svoje vojaško poveljstvo ; in ruske žrtve , ne glede na uradne številke, so šokantno visoke.
https://edition.cnn.com/2022/06/02/euro...
LightBit ::
PacificBlue je izjavil:
Leta 2016, so zacele Zda oboroževati Ukrajino za boj proti Rusiji, hkrati pa zacele financirat program biološke raziskav, v sklopu katerih so v Ukraijo prenesli ogromno jedrskega materiala. Rafael Grossi iz Argentine, ki vodi mednarodno agencijo za atomsko energijo je 25. maja na forumu v Davosu dejal, da je Ukrajina v Zaporozji shranila 30 ton plutonija in 40 obogatenega urana in da se njegova afencija sprasuje kaj se je z vso to kolicino snovi zgodilo.
Spomnimo, da 26 februarja je jedrsko elektrarno zavzela ruska vojska, kasneje je v bliznjem laboratoriju izbruhnil pozar. Takrat so ruske enote zacele prenasati jedrske snovi, ukrajnske enote pa so jih napadle.
Zanimivo pri tem je, da bi Ukrajina shranjevala take kolicivne jedrskih snovi, glede na to, da so se po sovjetskem sporazumu morali odpovedati vsemu atomskim zalogam it takratne dobe. Od kod je torej prisel ta material?
In zakaj je te podatke prej organizacija za atomsko energijo skrivala?
Shady, shady..
Že spet ta neumni spin.
Če te že mešanje jedrskega in biološkega ne moti, vsaj preveri kaj je Grossi povedal. Gre za odpadke iz reaktorjev.
Go-ahead ::
Upam, da ta debil nima potomcev.
tomlin ::
A JE KAJ ČUDNEGA, DA KRVOLOČNEGA DIKTATORJA BOLI TIKVA, V TRENUTKU SO MU POBILI 10 GENERALOV!
Ukrajina je med nenehnim spopadom v Ukrajini ubila od "osem do deset" ruskih generalov, je v torek pred odborom
za oborožene sile senata povedal generalpodpolkovnik Scott Berrier, vodja ameriške obrambne obveščevalne
agencije.
Ameriški uradniki so pozorno spremljali naraščajoče število smrtnih žrtev generalov v ruski vojski - nenavadno
veliko število za sodobno vojsko, ki daleč presega število ameriških generalov, izgubljenih v 20 letih konflikta
v Afganistanu.
https://edition.cnn.com/europe/live-new...
agencije.
v Afganistanu.
primoz4p ::
Severna Koreja je v četrtek, ko je prevzela vodenje konference o razorožitvi, diplomatske prijeme zamenjala za bojni ton. "Moja država je še vedno v vojni z Združenimi državami," je izjavil veleposlanik Pjongjanga Han Tae-Song.
Približno 50 držav je izrazilo ogorčenje nad tem, da je nepredvidljiva Severna Koreja z jedrskim orožjem v naslednjih treh tednih zadolžena za predsedovanje najpomembnejšemu večstranskemu forumu o razoroževanju na svetu.
Severna Koreja je prevzela predsedovanje CD s sedežem v Ženevi v skladu z večdesetletno prakso 65 članic organa, ki si sledijo po abecednem vrstnem redu imen držav v angleščini.
CD, ki ni organ ZN, vendar se sestaja na sedežu ZN v Ženevi, je večstranski forum za razorožitev, ki ima tri zasedanja na leto. Poganja se o sporazumih o nadzoru orožja in razoroževanju ter se osredotoča na ustavitev tekme v jedrskem oboroževanju.
https://www.domovina.je/protesti-v-zdru...
Kdo jih je pa potrdil za to funkcijo? Mislim, da sedaj iz že kar dolge zgodovine Kima mlajšega, se da razbrat njegovo obnašanje.
Tako da "poslje j*banja nema kajanja!.
v Afganistanu.
Število ameriških generalov, izgubljenih v 20 letih konflikta v Afganistanu, je enako 0. Nazadnje so enega izgubili leta 2003 v Iraku, še tega zaradi prijateljskega ognja.
In Američani brigardirje (1 zvezdica, takoj nad polkovnikom) štejejo za "lahko zamenljive".
- spremenil: Smrekar1 ()
Poleg tega usa generali "bivakirajo" nekje daleč za frontno linijo te varnem gledajo dogajanje na zaslonih (droni, sateliti, . . .)
Ruski vojaki so bolj pogrešljivi, razen mogoče kakšen Putinu naklonjen general.
TezkoDihanje ::
Seveda lahko bivakirajo daleč za frontno linijo, ker:
- NATO vojske dajejo daleč večjo težo odločitvam nižjih oficirjev na bojišču
- imajo veze, ki dejansko funkcionirajo in so enkriptane
Russia can't into cell phones, wireless Internet and modern data transmission. The only option left - direct commands at range of human scream. Good general can scream and command solders at 500 meters range. :D
tomlin ::
PUTIN KRIV ZA LAKOTO V TRETJEM SVETU, V EU NIKAKOR NE BO POMANKANJA
Vladimir Putin in njegova "agresivna vojna" sta odgovorna za nevarnost lakote v Afriki in ne na Zahodu, je dejal
tiskovni predstavnik nemškega zunanjega ministrstva.
Nemčija ostro obsoja poskus ruskega predsednika, da bi ustvaril naracijo, da je zahod odgovoren za povzročanje
svetovne prehranske krize, so povedali na redni vladni tiskovni konferenci.
Tiskovni predstavnik zunanjega ministrstva je dejal:
Poudariti moramo, da je dejstvo, da v nekaterih delih sveta grozi lakota, da so nekatere države odrezane od izvoza žita, posledica ruske agresije in ne sankcij Zahoda.
Operaterji blokirajo na retail dostopih, business je open, podjetja pač poslujejo z RU...
primoz4p ::
Ukraine has exported more than 46.9 million tonnes of grain and leguminous crops as of May 30, including 1.06 million tonnes in May.
That’s according to the press service of the Ministry of Agrarian Policy of Ukraine, referring to figures from the State Customs Service, Ukrinform reports.
Since the beginning of the 2021/2022 marketing year, Ukraine has exported 46.93 million tonnes of grain and leguminous crops as of May 30, including 1.06 million tonnes in May. In particular, Ukraine exported 18.56 million tonnes of wheat (including 42,000 tonnes in May), 5.68 million tonnes of barley (11,000 tonnes). 161,900 tonnes of rye (not shipped in May), and 22.22 million tonnes of corn (1 million tonnes).
According to the report, since the beginning of the marketing year, Ukraine has exported 71,000 tonnes of flour (1.400 tonnes in May), including 69,400 tonnes of wheat flour (1,300 tonnes).
As was reported earlier, Russian invaders have stolen at least half a million tonnes of grain from Ukraine's temporarily occupied territory and they are looking for ways to sell it illegally. The Ministry of Agrarian Policy of Ukraine fears that the Russians may steal a new harvest of winter crops. Ukraine is constantly discussing the issue of exporting its crops to other countries with the UN, the EU, the United Kingdom, the United States, and grain-importing countries.
Primerjava s predhodnim obračunskem letom pa je na naslednji povezavi (original)
https://www.ukrinform.ua/rubric-economy...
Kaj je vzrok za grožnjo lakote?
Jazon ::
Medtem v Chicagu.
https://imgur.com/a/AnlkQ3Y
Medtem na Rusko Ukrajniski meji
https://imgur.com/a/wBchXKD
Medtem na Kurdsko Sirski meji
https://imgur.com/a/R86oyWa
Medtem v Moskvi
https://imgur.com/a/He8IJFL
Putin zapušča Moskvo, v centru so izvedli atentat na Ognesa Kamaryana
Medtem v Moskvi
Medtem v Chicagu.
Medtem v Moskvi
Maš kaki link, o čem se to gre? Puter gre na zdravljenje?
In Mariupol, Russians execute and torture officials who refused to cooperate - the mayor
Prijazni osvoboditelji.
Jazon ::
Medtem v Chicagu.
Medtem v Moskvi
Na počitnice.
Oba Iljušin96 sta pristala v Sočiju.
yayo ::
12.18 Proruski separatisti se pritožujejo Putinu zaradi pogojev, pravijo, da so lačni in nimajo zdravil
Novinar Politica za Ukrajino in vzhodno Evropo Christopher Miller je na Twitterju objavil posnetek proruskih separatistov, ki se pritožujejo ruskemu predsedniku Vladimirju Putinu glede pogojev boja.
V videoposnetku, ki naj bi bil posnet na območju Hersona, se proruska separatistična vojska pritožuje Putinu zaradi lakote in mraza. V posnetku en vojak prebere besedilo, preostali pa stojijo okoli njega z orožjem v rokah. Navedli so tudi, da nimajo zdravil in so jih brez ustreznega orožja vrgli v boj in poslali v klavnico. Prosijo, da jih pošljejo nazaj v Donetsk.
Putler jih pošilja v klavnico
primoz4p ::
"osvoboditelji" in "osvoboditelji"
Separatizam u Donbasu
Sjeverodonjeck je poznat i po tome što je prije dvadeset godina tamo bio prvi pokušaj podjele Ukrajine. U gradu se 28. studenoga 2004. godine sastao takozvani „Sveukrajinski kongres zastupnika svih razina", na kojem su prije svega sudjelovali predstavnici proruske Stranke regije.
Ta stranka je nastala u Donbasu i dominirala je regijom. U doba prozapadne „narančaste revolucije" prijetila je proglašenjem autonomije s Harkovom, kao svojim centrom. Autonomija je trebala obuhvatiti osam istočnih i južnih ukrajinskih oblasti, kao i Krim i Sevastopolj.
Na kongresu je govorio i tadašnji gradonačelnik Moskve Jurij Luškov, koji je kao mladić radio u tvornici Azot. Kasnije je čak proglašen počasnim građaninom Sjeverodonjecka, iako su mu ukrajinske vlasti još tada, zbog separatističkih izjava o Sevastopolju, zabranile ulazak u zemlju.
Inicijatori „Sveukrajinskog kongresa" 2004. godine su ostali na prijetnjama. Međutim, mnogi promatrači taj sastanak vide kao prvi, neuspjeli pokušaj formalnog političkog raskola u Ukrajini.
Drugi pokušaj je uslijedio deset godina kasnije, tokom proljeća i ljeta 2014. godine. Nakon ruske aneksije ukrajinskog poluotoka Krima, naoružani lokalni separatisti, zajedno s kozacima koji su došli iz Rusije, zauzeli su tri susjedna grada Sjeverodonjeck, Lisičansk i Rubižne.
U drugoj polovici srpnja 2014. ukrajinska vojska je oslobodila regiju. Sjeverodonjeck je postao regionalni centar vojno-civilne administracije. Iz Luganska su se tamo preselile razne institucije i fakulteti. Sada su se ponovo preselili, ovoga puta u zapadnu Ukrajinu.
https://www.dw.com/hr/sjeverodonjeck-%C...
nejclp ::
VladarP ::
FAKTOR #744: DO KDAJ ŠE UKRAJINA? (dr. Bogomil FERFILA, mag. Bernard BRŠČIČ)
Brscic dominira kot vedno. Hvala za ta posnetek.
Akhmat sila
Kebo ::
Brščič pa Norma sta mi najboljši par. Klerikalka k zagovarja družinske vrednote razbije družino in povrže par malih čefurčkov, taprava slovenska.
l0g1t3ch ::
Ruska trgovina v Murglah in v MB sporoča, da je polno založena. Vabljeni!
LOOOL, še 2 urni ne zdržiš brez nas.
Pa na dopust greš k Italjanom. Hvaležni bomo za tvoje €, ki jih bomo v obliki granat poslali naprej v Rusijo!
Kozja Sila!!!
TezkoDihanje je izjavil:
Rumeni del je bil vsaj nekaj časa pod kontrolo Rusije v tej vojni.
Rusi napredujejo v rikverc ?
TezkoDihanje ::
Severodonetsk
prevod:
https://twitter.com/mdmitri91/status/15...
Lost boys of DPR have no clue who their commander is - let alone which unit they belong to.
The Russian 35th army, transferred from Far East and stationed in Izyum, is successfully destroyed by its own army command as evidenced from this full of irony and snark report received and shared by a Russian livejournal blogger.
prevod:
- spremenil: TezkoDihanje ()
Zelensky admits Russia now holds one-fifth of Ukraine, the largest country entirely within Europe. What he didn't acknowledge is that Russia controls Ukraine's industrial heartland, 90% of its energy resources (including all of offshore oil), and its critical ports and shipping.
A nisi rekel,da greš v bazo? Te je strah dežja?:D
Pregovor od VladarP-ja
Če žena ne bo dala, bo pa kozlica dala
tomlin ::
To si zadel žebljico na glavico. "ferfilc" neskončno dolgo občuduje svoje samogovore. In misli o vseh svojih prognozah, da so neskončno točne.
Ferfila ma en poseben talent, da mu nikoli ne uspe karkoli pravilno napovedati, o naciju pa itak ne bi besed izgubljal.
Jaz čakam na slike zajetih NATO generalov in admiralov iz Mariupola.
Sem zasledil naracijo putinovcev na twiterju, da ker niso našli nato generalov in bioznanstvenikov, je to dokaz, da so jih, po direktivi Bidna in Zelenskega, azovci pobili, trupla pa razkosali do neraspoznavnosti. Resno.
- spremenilo: tomlin ()
