Forum » Loža » Korona - prvi in drugi val
darkolord ::
So naredili obdukcijo pri vseh, da lahko z gotovostjo trdijo ?Ni nobene potrebe po obdukcijah, sploh če je vzrok smrti očiten (po strokovnih - ne facebook - merilih). Obdukcije, ki so jih pri nas in v tujini naredili, so kazale na močno prizadetost pljuč pri vseh bolnikih, umrlih "s covidom".
Še zmeraj velja, da če si pozitiven na pcr testu in umreš v naslednjih 28 dneh, da si žrtev korone ?Pri nas to ni nikoli veljalo.
S tem da si po pcr testu pri Ct +34 pozitiven v 98%.Pojma nimaš, to številko si si kar izmislil. Tudi če bi držala, nikjer ni 98% testov pozitivnih, tako da je po tvojih kriterijih to OK.
https://www.cdc.gov/nchs/nvss/vsrr/covi...
Comorbidities
Table 3 shows the types of health conditions and contributing causes mentioned in conjunction with deaths involving coronavirus disease 2019 (COVID-19). For 6% of the deaths, COVID-19 was the only cause mentioned. For deaths with conditions or causes in addition to COVID-19, on average, there were 2.6 additional conditions or causes per death. The number of deaths with each condition or cause is shown for all deaths and by age groups.
category 1: definite COVID-19 death;
category 2: probable COVID-19 death;
category 3: possible COVID-19 death with an equal alternative cause of death;
category 4: SARS-CoV-2 detection with cause of death not associated to COVID-19
Our evaluation provides a systematic overview of the first 80 consecutive full autopsies. ... A total of 76 cases (95%) were classified as COVID-19 deaths, corresponding to categories 1–3. Four deaths (5%) were defined as non-COVID-19 deaths with virus-independent causes of death.
Malo refresha:
- povprečen dan umre zaradi VSEH razlogov 56 ljudi
- danes je s/zaradi COVID-19 umrlo 45 ljudi
Ali je to samo strašenje, kot že tolikokrat do sedaj ? Ker vlada laže, da se kar kadi https://necenzurirano.si/clanek/aktualn... .
Comorbidities
Za UK je številka še nižja, 4.529%
https://www.england.nhs.uk/statistics/s...
weekly file, Tab3 Deaths by condition.
Za razliko od cdc tu ne piše, koliko drugih bolezni so imeli umrli.
84 odstotkov umrlih s covidom-19 starejših od 74 let
V DOS ih je zgleda pravi masaker. Virus neusmiljeno prodira v še preostale domove. V bistvu je že od poznega poletja not, najprej se hinavsko širi, potem ko udari, je pa itak že pozno za karkoli. Toliko ljudi na kupu. Tle je narejeno precej narobe po moje.
Če zdaj gledam nazaj, v bistvu pred začetkom šole bi morali testirati učitelje, v šolo pa pa bi lah šla sam prva triada. Sam če pogledamo po evropi je povsod dar mar, tako da se bodo neprijetna vprašanja postavljala če pride cepivo drug mesec, če pa ćez pol leta, bo pa itak virus pr nas že itak zdivjal čez te reveže v DOS ih. Bo zadeva brezpredmetna.
- spremenilo: Telbanc ()
imagodei ::
Malo refresha:
Zakaj delaš iz sebe bedaka?
Ko govorimo o hudo bolnih zaradi Covid-19, ima bolezen precej značilen potek. To ni tako, kot pri ljudeh z milimi simptomi, kjer zdravnik brez testa res težko oceni, ali gre za Covid ali gripo (seveda s to razliko, da zdaj sploh še ni sezona gripe). Ampak, pri umrlih govorimo o najhujšem možnem poteku bolezni in tu ima bolezen kar nekaj značilnosti. Vemo recimo, da prihaja pri najhujših primerih do akutnih odpovedi oziroma poškodb več organov (pljuča, jetra, ledvice, srce, krvožilje...) Poleg tega je bilo povedano, da zdravniki pri intubiranih bolnikih testirajo tudi aspirat sapnika ali bronhoalveolarnega izpirka. Poleg tega se zdravniki poslužujejo slikanja pljuč z rentgenom; infiltrati v pljučih pri Covid-19 pacientih so menda spet dovolj specifični, da tega izkušen zdravnik ne zamenja za bakterijsko pljučnico.
Skratka, v nasprotju z vami, ki zgolj fantazirate o teorijah zarote, se v naši realnosti na Covid-19 oddelkih in na ICU-jih dogaja kar precej diagnostičnih preiskav.
Američani imajo en tak fajn izraz: če hodi kot raca in če gaga kot raca, potem najverjetneje je raca. In če imajo zdravniki pred sabo pozitiven PCR test bronhoalveolarnega izpirka, tipično rentgensko sliko za Covid-19 in tipičen potek bolezni, potem pri pravkar preminulem res ni treba opravljat še obdukcije.
Nekaterim je to jasno. Vprašanje samo, a si ti med njimi?
- Hoc est qui sumus -
kunigunda ::
Na kitajskem so pri kasnejsnjih obdukcijah nasli preko 90% primerov smrti, kjer je bil poleg sarscov2 prisoten se vsaj en virus (influenca, rino, rsv, ...)
ajdov ::
Imam občutek da dokler ne pride do masovnega, ampak res masovnega neupoštevanja ukrepov s strani večine tega ne bo konec. To je edini način da tole zaključimo. Zdaj mi je jasno, nekaterim drugim tudi. Ostali boste pa že dojeli.
MeGreat ::
Dobro, za razliko od marčevskih zapiranj so tukaj vsaj dali tiste cilje kdaj se bo nazaj odpiralo.. Koliko jih je že 150 okuženih na dan, da se spet odpre? Se pravi marca že zna biti odprto.
dexterboy ::
Ste pa res zasvinjali temo s temi napadi na Matota...
Sinoči grem domov, ura 21:05. Center mesta, mlajši par sprehaja psa, oba imela maski gor.
Pride mimo Lupo Zoki Redarstva, ustavi in "jebe v glavo" punco in fanta...
Niso jima napisali kazni, ampak je bilo 3 minute napetega ozračja...
Vprašanje v stilu "staroborcev"; "A smo se za to borili?"
En drugi večer prejšnji teden "šetam kera", pa grem mimo lokalnega Hoferja; ura okoli sedme zvečer (je bilo že kar mrzlo), zunaj pa vrsta za vstop v trgovino. Mi ni dalo miru; 17 ljudi je čakalo v vrsti. Sem se kislo nasmejal, ko so se mi je pred očmi prikazale črno bele slike prejšnjih desetletij, ko so ljudje v vrsti čakali za edini obrok tistega dneva...
Ampak sej bo. Naslednjih 14 dni bo kritičnih, potem pa krivulja obrne navzdol
MeGreat ::
Hja redarji majo norme, zdaj kazni za napačno parkiranje več ne morejo pisati je treba nekje drugje notri prinesti. Sicer pa ali ni sprehod psa dovoljen po 9 uri?
". . . pa grem mimo lokalnega Hoferja; ura okoli sedme zvečer (je bilo že kar mrzlo), zunaj pa vrsta za vstop v trgovino. Mi ni dalo miru; 17 ljudi je čakalo v vrsti. . . . "
To je rezultat tega, ker se ljudje ne znajo organizirat! Meni na kraj pameti ne pade, da bi pred koncem obratovalnega časa trgovine šel nakupovat (zdrava pamet ti pravi, da je takrat največja gužva).
/SON
"Naslednjih 14 dni bo kritičnih, potem pa krivulja obrne navzdol >"
/SOFF
To ti dam prav.
/SON
/SOFF
To ti dam prav.
Urbano#Desno ::
Pri nas je zadnjih par dni vedno gneča pred lidlom ob različnih urah.
Ma jaz predvsem ne štekam zakaj folk rine v trgovino za vsako pizdarijo posebej. Zadnjič grem v lidl ob 8h. Pridem minuto prej zunaj že vrsta penzijonistov. Jaz naložim cel voziček vsi ki so bili pred mano v vrsti na blagajni so imeli malenkosti da skupaj niso bile 10 - 15 EUR. A je res tako težko iti v štarcuno 1X na teden še posebej sedaj in še posebej če si rizičen za virus in ne da hodiš vsak dan.
lotar123 ::
Urbano#Desno je izjavil:
To govorim že od začetka, tisti, ki so najbolj ogroženi in bi bilo pametno da se najbolj izolirajo, najmanj upoštevajo vse skupaj!
nekikr ::
To je edina priložnost za njih, da gredo vsaj malo ven in se vsaj malo podružijo. Ja, to dobiš, če sprejmeš kretenske ukrepe. Ljudje pač ne bodo čepeli za štirimi stenami eno leto ali dve, ker zunaj razsaja tako hud virus, da ga v statistiki smrtnosti ne moreš zaznati.
Urbano#Desno ::
Ne vidim poante rinit v štarcuno z namenom druženja, kjer srečaš random ljudi, če se pa zmenijo zjutraj ob 8 ko se lidl odpre se dobimo pred vhodom bi se pa lahko zmenili tudi v lokalnem parku (ne ni legalno samo tudi grupiranje pred vhodom najbrž ni ).
Če gre za dobro kapitalizma potem je druženje dovoljeno, celo spodbuja se. Npr. v firmah, trgovinah in podobno.
3p ::
To s starimi je takole. Dosti je osamljenih. Prijateljev manjka. Z naključnimi ljudmi se ne zmeniš v parku. Lahko pa se v trgovini naključno srečaš pri solati in se malo pomeniš, kako je bila včasih bolj okusna. Pa še navad se držijo bolj kot mlajši. Če se gre v trgovino, se gre v trgovino.
V drugih novicah:
Sicer pa danes spet 2000+ in skoraj 30% pozitivnih. 70% ljudi se veselo druži na delovnih mestih.
V drugih novicah:
Hemi426 ::
https://www.rtvslo.si/zdravje/med-epide...
"Aprila je bilo izdanih za 21 odstotkov več receptov za antidepresive kot enakega meseca lani, maja kar za 41"
Ne razumem zakaj so ljudje tako egoistični in dodatno obremenjujejo ZD sistem z obiski zdravnikov zaradi psihičnih težav.
Namesto, da bi sprejeli fizične omejitve, omejitve socialnih stikov, izgubo financ, stalno paniko, strah pred kaznovanjem, kot nekaj dobrega za rešitev življenj.
Kakšni antidepresivi, knjiga in čajček za naslednjih 14 dn...emm..30 dni..emm do aprila...em do 2024, ko bo cepiva dovolj.
Za življenja gre in ohranitev ZD sistema se gre!!!!!!!!!
nekikr ::
3p ::
Ja nič, v ZDA so usput na volitvah, pod ljubljencem našega PV, še v par državah legalizirali rabo marihuane.
Danes nam Beovičeva sporoči, da bo PV urgentno sprejel podoben dekret. Pa smo lahko v izolaciji vsaj do junija.
Facebook dev ::
Nakoncu marsikomu tudi veliko pomeni, da je malo med ljudmi. Ni nujno, da jih pozna, da z njimi spregovori, sam da je del njih. In ja, pol ure v trgovini je za marsikaterega upokojenca toliko socializacije kot jo bo dobil ta dan.
If you can't handle me at my worst,
you don't deserve me at my best.
St235 ::
Zakaj bi moral nekdo drug organizirati smrt sicer opravilno sposobnemu moškemu? Bejš si za vogal kupit hors pa overdose v žilo!
To je moj plan, če dobim neozdravljivega raka, furat dokler ne boli, pol pa fly high and peace out.
Odpade, tisto sekundo ko rabiš pregled si v očeh našega socipata Mata že zrel za odstrel. Nimaš kaj obremenjevat zdravstva in čakat, da bo prehudo. Sumiš da si bolan, ode glava. Bog ne daj da ti pa računalnik crkne.
- spremenil: St235 ()
dexterboy ::
Če so ljudje, v tem primeru upokojenci, pripravljeni sprejeti riziko okužbe s covidom v zameno druženja, je naša zadnja pravica in dolžnost, da jim to preprečimo. Jasno, da to posledično polni bolnice in sesuva naš sistem, ampak, ali je kdo v politiki SPLOH rekel upokojencem, da je to za njihovo skupino PREPOVEDANO? In ravno zato, ker ni, jih nimamo obsojati, zakaj se družijo v vrstah pred štacunami... Pa napisano ni kontra temu, kar sem pisal in zagovarjal do sedaj. Je pač slika stanja, ki ga imamo v tej kokoški...
Kako lepo je imeti nekoga, na katerem se lahko človek sprazni in izlije svoj gnev ;)
Odpade, tisto sekundo ko rabiš pregled si v očeh našega socipata Mata že zrel za odstrel. Nimaš kaj obremenjevat zdravstva in čakat, da bo prehudo. Sumiš da si bolan, ode glava. Bog ne daj da ti pa računalnik crkne.Zakaj bi moral nekdo drug organizirati smrt sicer opravilno sposobnemu moškemu? Bejš si za vogal kupit hors pa overdose v žilo!To je moj plan, če dobim neozdravljivega raka, furat dokler ne boli, pol pa fly high and peace out.
- spremenil: dexterboy ()
dexterboy ::
https://www.rtvslo.si/radiomaribor/novi...
Za otroke gre? Ko si v svetu staršev in sodeluješ pri vsakoletnih akcijah zbiranja pomoči otrokom, ki si doma ne morejo privoščiti topel obrok... škoda, da pišem dalje. Itak bo malokdo doumel....
A kdo ve, če se dobi kje analiza umrlih po vzrokih?
Primerjati lansko in letošnjo jesen bi bilo brez dvoma zanimivo.
Poslušam Kacina zdaj, neki zmeden je... govori kot slab politik...
s1m0n ::
Zdaj nam nabija Dodička neke nebuloza ojej... Kje jih najdejo, resno!
hendriks ::
V Avstriji policija hodi preverjat ali so ljudje doma. Iz prve roke vam povem, da ljudje v mojem okolišu še naprej hodijo na rojstno-dnevna praznovanja, kot da epidemije ni.
Saj to je edino pravilno da hodijo... virusi pridejo in grejo, lajf je pa en sam!
- predlagal izbris: hendriks ()
3p ::
Ja, med nekonsistentnimi nebulozami pa je omenila tudi tabu temu slovenskega (middle) managementa.
Pošljite ljudi, ki lahko delajo od doma, delat od doma.
E, to pa ne. Ker jih pol ne vidim, kako delajo. In lahko naredijo vse v štirih urah in potem počivajo!
Sicer potem takoj nadaljuje, da če se ukrepov pravilno držimo, delujejo. Kar takoj negira potrebo po delu na daljavo.
Hemi426 ::
Zakaj je dolžnost, da jim preprečimo?
Mogoče so zavedanja, da virus ni tako smrten ali pa preprosto izberejo kvaliteto življenja "zadnjih dni" pred varnostjo.
Veliko bolj jih bo uničil izredno omejen dostop do ZD storitev, in zmanjšana socializacija.
Se sploh zavedaš, kako zelo so omejili dostop do ZD, če ni "nujno", kar je pristarejših ljudeh bistveno bolj širok spekter.
https://www.24ur.com/novice/slovenija/z...
Tile posledične stvari jih bodo pokopale veliko več, kot virus.
V sosednji kletni bife priletijo na prvo rundo kmalu po sedmi uri. Ko se začne delovnik. Potem pa počasi čez dan kapljajo. Kakor je kdo žejen.
Policija ne pride v kontrolo, župan pa.
Pravilno, vse te scene dozivljamo zaradi virusa zaradi katerega preživi 99.9% obolelih in 100% otrok. Sramota da se sploh pogovarjamo o tem ker tako to agonijo samo vspodbujamo.
3p ::
Dobro vem, ja. In prav imaš.
Ampak to je bilo že večkrat povedano. Gremo naprej kot da je prehlad, žal tega problema tudi ne reši.
hendriks ::
Jp, policija je pravilno da nadzira, če že ima taka navodila. Aja, ti si mislil na ljudi, kateri ne upoštevajo ukrepe :) Super, karanteno bomo imeli še globoko v 2021, kajne Mato?
Če se nehamo držat karantene oz. ukrepov jih pač več ni... policije ni dovolj, narod je odločevalec... jaz grem vsak dan čez kakšno občino iz principa, ko so ukrepi neumni je dolžnost državljana da jih krši!
3p ::
Bolj (58950-919)/58950. Torej okoli 98.5%.
Ne, mrtve bomo imeli še globoko v leto 2021.
To pa zato, ker vlada in podrepniki mislijo, da se osemdesetletni umirajoči okužijo medtem, ko ponoči žurajo z mladoletnicami po diskačih. Zato so to tudi prepovedali.
In zdaj mislijo, da bo vse ok. Ampak očitno to ni bil pravi vzrok in način reševanja.
Laž... okuženih je like 3x toliko kot je zaznanih... smrtnost je po WHO tam okrog 0,0XX! Pri tistih nad 65 pa okrog 0,15 ali nekaj takega...
Vseh okuženih ni v statistikah. Koliko si neupam ugibat, ker bomo prišli globoko v decimalke da bomo sploh % mrtvih našli.
Kaj so sploh na tej konferenci povedali? NIČ PAMETNEGA... Prvič sem gledal in to je res smešnica.
Hemi426 ::
Zakaj je globalna stroka tako neenotna?
Tako, kot bi po 10 letih izobraževanja, dejansko začeli črpati znanje par tednov nazaj z Wikipedie.
Portugalca z ustavnim sodiščem razsodi, da so PCR testi izredno nenatančni in neuporabni, Nizozemska in Španija jih vrnejo proizvajalcem, Dodikova pa teži k vzpostavi infrastrukture za množično PCR testiranje?
Urbano#Desno ::
Če si pričakoval da bodo rekli da je kul hodit okoli kot smo prej si imel kot vedno napačna pričakovanja. Verjamem pa da moraš imeti vsaj rahlo fleksibilen mozek da razumeš kaj želijo povedati. Kako bo jokcanje veliko šele konec decembra ko ugotovite da klasičnih silvestrovanj ne bo.
3p ::
Ni govorila o PCR ampak o hitrih testih.
Ki so, če jih uporabljaš za to, da se odločiš da koga od zaposlenih pošlješ domov, povsem uporabni (v primerjavi z ničemer).
PKP8 ukinitev programa Metadona, legalizacija konoplje kar z odlokom. Krivulja receptov za antidepresive narašča eksponentno.
Hemi426 ::
Se popravljam, hitri so antigenski.
Se pa ne strinjam, da so uporabni, če je zanesljivost manj kot 50%.
Mi že mamo zmenjeno silvestrovanje... taktično bomo še šli rakete spustit v luft... na polje pa skrit v gozd, pol nas pa naj najdejo... pa premični šank na kolcah so kolegi spacali skup, ni slabo.
Urbano#Desno ::
nekikr ::
In tudi to je bilo že večkrat povedano, da nehajte pretepati slamnatega moža, ki naj bi bil "gremo naprej brez ukrepov". Glede na nevarnost virusa bi morali ubrati srednjo pot. Uničenje vsega in vsakogar zaradi močnejšega prehlada pač ni najbolj smotrno početje. Še enkrat: med kugami v srednjem veku in svetovnimi vojnami (ker tako velikokrat zasledim, da če smo to preživeli bomo pa še covid) ljudem ni bilo potrebno razlagati, da je zunaj smrtonosni virus. Niti se niso "strokovnjaki" ubadali z raziskovanjem smrtnosti in iskanjem tistih treh, ki so morda dodatno umrli, je bilo vse precej jasno. Danes pa raziskujemo, premetavamo številke, gledamo razne vire, zato, da ugotovimo, da je manj umrlih kot prejšnja leta, da umrejo izključno tisti, ki bi tako ali tako umrli v enakem času zaradi drugih bolezni itd. Res hudo huda apokaliptična plandemija je to, ja.
