Autoptimize mi je zrušil stran WP -Kaj sedaj?
Manager ::
POzdravljeni
Imam velik problem. Delal sem spletno stran v Wordpressu, vse končal, naložil Autoptimize plugin, potem mi je začela stran štekati, pa se sedaj ne morem več vpisati. Stran je na localhostu. Sem bil v wordpressu, pa ko sem stisnil restore v Updraftu mi je pokazalo napake in me ven izpisalo. Danes sem, predn sem naložil Autooptimize v Wamp-u tudi kliknil Export - Sqla. Zdaj pa več ne vem kako se vpisati nazaj in ne vem, ali mi je stran čisto zbrisalo. Imam tudi na pcju prenesene te datoteke Backup, others, themes, uploads, plugins, others..
Ko se hočem vpisati, mi pokaže 404 stran.
Upam,da mi kdo pomaga.
  • spremenil: Manager ()
Manager ::
Zdaj sem se vpisal namesto localhost/wordpress/mojastran-login sem probal localhost/wordpress/wp-admin in mi je šlo, ampak je vse prazno noter. Pugini so vsi prazni, ni slik...
The plugin polylang/polylang.php has been deactivated due to an error: Plugin file does not exist.
The plugin 404page/404page.php has been deactivated due to an error: Plugin file does not exist.
The plugin addon-elements-for-elementor-page-builder/elementor-addon-elements.php has been deactivated due to an error: Plugin file does not exist.
The plugin better-search-replace/better-search-replace.php has been deactivated due to an error: Plugin file does not exist.
The plugin child-theme-configurator/child-theme-configurator.php has been deactivated due to an error: Plugin file does not exist.
The plugin cookie-notice/cookie-notice.php has been deactivated due to an error: Plugin file does not exist.
The plugin custom-fonts/custom-fonts.php has been deactivated due to an error: Plugin file does not exist.
The plugin duplicator/duplicator.php has been deactivated due to an error: Plugin file does not exist.
The plugin elementor/elementor.php has been deactivated due to an error: Plugin file does not exist.
The plugin elements-plus/elements-plus.php has been deactivated due to an error: Plugin file does not exist.
The plugin jetpack/jetpack.php has been deactivated due to an error: Plugin file does not exist.
The plugin mousewheel-smooth-scroll/mousewheel-smooth-scroll.php has been deactivated due to an error: Plugin file does not exist.
The plugin really-simple-ssl/rlrsssl-really-simple-ssl.php has been deactivated due to an error: Plugin file does not exist.
The plugin updraftplus/updraftplus.php has been deactivated due to an error: Plugin file does not exist.
Samo nekaj pluginov se pokaže, strani več ni....
spegli ::
Pwned zelo verjetno. Na novo OS...
Manager ::
Na novo narediti celo stran?
spegli ::
A backup maš ?
Manager ::
Danes sem v Updraftu naredil Backup in jih shranil na pc. Potem sem pa še v Wampup dal Export Sql in shranil na pc. Sedaj sem se vpisal na stran, tekst še je, meni je tudi, slim več ni. Nekaj pluginov mi je pokazalo, da lahko aktiviram in sem. Sedaj sem naložil Updraft in mi je pokazalo seznam datotek, ki sem jih v zadnjih dneh Backupal.
! ) Warning: copy(): The first argument to copy() function cannot be a directory in C:\wamp64\www\wordpress\wp-admin\includes\class-wp-filesystem-direct.php on line 247
Call Stack
# Time Memory Function Location
1 0.0004 411216 {main}( ) ...\options-general.php:0
2 0.0004 411888 require_once( 'C:\wamp64\www\wordpress\wp-admin\admin.php' ) ...\options-general.php:10
3 0.4211 6822952 do_action( ) ...\admin.php:253
4 0.4211 6823328 WP_Hook->do_action( ) ...\plugin.php:465
5 0.4211 6823328 WP_Hook->apply_filters( ) ...\class-wp-hook.php:310
6 0.4211 6824344 UpdraftPlus_Admin->settings_output( ) ...\class-wp-hook.php:286
7 0.4218 6831224 UpdraftPlus_Admin->restore_backup( ) ...\admin.php:2558
8 0.4625 7073248 Updraft_Restorer->perform_restore( ) ...\admin.php:4571
9 0.4842 7078200 Updraft_Restorer->restore_backup( ) ...\restorer.php:482
10 17.6334 7099608 Updraft_Restorer->move_backup_in( ) ...\restorer.php:1501
11 18.2772 14173896 WP_Filesystem_Direct->move( ) ...\restorer.php:1111
12 18.3772 14173896 WP_Filesystem_Direct->copy( ) ...\class-wp-filesystem-direct.php:270
13 18.3772 14173896 copy ( ) ...\class-wp-filesystem-direct.php:247
Error message: Could not move the files into place. Check your file permissions.
Error data: C:/wamp64/www/wordpress/wp-content/upgrade/83d6e52e/uploads/2019 -> C:/wamp64/www/wordpress/wp-content/uploads/2019
Restore failed...
To mi je pokazalo, ko stisnem Continue restoration
spegli ::
Možno da je plugin broken (napačna verzija inp.) . Poskušaj ga odstraniti. Sicer boš verjetno rabil restore.
Manager ::
Plugin sem takoj odstranil, Autoptimize, potem pa se je vse skupaj zrušilo. Sedaj pa sem dodal nekaj pluginov, pa se je postavljalo nazaj, nimam pa slik in oblike.
Final checks
Looking for db archive: file name: backup_2019-02-28-1214_moja_stran_410ed4e57d75-db.gz
Archive is expected to be size: 3819 KB: OK
Looking for plugins archive: file name: backup_2019-02-28-1214_moja_stran_410ed4e57d75-plugins.zip
Archive is expected to be size: 34986.9 KB: OK
Error: Existing unremoved folders from a previous restore exist (please use the "Delete Old Directories" button to delete them before trying again): C:/wamp64/www/wordpress/wp-content/plugins-old
Restore failed...
Actions: Return to UpdraftPlus Configuration
Kaj če kliknem Delete old directories?
UpdraftPlus Restoration: Progress
Follow this link to download the log file for this restoration (needed for any support requests).
Final checks
Restore failed...
Manager ::
Če nazaj vse plugine aktiviram, mislite da se bo povrnilo?
spegli ::
Če greš pogledat file na C:/wamp64/www/wordpress/wp-content/nekineki
obstajajo ?
Manager ::
ja, obstajajo
cache
languages
mu-plugins
plugins
plugins-old
themes
themes-old
updraft
upgrade
uploads
uploads-old
wflogs
in
index.php
Ko sem začel vklapljati plugine nazaj, se je stran postavljala nazaj, ampak ni slik, postavitve...
spegli ::
Potem se je verjetno nekje v konfiguraciji spremenila pot do slik.
Manager ::
Ko grem pod Media, mi pokaže slike oz. seznam slik, imena jpg, ni pa dejansko vizualnega prikaza slik
Ozadja so povsod vijolična
Tudi linki delajo
Tekst je razmetan
spegli ::
Mogoče kdo pomaga z več izkušnjami z WP, moje so like 0. WP je sicer precej zaželjeno hekat. Katero verzijo WP pa imaš ?
Manager ::
Wordpress 5.1
Tekst se je vrnil, edino, razmetan je, linki delajo, slik ni nobenih na strani nikjer, niti ene, so pod Media slike oz. seznam slik, z imeni, samo dejansko vizualnega prikaza slik ni niti v Media.
Saul Goodman ::
spegli je izjavil:
model, če prebereš še enkrat, vidiš, da ima spletno stran na localhost. videl sem že marsikaj, ampak da ti nekdo vdre v wordpress namestitev, ki jo furaš lokalno.. no, tega pa še ne.
Manager ::
Ko sem naložil plugin Autoptimize mi je vse zrušilo. Tega plugina sedaj nimam več, sem ga zbrisal. Imam pa pod na C:/wamp64/www/wordpress/wp-content/cache naslednje mape
all
autoptimize
swift-performance
wpfc-minified
in datoteko index.html
Manager ::
Ko grem C:/wamp64/www/wordpress/wp-content/uploads imam dve mapi
- 2019/03 ki je prazna
- elementor/css ki je prazna
Ko pogledam tiste mape v .zip pod Downloads, ki sem jih dol potegnil, pa imam
- 2019/01 kjer imam pisavo in eno sliko; 2019/02 polno slik in 2019/03 prazno
- elementor/css pa imam polno datotek post-10, post-21, post-305 itd.
Ne bo nič narobe, če bi te mape, ki sem jih downloadal kot backup, samo prenesel v mape C:/wamp64/www/wordpress/wp-content/uploads?
Manager ::
Sem prenesel in mi je vrnilo slike. Je najbolje, da vsebino na C:/wamp64/www/wordpress/wp-content/ po posameznih mapah menjam s to vsebino iz teh .zip bakup map?
Ne bi rad preveč čačkal, ker se ne spoznam preveč na te zadeve.
Manager ::
Hvala vsem za pomoč.
Sedaj stran zgleda, kot je bila pred tem autoptimize pluginom. Edino, malo se mi zdi bolj počasna, kot prej.
Ko pogledam v Chromu, pod Dev Toolbar, mi sedaj kar nekaj datotek data:image/png;base64/... (from memory cache) s časom 0ms?
Zdaj boš začel backupirat, ali še ni bila dovolj dobra lekcija?
Manager ::
Lekcij je bilo kar nekaj med izdelavo c3pO ;) Se strinjam. Amapak sem Backupal z Updraftom na prenosnik (themes, uploads, plugins...) in iz Wampa sql bazo prenel, pa sem mislil, da je dovolj. Potem sem pa ta en vtičnik prenesel, pa se je vse zrušilo.
Zdaj je vse gor, ampa spletna stran se mi ne zdi ista po obnašanju, časi so malo daljši (v Dev toolbaru), pa ko odprem stran v IE ali pa Microsoft Edgu ne scrolla tako lepo stran in nekatere slikice so včasih samo delno vidne, kot male slike, ena manjka včasih, ko refresh dam pa spet naloži. Tako, da nekaj se je verjetno zgodilo s spletno stranjo oz. zeznil sem si nekako sam spletno stran.
Ko pogledam v Chromu, pod Dev Toolbar, mi sedaj kar nekaj datotek pokaže, ki jih prej ni bilo, sicr s časom 0ms, ampak nek pomen verjetno imajo:
- data:image/png;base64... Type - png Size - (from memory cache)
Manager ::
Ko pogledam v Edgu in IE mi zdaj, ko naložim na novo stran celo zmrdano pokaže, vijolično ozadje, medtem ko je v Chrome vredu. Hmmm, zj.... sem vse skupaj očitno.
b3D_950 ::
Pred namestitvijo plugina je dobro prebrat komentarje (negativne najprej).
Lahko da je opisan "revert" postopek kje med komentarji:
https://wordpress.org/support/plugin/au...
Manager ::
Imaš prav. Začetniska napaka, jaz sem kriv, da kar tako nekaj instaliram, kar sem videl nekje, da je ok. Se posebej, ko se dejansko na te stvari ne spoznam. Se ko probam preko updarafta restorati, mi pokaže napake.
Ne vem, če bi rešilo tezavo, da tiste datoteke, ki sem jih imel backupane v zip (themes, plug-ins, uploads...) nadomesti s tistimi, ki so v c:wamp/www/wordpress/wp-content?
b3D_950 ::
Poglej v bazo ( tabela wp_options) ali
https://codex.wordpress.org/Changing_Th...
https://codex.wordpress.org/Database_De...
Če karkoli delaš, delaj direktno na "domeni" brez nekih localhost (v etc/hosts dodaš domeno in ip).
Manager ::
Sedaj sem testiral spletno stran na localhost.
- Ko sem vpisan v Wordpress mi deluje vse ok.
- Ko se izpišem iz Wordpressa in testiram spletno stran v Chrome, pa mi v nekaterih galerijah slikice zmanjša na male.
Sem mislil dati stran danes na net, ampak ne vem, če mi že sedaj na localhostu šteka, kaj bo ko bo online. Previdevam, da nič boljšega.
Saul Goodman ::
nasvet: resno premisli, katere plug-ine potrebuješ in katerih ne nujno. če sem prav opazil, imaš shitload nekih pluginov, ki so ponavadi recept za počasne in luknjaste spletne strani.
Dragi ::
Prvo kar je tvoj problem je, da to delas na wamp. Windows in apache + php so znani po temu, da delajo tezave. Pozeni docker wordpress image, ti bo ponudilo da uporabis lokalno bazo na mariadb. Tako ti v dockerju deluje nginx + redis + whatever rabis za razvijanje in data se ti shranjuje lokalno. Nastavi se htdocs folder v dockerju (external data folder, data) na lokalni folder v windowsih in si zmagal.
Razvijaj tam, bo lazje. Ne bo teh cudnih hecov.
Sicer pa sploh priporocam, da gre vse na vps pa easyengine skripto za lazje postavljanje. za 3$ na mesec dobis 2GB in 20Gb storage, dovolj za vse kar rabis.
  • spremenil: Dragi ()
spegli ::
Saul Goodman je izjavil:
spegli je izjavil:
Zato sem pa predalagal pametnejše.
  • spremenilo: spegli ()
Stari89 ::
I don't want to be that guy, but ...
Zakaj ne uporabljaš nek version control, da se izogneš takim fuckupom? Git čisto lepo laufa z WordPressom. How to Use Git with WordPress
  • spremenilo: Stari89 ()
Blokiranje piškotkov v wp-config.php
Oddelek: Izdelava spletišč
61134 (934) Manager
Wordpress vpis NE GRE - 404 stran
81588 (1337) Manager
[Ubuntu 12.10]Napaden streznik
Oddelek: Omrežja in internet
101553 (1396) Icematxyz
Flash prihodnost spleta? (strani: 1 2 )
Oddelek: Novice / --Nerazporejeno--
5024282 (22621) root987
Zanimiv server LOG
142414 (1982) TheHijacker
