Težave z implementacijo facebook logina
tron123 ::
Poskušam implementirati FB login na spletno stran in sem naletel na težavo. Ta se pojavi že pri demo primeru, ki je objavljen na FB strani - https://developers.facebook.com/docs/fa... (na dnu strani).
<!DOCTYPE html>
<html>
<head>
<title>Facebook Login JavaScript Example</title>
<meta charset="UTF-8">
</head>
<body>
<script>
  // This is called with the results from from FB.getLoginStatus().
  function statusChangeCallback(response) {
    console.log('statusChangeCallback');
    console.log(response);
    // The response object is returned with a status field that lets the
    // app know the current login status of the person.
    // Full docs on the response object can be found in the documentation
    // for FB.getLoginStatus().
    if (response.status === 'connected') {
      // Logged into your app and Facebook.
      testAPI();
    } else {
      // The person is not logged into your app or we are unable to tell.
      document.getElementById('status').innerHTML = 'Please log ' +
        'into this app.';
  // This function is called when someone finishes with the Login
  // Button.  See the onlogin handler attached to it in the sample
  // code below.
  function checkLoginState() {
    FB.getLoginStatus(function(response) {
      statusChangeCallback(response);
  window.fbAsyncInit = function() {
    FB.init({
      appId      : '{your-app-id}',
      cookie     : true,  // enable cookies to allow the server to access
                          // the session
      xfbml      : true,  // parse social plugins on this page
      version    : 'v2.8' // use graph api version 2.8
    // Now that we've initialized the JavaScript SDK, we call
    // FB.getLoginStatus().  This function gets the state of the
    // person visiting this page and can return one of three states to
    // the callback you provide.  They can be:
    // 1. Logged into your app ('connected')
    // 2. Logged into Facebook, but not your app ('not_authorized')
    // 3. Not logged into Facebook and can't tell if they are logged into
    //    your app or not.
    // These three cases are handled in the callback function.
  // Load the SDK asynchronously
  (function(d, s, id) {
    var js, fjs = d.getElementsByTagName(s)[0];
    if (d.getElementById(id)) return;
    js = d.createElement(s); js.id = id;
    js.src = "https://connect.facebook.net/en_US/sdk.js";
    fjs.parentNode.insertBefore(js, fjs);
  }(document, 'script', 'facebook-jssdk'));
  // Here we run a very simple test of the Graph API after login is
  // successful.  See statusChangeCallback() for when this call is made.
  function testAPI() {
    console.log('Welcome!  Fetching your information.... ');
    FB.api('/me', function(response) {
      console.log('Successful login for: ' + response.name);
        'Thanks for logging in, ' + response.name + '!';
</script>
  Below we include the Login Button social plugin. This button uses
  the JavaScript SDK to present a graphical Login button that triggers
  the FB.login() function when clicked.
<fb:login-button scope="public_profile,email" onlogin="checkLoginState();">
</fb:login-button>
<div id="status">
</div>
</body>
</html>
Če v FB nisem prijavljen, se lahko brez težav preko login gumba na strani (se odpre login prompt > potem še permissions prompt). V primeru, da sem pa na FB že prijavljen, a še nisem potrdil pravic in se torej poskusim prvič prijaviti preko gumba na strani, pa se "prompt" za potrditev FB pravic ne odpre in se zato niti ne morem prijaviti.
Ve kdo v čem je težava?
AndrejS ::
Si to nastavil pravilno ?
tron123 ::
Seveda, zgoraj sem le copy-pastal demo kodo iz fb strani.
Arduino in luči (strani: 1 2 )
9814764 (12390) FX6300B
[js] json kompresija
Oddelek: Programiranje
225262 (4611) infiniteLoop
[jquery] .append
211248 (1075) korenje3
AJAX neznana težava
81562 (1356) luksorzi
[Ajax in Java] v IE6 dela, v Firefoxu ne
242325 (2079) krho
