Kolesarske dirke - Giro, Tour, Vuelta+
nokken ::
Kar se mene tice Roglic realno nima nobene moznosti ne proti Pogacarju ne proti Vingegaardu in ne proti Evenepoelu. No mogoce proti Evenepoel se nekaj malega, proti Pogacarju in Vingegaardu pa ce gre vse ok in nekdo ne zboli ali se razbije na kaksnem ovinku, realno nima nobenih moznosti.
Kar pa se Gira tice je pa tole letos bolj drugorazredna dirka. Ce so glavni konkurentje Thomas, Martinez in O'Connor potem to precej pove o sami kvaliteti in Pogacarju niti ni treba biti iz drugega planeta da izgleda kot da je. Od vseh teh je Pogacar zares za dva razreda boljsi in se zato tudi lahko dela norca iz vseh medtem ko izgleda, kot da je sel na krajsi kolesarski izlet. Kaj bo na Touru bomo videli, ampak glede na poskodbo Vingegaarda imam obcutek da bo precej podobno kot tule.
Samael ::
Če dobi še Tour bi znalo biti pa zanimivo ugibati, če bo šel še na Vuelto.
Mislim, da še nihče ni dobil vse tri GT-je v eni sezoni oz. moj "pogovor" s ChatGPTjem pravi sledeče (zgolj kot komičen intermezzo)
Has anyone ever won all three Grand Tours in the same season?
No cyclist has ever won all three Grand Tours (the Giro d'Italia, the Tour de France, and the Vuelta a Espa?a) in the same season. Winning even one of these prestigious races is a remarkable achievement, and taking all three in a single year would require an extraordinary level of endurance, skill, and consistency over a period of several months.
The closest anyone has come to this feat is Eddy Merckx, who in 1974 won both the Giro d'Italia and the Tour de France and finished second in the Vuelta a Espa?a.
Are you sure regarding vuelta?
You are right; I made an error regarding Eddy Merckx's achievements. Eddy Merckx did not finish second in the Vuelta a Espa?a in 1974, as he did not participate in the Vuelta that year. He did, however, win the Giro d'Italia and the Tour de France in 1974.
In terms of winning all three Grand Tours, no cyclist has achieved this feat within the same season. Eddy Merckx, Bernard Hinault, and Chris Froome are among the few who have won all three Grand Tours during their careers, but not within a single year.
Thank you for pointing out the need for clarification.
Hecna ta zadeva... AI.
Samael != Samuel
Zimonem ::
Hauptman pove na podkastu številke, da je treba najprej preživeti Giro. Potem se bo pa videlo , kako se spočit in naprej trenirat. Na vuelto trenutno nihče ne misli.
https://www.rtvslo.si/stevilke/andrej-h...
Bodo pa precej vplivale tudi zasedbe za tdf. Bora je na papirju močna. Ampak Martinez na klancih ostaja sam po odstopu lipowica.
O višini vemo bolj malo.
Pa še OI so in nekatere vleče tja.
Pa seveda tudi vreme, Tadej ni ravno ljubitelj vročine.
  • spremenilo: Zimonem ()
Samael ::
Kaj da ne! Jaz mislim :P
Pa Tadej tudi najbrž tam nekje globoko v sebi.
Ampak okej, dajmo resno ... to tu so samo forumske debate, špekulacije, ugibanja, želje. Pač debatiramo tu. Jasno, da je za kakšno resno razmišljanje o Vuelti še krepko prezgodaj (saj še Gira ni konec, kje je potem še Tour...), omenil sem samo hipotetično v kontekstu forumske debate - kar je pa tudi iz napisanega najbrž razvidno, a?
Samael != Samuel
  • spremenilo: Samael ()
Zimonem ::
Poslušej podkast. Sicer lohk tud sanjamo o porno zvednicah.
Samael ::
Daj nehaj moriti :) Zgrešil si bistvo.
Saj vema obadva, kako pa kaj - bila je samo izražena misel glede hipotetične situacije, nič okoli česa bi kdo delal big deal, da je treba zdaj pojasnjevati in se vrteti okoli tega.
Samael != Samuel
Če dobi giro in tour bo stoprocentno šel tudi na vuelto, škoda sploh kaj debatirat o tem.
mikhaair ::
Ampak, ali ima Pogi sploh realno konkurenco na Tdf, morebitne težave, poškodbe, pustimo ob strani? Vinge ni sans da bo vsaj približno v formi, Primož bo moral res vse presenetiti, Remco?
Samael ::
Jah, saj vemo kako je. V tem momentu najbrž ni kolesarja, ki bi vozil na njegovem nivoju, tako da je kot si rekel. Nepredvideni dogodek ... nekaj izjemnega bi se moralo zgoditi, da nekdo preseneti. Se pa presenečenja na GT-jih dogajajo ane.
Samael != Samuel
hunter01 ::
Samael je izjavil:
V bistvu je Froome to "uspel" in hkrati ni uspel. Dobil je vse 3 zapored, vendar ne v isti sezoni :-)
2017 Tour in Vuelto
2018 Giro
Mogoče je še komu zaporedno to uspelo?
Samael ::
To jih je bilo verjetno malce več.
Sem pogledal za Merckxa, za katerega zgoraj piše, da je dobil 1974 Tour in Giro, če je slučajno leto pred tem ali zatem dobil Vuelto, pa je res 1973 dobil Vuelto, ampak oboje kar navajama sta še vedno dve sezoni - torej ni ravno enako, kot dobiti vse tri GT-je v eni sezoni, kar ni uspelo še nikomur :)
Samael != Samuel
mikhaair ::
Če smo že pohlepni in pametujemo, pol je letos možen zlati (v tenisu je zlati Grand Slam) 3+1. Trojček + zlata OI.
mikhaair je izjavil:
Roglič vs. Thomas Giro 23
vs.
Pogačar vs. Thomas Giro 24
vs
Pogačar vs. Roglič Tour 24
Ali je Thomas toliko slabši letos ali Pogi iz druge dimenzije in ali ima Roglič realne možnosti proti Pogačarju?
Dober je, pa še toliko mlajši... Thomas je skoraj 40...
Pa se mi zdi, da mu vedno manjka en mali košček, da bi bil lahko zmagovalec. Meni dober, simpatičen kolesar, ampak malo mu zmanjka. Kot recimo Landa...
val46 ::
Ja, dejmo bit požrešni, pa še naslov svetovnega prvaka dodajmo zravn ;)
Ampak ne, bodimo realni. Prvo naj pripelje Giro do konca, ja pripelje, ker napadat mu res ni več potrebe. Pol je tu tour, kjer po vsem videnem, pa če vzamemo v kontekst še tisti padec največjih rivalov na Baskiji in pri predpostavki, da se res dobro regenerira po Giru, tudi tam ne vidim neke konkurence. Za OI jaz nanj pa vseeno ne bi stavil. Je tista trasa okrog Pariza prelahka za njega. Dosti dosti bolj mislim da se bo po touru osredotočil na svetovno prvenstvo v Švici, kot pa same olimpijske igre. Je tudi sam to že povedal, da mu mavrična majica pomeni precej več kot še ena olimpijska medalja. Sploh ker je letos prvenstvo v Švici in je trasa kot narisana za njegov tip kolesarja. Sam priznam, da če pride tja v formi in ne bo kakih nepredvidenih zadev, bom razočaran, če ne bo prvak. Pa kolikor poznam njega, bo tudi on sam.
Tko da, Vuelta...ne vem, mislim da se ji letos bo odpovedal, ker mu je mavrična majica resnično velik cilj in bo po touru in morda OI, res posvetil priprave na svetovno prvenstvo. Pa še nekaj je treba razumet. V UAE ni sam...in imajo še kakega kapetana, ki si sigurno želi dirkat tudi za svoj rezultat, ne da bodo celo leto sam zanj delali na tri tedenskih dirkah. Tko da, morda to niti ni pametna ideja za klimo v ekipi.
nokken ::
Invictus je izjavil:
No ja zmanjkalo mu je toliko malo da je vseeno zmagovalec TdF (o dirkaliscu je pa brez veze izgubljati besede, glede na to da je bil eden najboljsih v zgodovini in je osvojil dobesedno vse kar se je na stezi dalo osvojiti)
mikhaair ::
Druga stran medalje pa je, da bi kakšen krat as kot je Pogi, se lahko malo držal nazaj. Kot npr. etapa par dni nazaj, ko bi lahko prepustil zmagi Italijanu iz male ekipe, Pelizzari al kako že. Mala ekipa, kateri zmaga na GT pomeni celo sezono. Iz takih ekip gredi fantje v WT ekipe, tudi oni rabijo sponzorje, še bolj dejansko.
Alla italiana, kar je Pogiju všeč, so tudi nenapisana pravila, kolesarska romantika, saj je super simpatičen, kakšen krat bi lahko bil še bolj.
Zmage se ne pušča.
To lahko naredi samo totalen kreten.
Gambino ::
Vinko bo vseeno favorit, zaenkrat še ni človeka, ki bi dokazal, da je na TdF kdo boljši od njega. Če bo pripravljen, potem bo prišel na TdF, če ne ga ne bo!
nokken ::
Ko enkrat ne dikrajo vec za sopek roz ampak za denar "romantike" pac ni vec. Poglej koliko je v cisto navadnem denarju vredna etapna zmaga (ne sponzorskem itd. ampak cisti cash od nagrade) in to se razdeli med vse v ekipi, katerim na koncu ta znesek precej pomeni (99% ljudi, pa naj bodo kolesarji ali pa mehaniki, maserji itd., v kolesarstvu, tudi pro ekipah, dela za precej mizerne zneske in jim par 1000eur na koncu enega Gira pomeni hudicevo veliko).
dunda ::
Lahko bi se kdaj malo nazaj držal zaradi napornega leta v celoti. Po drugi strani pa - gre za celotno ekipo, ki gara na celi dirki. In če se mu že ponuja možnost zmage (pač v skladu z utrujenostjo/načrti za prihodnost), je po svoje tudi prav, da zagrabi. Zmage se štejejo (tudi) ekipi, prav tako si razdelijo tisti denar in tako prispeva, da pomočniki dobijo nekaj cekinčkov, ki jih sicer ne bi.
Je pa on tak po naravi, da rad tekmuje in v tem uživa, ni naduvan, korekten do sotekmovalcev ... Zato je simpatičen in najbolje, da ga pustijo, dokler to pije vodo.
https://www.kacnje.eu
wcpapir ::
70 let že ni bilo take razlike (bila je 6 in nekaj min) med prvim in drugim mestom v Giro na 15 etapo, on še pa kar navija... nekaj mu je zaškodilo.
Misliš da če bi te 3 tedne samo se pripravljal na tdf pa ne bi niti zašvical?
nokken ::
wcpapir je izjavil:
Mogoce ima pa v planu treninga par intervalov in jih pac naredi. Ce je pa po nesreci to ravno na tekmi in posledicno na tv pa pac pride tako :))
dunda ::
Saj verjetno ima sedajle do TdF idealno za nekaj počitka in treninga po načrtu. Mislim, da je časa dovolj, da se taki asi regenerirajo.
No, bodimo veseli, da imamo takšne debate. Sedaj se dajemo okrog tega ali naj zmaga ali prepušča konkurenci. To so res sladke skrbi.
one too many ::
Samael je izjavil:
Vuelte so bile včasih ne povsem tritedenske dirke in tik pred Girom. Šele od 199x je Vuelta avgusta. Zato dvojček Tour-Vuelta in še posebno Giro-Vuelta nima take teže, ker ni primerjave z legendarnimi kolesarji.
Samael ::
Tega pa res nisem vedel - zanimiva informacija.
To je bilo še pred mojim časom interesa za kolesarstvo, ki se je iz čisto osebnih okoliščin po spletu naključij pojavilo (pa za nekaj časa tudi kmalu izzvenelo) tam od sredine 199x s teamom ONCE (pozneje Liberty Seguros, danes Astana) oz. Jalabertom (ja vem, lahko bi izbral bolje... :), ki je vozil isto znamko kolesa, kot je bilo takrat moje povsem novo kolo :)
Samael != Samuel
mikhaair ::
Na Bernala smo že vsi pozabili.
Gre na Tdf? Od nesreče dalje se njegova forma le vzpenja.
Samael ::
Ja, je načrtovan za TdF. Ineos še nima objavljene kompletne ekipe za Tour, so pa trenutno na startlisti:
INEOS Grenadiers (WT)
-PIDCOCK Thomas
-THOMAS Geraint
-RODRÍGUEZ Carlos
-KWIATKOWSKI Michał
-BERNAL Egan
Samael != Samuel
nokken je izjavil:
Ja, sam zdaj je že malo star. Čeprav še vedno zelo dober. Svaka mu čast. Mi je simpatičen, pa še malo se zna pohecat...
Nima sreče na Giru, že drugo leto ga bo zajebal Slovenec :).
Mogoče drugo leto, če se kakemu Slovencu spet ne utrga...
val46 ::
Ja, drugo leto bo šel Primož nazaj na Giro najbrž. Še posebno, če tam ne bo Tadeja. Pol pa še v Švico, tko da če že toura ne bo imel osvojenega, bo vsaj zapisan v zgodovino, kot prvi, ki je osvojil vse najpomembnejše enotedenske dirke. Pa upam da se naslednje leto res vrne Giro za kak dan/dirko na slovensko ozemlje.
mikhaair ::
Ravno prižgem tv in kaže padec Andree Piccola...in gleda dlani, s katerimi drsal po tleh, brez rokavic! Meni se ta moda brez rokavic zdi takoooooo nesmiselna.
gusto ::
Jaz tudi ne razumem, kako lahko vozijo brez rokavic. Zadnjič sem šel po 5ih letih za foro probat brez rokavic, ker sem šel eno kratko razpeljavo. Takoj ko malo zašvicaš v roke, sploh nimaš več dobrega oprijema, balanca kar drsi iz rok, pa imam gor kvaliteten trak. Poleg tega pa še to, na kar si ti ciljal - zaščita pri padcih.
Have you tried turning it off and on again?
wcpapir ::
Prav patetično je gledati navijače Pogačarja, čez 5, 10 let pa ne bodo priznali, da so kdja spremljali kolesarstvo :D
Badwolff ::
GodoBoy ::
Ignore idiota bo nartabolš
blink ::
Tole je bilo res tri tedne odlicne predstave Pogacarja in UAE ekipe: 9:57 min prednosti (druga najvecja na Giru ever), 6 etapnih zmag, najvisja povprecna hitrost na Giru ever, roza majica od 2 etape dalje, modra majica.
Lahko smo veseli, da v zivo spremljamo Slovenca ki pise kolesarsko zgodovino in se ga primerja z legendami kot Merckx. Jutri zakljucek, cez dober mesec pa ze TDF!
gusto ::
Giro totalno v znamenju Pogija, nobeden mu ni bil niti blizu, delal je kar je hotel. Prevlada za zgodovino.
A kdo ve, kako lahko gledam The breakaway show na Eurosportu. Imam subscription, pa lahko gledam samo kratke clipe po par minut, ki se mi pojavijo v feedu. Nikjer ne najdem celih oddaj. Včasih je to bilo na voljo (vsaj ko sem imel GCN+). Kakšna fora s pravicami? Eurosport je lepo zjebal sceno drugače, GCN+ app je bil bistveno boljši, cenejši, še z dodatnimi vsebinami. Eurosport app pa je ena polomljena aplikacija, ki se jim je niti ne da preveč razvijat, ker imajo monopol in brez konkuence lahko delajo kar hočejo.;(
blink ::
Zmagovalno kolo
Samael ::
Ko smo ravno debatirali pred dnevi na to temo, se je zdaj oglasil tudi Tadej:
Za Tadejem Pogačarjem so sijajni trije tedni, v katerih je upravičil vlogo glavnega favorita na dirki po Italiji in suvereno prišel do rožnate majice. Do začetka Toura (29. junija) ne bo več nastopal, njegov koledar po francoski pentlji pa še ni povsem jasen. Številni so namigovali, da bi utegnil v primeru zmage v Franciji nastopiti tudi na zadnji tritedenski dirki sezone v Španiji, kar pa je slovenski šampion že zanikal.
Sliši se fantastično, a nekaj so želje, drugo je realnost, je na cilju dirke po Italiji v Rimu poudaril tudi sam. "Lahko vam zagotovim, da trojček ni na mojem programu v tej sezoni," je nosilec rožnate majice povedal v intervjuju za Eurosport. "Seveda je eden mojih glavnih ciljev, da bi dobil vse tri Grand Toure, ampak da bi mi to uspelo v isti sezoni, je morda preveč noro."
Vir: https://www.24ur.com/sport/kolesarstvo/...
Samael != Samuel
Jaz bi stavil vsaj 50 evrov, da če dobi tour, gre na vuelto.
mikhaair ::
Če dobi TdF bo Vuelta polna GT contenderjev, ki bodo reševali sezono. Primož, Vinge, Remco.
hunter01 ::
Verjetno je tudi to vzrok, da še nikoli noben v isti sezoni ni dobil vseh treh. Ker se že na dveh utrudi, na tretji so pa vsi preostali, ki rešujejo sezono še bolj napaljeni :)
dunda ::
Za nameček sta zraven še svetovno prvenstvo in olimpijske igre. Brez tega bi si mogoče (ob uspehu na TdF) še premislil.
Lepe stvari sanjamo, kar preveč.
Zimonem ::
Utk je izjavil:
Daj preberi si članek. Med drugim piše, da se z zgodovino ukvarjajo zgodovinarji.
Kaj si naj preberem? To bo mlel v glavi do toura in cel tour, in celo poletje od toura naprej. Tudi Roglič je že šel neplanirano na vuelto in zmagal, pa da ne bi mogel Pogačar. Kaj se bo zgodilo na njej je druga stvar, ampak da tak killer ne bi niti poskusil, ne verjamem.
val46 ::
Ma ni problem tle da ne bi poskusil, tudi dobit bi jo znal. Bolj je problem tu, da obstajajo še druge dirke, ki jih Pogi želi dobit. Konkretno svetovno prvenstvo, na katerem mu je trasa pisana na kožo letos. Pa OI, na katerih ima sicer bolj malo možnosti glede na traso, ampak pri njemu nikoli ne veš. Tudi Milano-Sanremo mu ni, pa je bil že 2x precej blizu. Pa ne me razumet narobe, tudi sam si želim, da bi šel na Vuelto, seveda ob predpostavki, da dobi tour, ampak eno so naše želje, drugo pa realnost. V bistvu si sam želim samo eno stvar...da gre tja, kjer si sam želi in se na tisto maximalno pripravi, ne pa da gre tja, kamor si želi javnost, sam zato, ker so novinarji in taki kot smo mi to od njega "zahtevali". Nikakor nočem, da bi se pri 25ih letih "prekuril" in bi se mu kolesarjenje zamerilo do te mere, da bi hodil na dirke sam še zato, da gre tja. Ampak da dejansko gre tja kjer si želi in tam da od sebe vse kar ima. Pa naj bo to en, dva ali pa trije GT. V tisti mavrični majici bi pa tudi lepo zgledal naslednje leto :)
Normalno, ampak svetovnih prvenstev bo še veliko, šanse za 3 toure v enem letu pa morda več nikoli. To sigurno mleje v glavi tudi on.
  • spremenil: Utk ()
TOUR DE FRANCE : tout peut arriver.
Zimonem ::
https://vizita.si/dusevnost/kaj-je-proj...
Tadej nebi v 228 nastopih dosegel 77 zmag če nebo bil realen.
72 / 122
