OpenVPN
OpenVPN
OvCa77 ::
Živijo,
ostal sem brez idej ob postavljanju VPNja. Imam 2 routerja, na drugem teče OpenVPN server. Če forwardam katerikoli port je port zaprt. Ima kdo kakšno idejo?
Laptop: Probook 440 G3 | i5-6200U | 12GB DDR3L | SSD Plus 240GB
Desktop: Ryzen 1600X | Gigabyte AX370 K3 | 8GB DDR4 | MX100 256GB
BivšiUser2 ::
Se je kaj pri postavljanju OpenVpn spremenilo?
Praktično sem zagnal skripte na strani https://openwrt.org/docs/guide-user/ser... , kjer sem samo spremenil
wanIP="dynamic.dns.name"
na
wanIP="moj.ddns.net"
Trouble shooting sem že pognal, ni pa videti, da je kaj napačno. Router je priklopljen na Telesmeh Router+Modem. Ovpn file:
client
dev tun
proto tcp
fast-io
remote jazz.ddns.net 1194
remote-cert-tls server
nobind
persist-key
persist-tun
comp-lzo on
verb 7
key-direction 1
<ca>
-----BEGIN CERTIFICATE-----
-----END CERTIFICATE-----
</ca>
<cert>
</cert>
<key>
-----BEGIN PRIVATE KEY-----
-----END PRIVATE KEY-----
</key>
<tls-auth>
# 2048 bit OpenVPN static key
-----BEGIN OpenVPN Static key V1-----
-----END OpenVPN Static key V1-----
</tls-auth>
Logi:
Mon Jun 25 14:56:40 2018 OpenVPN 2.4.4 mips-openwrt-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD]
Mon Jun 25 14:56:40 2018 library versions: OpenSSL 1.0.2k  26 Jan 2017, LZO 2.09
Mon Jun 25 14:56:40 2018 NOTE: your local LAN uses the extremely common subnet address 192.168.0.x or 192.168.1.x.  Be aware that this might create routing conflicts if you connect to the VPN server from public locations such as internet cafes that use the same subnet.
Mon Jun 25 14:56:40 2018 TUN/TAP device ovpns0 opened
Mon Jun 25 14:56:40 2018 do_ifconfig, tt->did_ifconfig_ipv6_setup=0
Mon Jun 25 14:56:40 2018 /sbin/ifconfig ovpns0 192.168.200.1 netmask 255.255.255.0 mtu 1500 broadcast 192.168.200.255
Mon Jun 25 14:56:40 2018 Could not determine IPv4/IPv6 protocol. Using AF_INET
Mon Jun 25 14:56:40 2018 UDPv4 link local (bound): [AF_INET][undef]:1194
Mon Jun 25 14:56:40 2018 UDPv4 link remote: [AF_UNSPEC]
Mon Jun 25 14:56:40 2018 Initialization Sequence Completed
Configi so praktično tiste skripte na strani oz. prirejeni po trobleshootingu.
SloTech - če nisi z nami, si persona non grata.
BivšiUser2 ::
Po nekem drugem tutorialu pridem do errorja
openssl req -out ca/csr/vpn-server.csr -new -days 3650 -sha5
12 -newkey rsa:2048 -keyout openvpn/vpn-server.key.pem -config ./openssl.cnf -ex
tensions v3_vpn_server -nodes
<strong>Error Loading extension section v3_vpn_server</strong>
. Res noben ne ve?
OpenVPN na DD-WRT
Oddelek: Omrežja in internet
91259 (1056) ExSpirit
OpenWRT in OpenVPN (strani: 1 2 )
7913110 (10970) BivšiUser2
OpenVPN odjemalec na Mikrotiku?
92376 (2168) noraguta
Težave z OpenVPN povezavo (strani: 1 2 )
6211665 (8561) čuhalev
Openvpn (strani: 1 2 )
Oddelek: Programska oprema
6518630 (10197) Blisk
