Forum » Operacijski sistemi » FreeBSD znalci
FreeBSD znalci
Mahagonij ::
Živjo,
Mi lahko kdo priskoči na pomoč, ker sem začetnik v FreeBSD svetu.
Rad bi inštaliral DNS server unbound, vendar konstantno dobivam error, da se velikost paketa ne ujema.
Probal sem narediti update paketov, kjer pravtako dobim error
internetna povezava deluje
Probal sem tudi namestiti samo sporni txtinfo
OS je v bistvu FreeNAS, inštalacijo pa delam v svojem jailu.
texinfo.tex: size mismatch: expected 380556, actual 382193
root@unbound:/usr/ports/dns/unbound # pkg update -f
Updating FreeBSD repository catalogue...
[unbound] Fetching meta.txz: 100% 944 B 0.9kB/s 00:01
[unbound] Fetching packagesite.txz: 100% 1 MiB 16.6kB/s 01:10
pkg: http://pkg.FreeBSD.org/freebsd:11:x86:6... Operation timed out
Unable to update repository FreeBSD
Error updating repositories!
root@unbound:/usr/ports/dns/unbound # ping google.com
PING google.com (172.217.23.238): 56 data bytes
64 bytes from 172.217.23.238: icmp_seq=0 ttl=57 time=28.489 ms
64 bytes from 172.217.23.238: icmp_seq=1 ttl=57 time=27.599 ms
64 bytes from 172.217.23.238: icmp_seq=2 ttl=57 time=27.589 ms
64 bytes from 172.217.23.238: icmp_seq=3 ttl=57 time=27.694 ms
root@unbound:/usr/ports/dns/unbound # pkg install texinfo
FreeBSD repository is up to date.
All repositories are up to date.
Updating database digests format: 100%
New version of pkg detected; it needs to be installed first.
The following 1 package(s) will be affected (of 0 checked):
Installed packages to be UPGRADED:
pkg: 1.10.1 -> 1.10.4
Number of packages to be upgraded: 1
3 MiB to be downloaded.
Proceed with this action? [y/N]: y
[unbound] [1/1] Fetching pkg-1.10.4.txz: 100% 1 MiB 20.0kB/s 01:18
http://pkg.freebsd.org/freebsd:11:x86:6...
Ta URL si sprobal, če ti ga sploh odpre na dotični kišti? Probaj s curl ali wget.
Mahagonij ::
wget nimam inštaliran in ga tudi ne znam, ker dobivam pri inštalaciji istit error kot pri unbound.
curl, pa dobim samo čudne znake ko vpišem
root@unbound:/usr/ports/dns/unbound # curl http://pkg.freebsd.org/freebsd:11:x86:64/latest/packagesite.txz
????h?F!t/??~???]8H??u&???y
??Z??ɝl?]?]6????n?K???][p?3"O?%?V<?B????>?į?X?8?{Q?\!?$Gd˘?????Q?`?\}IǸZv??K???`?^?qn?????`?'/????M??oQH?3?;?@r:+???8?}?K?y??<?????+?]_f?ֹ?W(??ߑ6?г????gDJ?G
???,.Q{l?,G
noraguta ::
Inštaliraj kako novejšo verzijo. Tole je že "rahlo" arhivska zadeva kar poganjaš.
konspirator ::
Matej
https://www.freebsd.org/doc/handbook/po...
btw, zadnja verzija FreeBSD je 12.
v11 je od 10/2016.
Kaj imaš v /usr/local/etc/pkg.conf in podobnih mestih ? https://forums.freebsd.org/threads/6261...
v11 je od 10/2016.
- spremenilo: konspirator ()
Mahagonij ::
@rokp. Tudi ta komada mi vrže isti rezultat kot sem ga kopiral zgoraj.
@noraguta. Zadevo laufam v svojem jail na FreeNAS 11.1, ki naj bi bil zadnja stabilna verzija. Ali lahko naredim samo posodobitev FreeBSDja v jailu? Sem popoln začetnik tako, da verjetno pišem in sprašujem neumnosti.
@konspirator.
OK, unbound in wget sem uspel inštalirat. Vse skupaj je zelo čudno. Rešil sem tako, da sem večkrat probal pkg install unboud in je enkrat šla zadeva skozi.
Potem sem za test naredil še en jail, kjer inštalacija ponovno ne deluje ker javlja isti error
Če mi, kdo zna razložit kaj je za to krivo bom prav vesel. Jaz sumim samo še slab NIC, ali kateri drugi kos omrežne opreme, ki povzroča izgubo paketov? Lahko bi bila težava tudi na njihovem serverju sam potem verjetno DL paketov nebi deloval tudi na mojem računalniku. Morda je lahko kriv torrent klient, ki teče v drugem jailu?
V glavnem ura je pozna, za danes bom zaključil. Inštalacija je uspela skupaj z vašo pomočjo. Hvala. Zdaj pa še konfiguracija.
@konspirator.
# System-wide configuration file for pkg(8)
# For more information on the file format and
# options please refer to the pkg.conf(5) man page
# Note: you don't need to have a pkg.conf file. Many installations
# will work well with no pkg.conf at all or with an empty pkg.conf
# (other than comment lines). You can also override any of these
# settings from the environment.
# Configuration options -- default values.
#PKG_DBDIR = "/var/db/pkg";
#PKG_CACHEDIR = "/var/cache/pkg";
#PORTSDIR = "/usr/ports";
#INDEXDIR = "";
#INDEXFILE = "INDEX-10"; # Autogenerated
#HANDLE_RC_SCRIPTS = false;
#DEFAULT_ALWAYS_YES = false;
#ASSUME_ALWAYS_YES = false;
Mahagonij ::
root@unbound:/ # ls
.cshrc COPYRIGHT libexec rescue tmp
.profile dev media root usr
bin etc mnt sbin var
boot lib proc sys
root@unbound:/ # cd usr
root@unbound:/usr # cd
root@unbound:~ # ls
.cshrc .history .k5login .login .profile
root@unbound:~ # exit
exit
root@freenas:~ # jexec 10
root@unbound:/ # ls
boot lib proc sys
root@unbound:/ #
Še eno vprašanje, ker ste ravno poznavalci v temi.
S komando jexec 10 odprem unbound jail. ls mi pokaže mape, cd usr me postavi v mapo usr. cd me prestavi nazaj na začetek. Ko dam ponovno ls dobim druge mape kot ob prvem ls. Če grem ven iz jaila in ponovno nazaj so mape spet prikazane?
Podvprašanje, kakšna je ekvivalentna komanda za cd.. iz dosa. Sepravi samo eno mapo nazaj?
Hvala
| » | Visok ping ob določeni uri? (Amis)Oddelek: Pomoč in nasveti | 1821 (1666) | čuhalev |
| » | Najmanjši ping v 100Mbit in 1000Mbit omrežjih.Oddelek: Omrežja in internet | 3084 (2575) | gumby |
| » | Linux in internetOddelek: Operacijski sistemi | 2079 (1915) | zee |
| » | ping www.klimahit.siOddelek: Omrežja in internet | 2396 (2099) | suse80 |
| » | ADSL vs kabelOddelek: Omrežja in internet | 3198 (2417) | Jinxy |
