Forum » Problemi človeštva » Moška plodnost v prostem padu
[D]emon ::
Scaramouche je izjavil:
Ne, ti se oklepas statisticnih anomalij. Genetske predispozicije so en, zelo majhen delcek, celotne slike.
Potem ne boš imel problem predstaviti to sliko, kot vidim imaš!
Na svetu je sedem miljard in se pljunek ljudi (ali tam nekje). Kaksen promil le-teh je vrhunskih atletov ? In kaksen promil le-teh ima genske predispozicije ? Stevilka hitro upade na statisticno zanemarljivo.
Kot sem rekel, oklepas se statisticnih anomalij, ki jih jemljes za sveti gral genetike. Nekje v isti kategoriji kot tisti tepci, ki pravijo, da so moski fizicno mocnejsi od zensk.
Scaramouche ::
ti si šel stran od teme, pričakovano, daješ not celo populacijo, mi govorimo o tem ali je to dedno pri ljudeh ki so imeli več fizične aktivnosti in ali oni dajejo ven več atletov, kar je pri NFL,NBA,atletiki več kot očitno! Dokazali nisi nasprotno da i geeki in ljudje ki stoletja niso delali večje fizične aktivnosti njim parirali!
glede žensk vs moški so pa moški povprečno močnejši ker imamo več povprečno testosterona, zdaj si pa šel full retard!
Females in general have lower total muscle mass than males, and also having lower muscle mass in comparison to total body mass;[32] males convert more of their caloric intake into muscle and expendable circulating energy reserves, while females tend to convert more into fat deposits.[33] As a consequence, males are generally physically stronger than females.
Sex differences in human physiology @ Wikipedia
https://www.ncbi.nlm.nih.gov/pubmed/847...
Strength and muscle characteristics were examined in biceps brachii and vastus lateralis of eight men and eight women. Measurements included motor unit number, size and activation and voluntary strength of the elbow flexors and knee extensors. Fiber areas and type were determined from needle biopsies and muscle areas by computerized tomographical scanning. The women were approximately 52% and 66% as strong as the men in the upper and lower body respectively. The men were also stronger relative to lean body mass. A significant correlation was found between strength and muscle cross-sectional area (CSA; P < or = 0.05). The women had 45, 41, 30 and 25% smaller muscle CSAs for the biceps brachii, total elbow flexors, vastus lateralis and total knee extensors respectively. The men had significantly larger type I fiber areas (4597 vs 3483 microns2) and mean fiber areas (6632 vs 3963 microns2) than the women in biceps brachii and significantly larger type II fiber areas (7700 vs 4040 microns2) and mean fiber areas (7070 vs 4290 microns2) in vastus lateralis. No significant gender difference was found in the strength to CSA ratio for elbow flexion or knee extension, in biceps fiber number (180,620 in men vs 156,872 in women), muscle area to fiber area ratio in the vastus lateralis 451,468 vs 465,007) or any motor unit characteristics. Data suggest that the greater strength of the men was due primarily to larger fibers. The greater gender difference in upper body strength can probably be attributed to the fact that women tend to have a lower proportion of their lean tissue distributed in the upper body.(ABSTRACT TRUNCATED AT 250 WORDS)
[D]emon ::
Edini ki je sel full retard si ti.
Unknown_001 ::
Facepalm... tema je postala bedna.
I am bored, I am out. No razen če bo namest krega glede banalnosti spet kaj zanimivga.
Begabt
Begabt
vostok_1 ::
Jz tudi ne vem o čem se tista dva kregata. Rasa in šport, je široka tema, predlagam da se odpre novo. Čeprav dvomim da bo komisija odobrila.
There will be chutes!
It came from the lab.
- spremenil: vostok_1 ()
Scaramouche ::
Jz tudi ne vem o čem se tista dva kregataSaj se ne kregata. Scaramouche trdi neumnosti, [D]emon ga pa poskuša izobraziti, neuspešno.
hvala zmagal sem, nisi podal raziskav ki bi trdile nasprotnoSaj si ti podal raziskave, ki trdijo nasprotno.
Scaramouche ::
Model trdi Nekje v isti kategoriji kot tisti tepci, ki pravijo, da so moski fizicno mocnejsi od zensk.
Mogoče boš pa ti potrdil da je to res..
Mogoče boš pa ti potrdil da je to res..Hja, bodisi ti nisi moški, ali pa moški niso fizično močnejši od žensk.
Unknown_001 ::
Narobe je trditi, da so močnejši.
Imamo pa za to boljše preddispozicije. Končni rezultat je odvisen od posameznika.
Begabt
Begabt
- spremenilo: Unknown_001 ()
Scaramouche ::
Unknown_001 je izjavil:
Imajo pa za to boljše preddispozicije. Končni rezultat je odvisen od posameznika.
Ja sej to je to, predispozicijo imamo povprečno boljšo, ti resnično deluješ bolj neumen vsakič ko več tipkaš.
Sej se noben ne rodi z kupom mišic, vsi morajo trenirati in predispozicija določa tvoj doseg!
Unknown_001 ::
Prej bom dobil potrdilo da sem prifuknen kot ti da si pameten.
Begabt
Begabt
Scaramouche ::
haha, torej ti si prej prfuknen kot jaz pameten.
pa to ne moreš verjet, model je vsakič bolj retard...
Unknown_001 ::
Zaenkrat še nisem dobil potrdila od psihiatra da je z mano kaj narobe. Imam pa potrdilo da je vse v redu od takrat ko sem pridobil orožno dovoljenje.
Begabt
Begabt
| » | "Rasa" in športna sposobnost (strani: 1 2 )Oddelek: Loža | 25640 (24015) | Phantomeye |
