Forum » Problemi človeštva » Global warming
Global warming
![](https://static.slo-tech.com/stili/bel_non_grata.png)
ZaphodBB ::
Pa ne pozabit, kakšno zimo so znanstveniki za letos napovedali pri NOAA
A da naši matematični modeli ne delujejo pri napovedovanju prihodnjega stanja kaotičnih sistemov?
A da, če bi znali napovedovati vreme, bi znali napovedovati borze in bi klimatski znanstveniki lahko zaslužili tam in ne bi rabili nategovat davkoplačevalcev?
A da?
zmaugy ::
Pa ne samo CNN, tudi drugi mediji so to objavili, plačanci eni!
https://www.independent.co.uk/environme...
https://www.theguardian.com/environment...
https://fox61.com/2019/02/01/european-c...
https://www.bbc.com/news/science-enviro...
Zanimivo je tudi, da so tile "znanstveniki" vzeli ravno depopulacijo Amerik v 16. stoletju ne pa veliko večje izgube prebivalsta Evrazije v 14 stol. zaradi kuge. Ali pa depupolacijo celih regij v Aziji zaradi mongolskih invazij v 13. stoletju. Verjetno zato, ker ne moreš obesiti white guilt na te dogodke.
The death and destruction during the 13th century Mongol conquests have been widely noted in both the scholarly literature and popular memory. It has been calculated that approximately 5% of the world's population were killed during Turco-Mongol invasions or in their immediate aftermath.[citation needed] If these calculations are accurate, this would make the events the deadliest acts of mass killings in human history.
Destruction under the Mongol Empire @ Wikipedia
The Black Death is estimated to have killed 30–60% of Europe's total population.[7] In total, the plague may have reduced the world population from an estimated 450 million down to 350–375 million in the 14th century.[8] It took 200 years for the world population to recover to its previous level.
Black Death @ Wikipedia
Napiši pritožbo Mongoliji in kugi.
A da?
Če nek model ni v nulo napovedal temperature mozolja na Trumpovi riti na določen datum v Severni Ameriki, to ne spremeni dejstva, da pozitivna toplotna bilanca planeta pomeni segrevanje.
Lahko mutibariš za neko prehodno obdobje, ampak globalnih dejstev to ne spremeni.
Zdaj če tebi to pomaga živeti, je to ok, samo ne zavajaj še drugih.
- spremenilo: zmaugy ()
Leaker49 ::
Samo ti modeli so zgrešili precej več kot pa za nulo.
Morda je treba zamenjati te znanstvenike katerih prihodnost odvisi od napovedovanja globalnega segrevanja. Ali pa priznati da več kot je ljudi na tem planetu, več bomo nanj vplivali.
- predlagal izbris: madviper ()
zmaugy ::
1. Aha, najboljše da zamenjamo te znanstvenike. Donny je itak naravno nadarjen za znanost, bo kar on povedal.
2. "več kot je ljudi na tem planetu, več bomo nanj vplivali." Hmm, če bi bil zdaj jaz skeptik GW, bi ti nalimal sto grafov, ki bi "dokazovali", da več kot je ljudi na planetu, manj vplivajo. To namreč skeptiki počnete, tale citirana je pa seveda logična. Leta 1804 je bilo ljudi eno milijardo, danes jih je skoraj 8. Plus drastičen dvig standarda.
Leaker49 ::
Te bom opomnil na to ko boš drugič jokal kako smo belci uničili planet pa iztrebili vse živali.
- predlagalo izbris: zmaugy ()
![](https://static.slo-tech.com/stili/avatar_gray.gif)
HODL ::
Pa ne pozabit, kakšno zimo so znanstveniki za letos napovedali pri NOAA :)Nismo pozabili, razumemo pa, da se intelektualno izzvani ljudje ne spoznate na številke.
Jaz nimam pojma, bom pa vseeno pravil, da GW obstaja, da izpadem učenjak in PC.
- predlagalo izbris: tikitoki ()
gruntfürmich je izjavil:
ciljaš nase?Zagovorniki lastne osebne svobode na račun osebne svobode vseh ostalih že imate ime: Kreteni.
https://www.theguardian.com/environment... ... down under down under imajo težave potencirane.
Truga ::
https://www.nasa.gov/feature/jpl/huge-c...
Beneath West Antarctica's Thwaites Glacier, NASA JPL researchers found signs of rapid disintegration: a cavity 2/3 the area of Manhattan. It's big enough to have contained 14 billion tons of ice, and most of it melted over the last 3 years.
Rabijo zakonske omejitve in brco v cuzo, če se jih ne drzijo
Leif ::
Lepo, da nadebudni socialisteki priznate, zakaj se gre vse skupaj. Za omejevanje resursov in zapiranje ljudi. Bojda za naše dobro
![:D](https://static.slo-tech.com/smeski/icon_biggrin.gif)
Lepo, da nadebudni socialisteki priznate, zakaj se gre vse skupaj. Za omejevanje resursov in zapiranje ljudi. Bojda za naše dobro![]()
Lepo, da bebcki priznate, da nima pojma o osnovah druzbenih ureditev. Lahko pa si preberes kaj o zakonodaji ZDA, te bo dol vrglo koliko omejitev obstaja, prava socialisticna meka.
Rabijo zakonske omejitveKdo jih bo pa sprejel, če smejo oni zakonodajalce legalno podkupiti?
Problem je tudi horda bedakov, ki se dela, da problemov ni in se derejo o svojih svoboscinah in pravicah. Tako lahko lepo sprejo ljudi in vladajo naprej.
- spremenilo: tikitoki ()
Leif ::
Pričanje prof. dr. Dona Eastbrooka pod prisego pred ameriškim senatom o klimatskih spremembah.
Highlighti:
-trenutno segrevanje se je ustavilo okoli leta 1998
-NASA in NOAA prirejata podatke s selektivnim pobiranjem, daleč najbolj toplo obdobje 20. stol. so bila 30. leta. Z vsakim data adjustom jih nadaljno ohladijo.
-podatki kažejo, da so ekstremni vremenski pojavi v upadu, ne v porastu, kot bi nas radi prepričali alarmisti
-količina CO2 v atmosferi se ne sklada z človeškimi izpusti, videti je da ni povezave
-videti je da dvig CO2 sledi dvigu temperature in ne obratno, v hladnejših oceanih se raztopi več CO2, toplejši ga oddajajo
-oceani imajo pH med 8.2 in 8.1, tudi že bi se v oceanih raztopil ves CO2 iz atmosfere, pH še vedno ne bi padel pod 7, se pravi v kislo
-CO2 je v atmosferi v tako majhni količini (0,04%), da realno nima vpliva na podnebje, to je večinoma odvisno od sončevega outputa in oceanskih tokov
-morska gladin narašča približno 18cm na stoletje in ni videti pospeška. Vse napovedi so se izkazale za napačne.
-vsi klimatski modeli, ki se zanašajo na CO2 so se izkazali brez povezave z realnostjo
-led na Antarktiki se debeli že zadnjih 15 milijonov let, ni videti da se zmanjšuje
ZaphodBB ::
Za razliko od tebe, ki praviš "You are free to do as I tell you!"
Za razliko od tebe, ki praviš "You are free to do as I tell you!"Nekaj drugega pravim, drži pa, da nepismen težko razume prebrano.
- predlagalo izbris: 49106 ()
ProGo ::
ProGo ::
Funkcionalno nepismen bere, a ne razume.
No, dupetov odvetnik, nikjer ni govora o "funkcionalno" nepismenih.
zmaugy ::
ProGo ::
Od kje ti ideja, da se pogovarjam s tabo? Razen če si ti dupe in si ti izjavil "Nekaj drugega pravim, drži pa, da nepismen težko razume prebrano."
zmaugy ::
Nič novega, da nekateri ne razumete narave spletnih forumov. Taki tudi ne razumete naravnih zakonov, ki so v ozadju GW.
Leif ::
ProGo ::
Vse je možno. Gotovo pa je, da tisti, ki zapiše "nepismen težko razume prebrano" ne razume kaj pomeni biti nepismen.
nèpísmen -a -o prid. (ȅ-ȋ) ki ne zna pisati in brati: nepismeni ljudje // slabš. ki kako stroko slabo pozna: na tem področju je popolnoma nepismen nèpísmeni -a -o sam.: organizirali so tečaj za nepismene ♪
Vse je možno. Gotovo pa je, da tisti, ki zapiše "nepismen težko razume prebrano" ne razume kaj pomeni biti nepismen.Mhm, ti, na primer, si nepismen.
Točno tako. Med "nepismenost" sodi tudi to, da izraze razumeš v enem samem, dobesednem pomenu.
ProGo ::
To je tvoja definicija, sskj pravi drugače.
- predlagalo izbris: Truga ()
To je tvoja definicija, sskj pravi drugače.Ne, ne pravi.
// slabš. slabo poznavanje kake stroke: filmska, plavalna, politična nepismenost ?
ProGo ::
Pravi, pravi, samo očitno slabo bereš.
Torej trdiš da tvoja izjava "nepismen težko razume prebrano" pomeni Nepoznavalec kake stroke slabo bere?
Pravi, pravi, samo očitno slabo bereš.Nepismen si:
Torej trdiš da tvoja izjava "nepismen težko razume prebrano" pomeni Nepoznavalec kake stroke slabo bere?Ne, a ker si nepismen, ne moreš razumeti, kaj moja izjava pomeni.
ProGo ::
Pa ti si vrhunski retorik, tvoja sposobnost ponavljanja "Nepismen si" ob očitni logični napaki v tvoji izjavi je presenetljiva.
ProGo ::
Uporabil si besedo "logični". Preveč se naprezaš, to so pretežki pojmi zate.
O, spet odvetnik, sedi 5, dobro si me zabil.
zmaugy ::
Ah, ekstrakt naravoslovnih znanosti se je spet oglasil, si že posadil magični fižol?
Truga ::
O, lej: https://www.theguardian.com/environment...
The world's insects are hurtling down the path to extinction, threatening a "catastrophic collapse of nature's ecosystems", according to the first global scientific review.
More than 40% of insect species are declining and a third are endangered, the analysis found. The rate of extinction is eight times faster than that of mammals, birds and reptiles. The total mass of insects is falling by a precipitous 2.5% a year, according to the best data available, suggesting they could vanish within a century.
The planet is at the start of a sixth mass extinction in its history, with huge losses already reported in larger animals that are easier to study. But insects are by far the most varied and abundant animals, outweighing humanity by 17 times. They are "essential" for the proper functioning of all ecosystems, the researchers say, as food for other creatures, pollinators and recyclers of nutrients.
ZaphodBB ::
> Germoney.
Očitno socializem ni odgovor.
jb_j ::
Najvišje anomalije na aljaski, arabskem polotoku, eu, kitajski in V rusije.
A bi lahko bi skupni imenovalec:
Prudhoe Bay Oil Field is a large oil field on Alaska's North Slope. It is the largest oil field in North America, covering 213,543 acres (86,418 ha)
mogoče niti ne, rafinerije so postavljene drugje:
- spremenil: jb_j ()
jb_j ::
The past five years have been the warmest years in the modern record, and 18 of the 19 warmest years have occurred since 2000.
