Forum » Strojna oprema » Ram upgrade starejšega prenosnika
0x101 ::
Pozdravljeni! Ravnokar sem zelel upgrejdati ram na starejsem prenosniku. Kupil sem 2 kingstonova ploscka (ista serija in vse) jih dam noter in BIOS zazna 8gb rama (prej sem mel 2) ampak ko bootam linux se komp takoj ugasne. Sprobal sem oba ploscka posebi dat not in vsak zase dela v obeh slotih. Probal sem dat not en nov in en star ploscek (en 4gb drugi 2gb) in se zgodi isto, takoj restart. Prenosnik je Acer TimelineX 5820tg. Sploh ne najdem navodil kako resetirat CMOS, vrgel sem baterijo vn ampak nevem ce je delovalo. Je kdo ze kje kaj podobnega videl? Kakšna ideja?
konspirator ::
Lahko da je problem samo v tvoji distibuciji ?
Kako dela live lubuntu/porteus/antiX/memphis ?
Kako dela če daš notri samo 1x nov ram ?
- spremenilo: konspirator ()
0x101 ::
Če je sam 1x nov ram dela v katerem koli slotu. Oba ploscka sem posebi stestiral. Mam Arch ja, bom probal zloadat live buntu.
konspirator ::
Specifikacije novega rama ?
Bios je zadnji ?
http://www.notebookcheck.net/Review-Ace...
dddr3 1.5V 1333 Mhz naj bi bil.
Aces support stran
https://www.acer.com/ac/en/US/content/s...
F2 da prideš v bios.
Bios je zadnji ?
Aces support stran
0x101 ::
Ja nisem dobil drugega pa sem DDR3 1600mhz vzel sam sem se zanasal na to da bios auto downclocka ram, upam da ni to. Morm pogledat ce obstaja kasn custom bios kjer lahko downclockam ram.
konspirator ::
http://community.acer.com/t5/2014-Archi...
After my research, I have found out that acer supports max of 8GB 1333Mhz RAM, i.e. 4GB per slot for my laptop (5830TG).
Also please note the below points
1. Max RAM memory supported by "Intel Core-i5 2410M" is 16GB but acer only recommeds and supports 8GB of RAM
2. The HM65 Express Chipset supports 16GB of RAM but acer only recommends and supports 8GB of RAM
3. The max RAM frequency supported by acer is 1333Mhz, 1600MHz is not supported since the BIOS does not allow you to use it as one guy mentioned in a forum. If you want to use 1600MHz RAM then you need to flash the BIOS which is not the right thing since there will be heat issues and laptop might stop working and it is anyway not tested and certified by acer.
konspirator ::
http://www.bolha.com/racunalnistvo/pomn...
ne vem če delajo, pred morebitnim nakupom preveriš, lahko da ima jabuk ram kakšne posebnosti
0x101 ::
Bom zamenjal na mimovrste za rame z nižjo frekvenco. Očitno BIOS ne downclocka ramov al kaj, obstaja še nek moddan bios kjer so odklenjene nastavitve za napajanje pa frekvenco sam kokr berem forum ma ful folka pol brickan komp ce nastimas napacno kombinacijo nastavitev tko da to je no go. :D Hvala za pomoč
_koki_ ::
Napiši oznako rama, mogoče imaš DDR3L 1.35V rame in so zaradi tega problemi, frekvenca sigurno ni problem, ti rabiš 1.5V...
| » | Pomoc prosim-ram v laptopuOddelek: Strojna oprema | 2294 (1783) | care20 |
| » | Kaj za občasni backup celotnega PC-ja?Oddelek: Kaj kupiti | 3787 (2494) | krneki0001 |
| » | RAM DDR3 in matična MSI G41M-P28 (MS-7592)Oddelek: Kaj kupiti | 2259 (2168) | mtosev |
| » | RAMOddelek: Pomoč in nasveti | 3703 (3206) | BorutK-73 |
| » | Nadgradnja rama in nov SSDOddelek: Kaj kupiti | 5933 (5265) | klinker |
