Forum » Programiranje » Dodajanje \ pri inputu
Excavator ::
Lep pozdrav,
pri selitvi projekta na RPI mi comment box pred znakoma " in ' postavi \.
Data je corruptan že pred uvozom v database, sem preveril..
Če kaj pomaga, pred refreshom strani pokaže \\\" ali \\\', po refreshu pa \' ali \". V databasu ostane druga oblika.
Vem, da bi bilo pametneje uporabiti mysqli, a z mysql funkcijami deluje kot mora..
<?php
ini_set("display_errors",1);
error_reporting(E_ALL);
require_once MODELS_DIR . 'subscribers.php';
class Comments {
public static function getComments( )
$output = null;
$sql = "select * from comments order by comment_id desc";
$query = mysql_query( $sql );
if( $query )
$output = array();
if( mysql_num_rows( $query ) > 0 )
while( $row = mysql_fetch_object( $query ) )
$output[] = $row;
return $output;
//return stdClass Object from the database
public static function insert( $comment_txt , $userId )
//insert data into the database
$comment_txt = mysql_real_escape_string( $comment_txt );
$sql = "insert into comments values( '' , '$comment_txt' , '$userId' )";
if( $query )
$insert_id = mysql_insert_id();
$std = new stdClass();
$std->comment_id = $insert_id;
$std->comment = $comment_txt;
$std->userId = (int)$userId;
return $std;
return null;
public static function update( $data )
public static function delete( $commentId )
$sql = "delete from comments where comment_id=$commentId";
if( $query )
return true;
return null;
?><?php if( isset( $GLOBALS['comments'] ) && is_array( $comments ) ): ?> <?php foreach( $comments as $key => $comment ): ?> <?php $user = Subscribers::getSubscriber( $comment->userId ); ?> <li class="comment-holder" id="_<?php echo $comment->comment_id; ?>"> <div class="user-img"> <img src='<?php echo $user->profile_img; ?>' class="user-img-pic"/> </div> <div class="comment-body"> <h3 class="username-field"> <?php echo $user->first_name?> <?php echo $user->last_name; ?> </h3> <div class="comment-text"> <?php echo $comment->comment; ?> </div> </div> <?php if( $UserId == $comment->userId ): ?> <div class="comment-buttons-holder"> <ul> <li id="<?php echo $comment->comment_id ?>" class="delete-btn">x</li> </ul> </div> <?php endif; ?> </li> <?php endforeach; ?> <?php endif; ?>
<?php
require_once $_SERVER['DOCUMENT_ROOT'] . '/defines.php';
if( isset( $_POST['task'] ) && $_POST['task'] == 'comment_insert' )
$userId = (int)$_POST['userId'];
$comment = mysql_real_escape_string( str_replace( "\n" , "<br>" , $_POST['comment'] ) );
$std->user = null;
$std->comment = null;
$std->error = false;
require_once MODELS_DIR . 'comments.php';
if( class_exists( 'Comments' ) && class_exists( 'Subscribers' ) )
$userInfo = Subscribers::getSubscriber( $userId );
if( $userId == null )
$std->error = true;
$commentInfo = Comments::insert( $comment , $userId );
if( $commentInfo == null )
$std->error = true;
$std->user = $userInfo;
$std->comment = $commentInfo;
echo json_encode( $std );
else
header('location: /');
<?php
session_start();
$connect = @mysql_connect("localhost","root","pass" ) or die("this error");
mysql_select_db("comment_box")or die("filed to connect database");
if(isset($_SESSION['userName'])){
$userName = $_SESSION['userName'];
$password = $_SESSION['password'];
$query = mysql_query("select * from subscribers where userName='$userName' and password='$password' limit 1");
while($row = mysql_fetch_assoc($query)){
$fname1 = $row['userId'];
$fname2 = $row['userName'];
$fname3 = $row['first_name'];
$fname4 = $row['last_name'];
}else{
header("Location: user_login.php");
<?php
if(!isset($_SESSION["userName"])){
header("location:login.php");
} else {
<?php require_once $_SERVER['DOCUMENT_ROOT'] . '/defines.php'; ?>
<?php require_once MODELS_DIR . 'comments.php';
$UserId = $fname1
<html>
<head>
<title></title>
<link rel="stylesheet" href="css/styles.css">
<link href="css/layout.css" rel="stylesheet">
<script type="text/javascript" src="js/jquery.js"></script>
<script type="text/javascript" src="js/comment_insert.js?t=1414315248"></script>
<script type="text/javascript" src="js/comment_delete.js?t=1414315248"></script>
<script src="http://jwpsrv.com/library/kPeNbr6CEeOE1CIACrqE1A.js"></script>
<link rel="shortcut icon" href=".../logo.png">
<script type="text/javascript">
if (screen.width <= 800) {
document.location = "/index8.php";
</script>
</head>
<body>
<div class="wrapper">
<center>
<div id="cssmenu" class="align-center">
<ul>
<li class="active"><a href="index2.php">Home</a></li>
<li><a href="index3.php">About</a></li>
<li><a href="index4.php">Contact</a></li>
</ul>
</div>
</center>
<div style="position:relative; overflow:hidden; left:30px; top:30px; width:693px; height:360px; z-index:0">
<center>
<div id=''></div>
<script type='text/javascript'>
jwplayer('').setup({
file: '',
image: '',
title: '',
width: '635',
height: '365',
aspectratio: '16:9'
</script>
</center>
</div>
<div class="page-data">
</div>
<div class="comment-wrapper">
<h3 class="comment-title">
Welcome, <?php echo $fname3 ?> <?php echo $fname4 ?>! <a href="logout.php" style="text-decoration:none; color:#0099FF;">Logout</a>
</h3>
<div class="comment-insert">
<h3 class="who-says"><span>Says: </span><?php echo $fname3 ?> <?php echo $fname4 ?></h3>
<input type="hidden" id="userId" value="<?php echo $fname1 ?>">
<input type="hidden" id="userName" value="<?php echo $fname2 ?>">
<div class="comment-insert-container">
<textarea id="comment-post-text" class="comment-insert-text"></textarea>
</div>
<div id="comment-post-btn" class="comment-post-btn-wrapper">
Post
</div>
</div>
<div class="comments-list">
<ul class="comments-holder-ul">
<?php $comments = Comments::getComments(); ?>
<?php require_once 'includes/comment_box.php' ;?>
</ul>
</div>
</div>
</div>
</body>
<?php
- spremenil: Excavator ()
Excavator ::
Sem dodal
v /etc/php5/apache2/php.ini file in še vedno ostaja enako..
; Magic quotes ; ; Magic quotes for incoming GET/POST/Cookie data. magic_quotes_gpc = Off ; Magic quotes for runtime-generated data, e.g. data from SQL, from exec(), etc. magic_quotes_runtime = Off ; Use Sybase-style magic quotes (escape ' with '' instead of \'). magic_quotes_sybase = Off extension=pdo.so extension=pdo_mysql.so
Miha 333 ::
Katera verzija PHP? Kaj pa pravi phpinfo(); pri magic quotes? php.ini ni edino mesto, kjer se to lahko vključi.
Excavator ::
php -v da output PHP 5.6.29-0+deb8u1
Kaj niso magic quotesov removali že okoli php 5.4?
phpinfo kateri del naj postam?
Miha 333 ::
Ni treba postat, samo poglej, če so vsi magic_quotes* off.
Sicer glede na verzijo res verjetno ni problem v tem. Da nimaš kje v includih kak prikrit addslashes ali kaj podobnega?
Excavator ::
//insert data into the database $comment_txt = mysql_real_escape_string( $comment_txt );
kaj pa ta del?
Sem rešil
Excavator ::
Sem rešil z removanjem addslashes, a zdaj mi ne spusti skozi znaka '. Če uporabim npr. '' gre skozi, če pa je kjekoli v besedilu en sam ' ne gre.
Error message:
JS:
Error message:
Cannot read property 'comment_id' of null. at comment_insert (comment_insert.js?t=1414315248:81) at Object.<anonymous> (comment_insert.js?t=1414315248:50) at j (jquery.js:1) at Object.fireWith [as resolveWith] (jquery.js:1) at x (jquery.js:3) at XMLHttpRequest.b (jquery.js:3)
JS:
$( document ).ready( function(){
//this will fire once the page has been fully loaded
$( '#comment-post-btn' ).click( function(){
comment_post_btn_click();
function comment_post_btn_click()
//Text within textarea which the person has entered
var _comment = $( '#comment-post-text' ).val();
var _userId = $( '#userId' ).val();
var _userName = $( '#userName' ).val();
var _first_name = $( '#first_name' ).val();
var _last_name = $( '#last_name' ).val();
if( _comment.length > 0 && _userId != null )
//proceed with our ajax callback
$('.comment-insert-container').css( 'border' , '1px solid #e1e1e1' );
$.post( "ajax/comment_insert.php" ,
task : "comment_insert",
userId : _userId,
comment : _comment,
userName : _userName,
first_name : _first_name,
last_name : _last_name,
.error(
function( )
console.log( "Error:" );
.success(
function( data )
//Seccess
//Task Insert html into the ul/li
comment_insert( jQuery.parseJSON( data ) );
console.log( "ResponseText:" + data );
console.log( _comment + "UserName: " + _userName + "User Id" + _userId );
else
//the textarea is empty, lets put a border of red on it
//in a second
$('.comment-insert-container').css( 'border' , '1px solid #ff0000' );
console.log( "The text area was empty" )
//remove the text from the textarea, ready for another comment
//possibly
$( '#comment-post-text' ).val("");
function comment_insert( data )
var t = '';
t += '<li class="comment-holder" id="_'+data.comment.comment_id+'">';
t += '<div class="user-img">';
t += '<img src="'+data.user.profile_img+'" class="user-img-pic"/>';
t += '</div>';
t += '<div class="comment-body">';
t += '<h3 class="username-field">'+data.user.first_name+' '+data.user.last_name+'</h3>';
t += '<div class="comment-text">'+data.comment.comment+'</div>';
t += '</div>';
t += '<div class="comment-buttons-holder">';
t += '<ul>';
t += '<li id="'+data.comment.comment_id+'" class="delete-btn">x</li>';
t += '</ul>';
t += '</div>';
t += '</li>';
$( '.comments-holder-ul' ).prepend( t );
add_delete_handlers();
| » | [php] preverjanje online uporabnikovOddelek: Programiranje | 2632 (2288) | cobrica |
| » | [php-seje]Ali kdo pozna rešitev!Oddelek: Programiranje | 1678 (1504) | diovc |
| » | PHP/HTML strokovnjaki help!Oddelek: Izdelava spletišč | 2172 (1883) | TheHijacker |
| » | Kako se obvarovati refresha...Oddelek: Programiranje | 1234 (1131) | Shershen |
| » | Varnost PHP & MySQLOddelek: Programiranje | 2485 (2312) | Tr0n |
