Forum » Strojna oprema » AMD Vega GPU
AMD Vega GPU
renofkinja je izjavil:
ryzen je bolsi do useh intelov. to je fact
Kar se ne pomeni ,da je VEGA cesa vredna.
mahone ::
Zakaj je potem AMD predstavil Vego na Intel cpuju?
D3m0r4l1z3d ::
Zakaj je potem AMD predstavil Vego na Intel cpuju?![]()
In Ryzne prodaja za džabe.
SmotaniJanez ::
D3m0r4l1z3d je izjavil:
Vega je ze zunaj od junija, pa se vedno ni prave cene in dizajna za gamerje. Zalostno leto je 2017.
Še bolj žalostno je, da bodo Vego tudi v mainstream vrinili in to s hbm2. Rabimo Polaris 2 za 250 in 350 eur.
http://wccftech.com/amd-rx-vega-64-outp...
The test system included an Intel Core i7 6850K overclocked to 4.3GHz, paired with 16GB of DDR4 memory running at 3000MHz in quad-channel mode. The drivers used were Crimson ReLive 17.93 for AMD and 385.69 for NVIDIA. These drivers are officially optimized for Forza 7.
All graphics options were set to their maximum settings and 8 x MSAA was used in all three resolutions tested.
In quite a shocking turn of events AMD’s RX Vega 64 manages to outpace NVIDIA’s GTX 1080 Ti by up to 23% in the upcoming DirectX 12 ready Forza 7.
LOL.
- spremenilo: SmotaniJanez ()
D3m0r4l1z3d ::
dokler nvidia ne zoptimizira driverjev, tako kot je bilo s hitmanom, gleda se povprečje min. 15 iger, pa vidiš kaj je kaj
SmotaniJanez ::
Tečaj angleščine...??
D3m0r4l1z3d ::
Ne se hecat, saj veš kako bo čez par mesecev, fine wine
SmotaniJanez ::
Ja vem, kakšna škoda, pa tako dobro je kazalo 1080 ti.
D3m0r4l1z3d ::
upcoming...
SmotaniJanez ::
upcoming...![]()
Sploh tole je žalostno, smrk...
This explains how the performance gap consistently shrunk by upping the resolution and why the Radeons were consistently smoother across the board. Even at 4K the GTX 1080 Ti is showing signs bottlenecking and is unable to deliver the same performance lead that it usually has over the GTX 1080.
ComputerBases's frametime analysis at 4K demonstrates this, although they compare the RX Vega 64 to its direct competitor the GTX 1080. The RX Vega 64 manages to deliver both a consistently higher framerate and consistently lower frametimes than the GTX 1080. Which means it delivers more frames per second and does so in a significantly smoother cadence, with far less choppiness and considerably fewer lag spikes.
Grey ::
Če AMD uspe dobit nevtralen teritorij, ki se ga ne bo dotaknil niti sleherni nVidiin inženir niti enka ali nula GameWorks kode ali pa da se loči igra na ImeIgre_GPUOpen.exe in ImeIgre_GameWorks.exe (kar bi bilo še najbolje), bo tak performans stalnica IN vedno delujoč mGPU (ki se ne bo kar iznenada pokvaril).
Verjetno so se nekaj naučili iz Dirt 4, ker je performans scaling podoben. Niti ta niti tista igra nista imeli vmes GameWorks.
Bomo videli, kako bo s Far Cry 5 (FP16) in Wolfenstein II (idTech 6 Vulkan, also FP16).
Tisti, ki so uspeli dobit RX Vega 56 za 399€ so verjetno najbolj profitirali za naslednje 3 - 4 leta.
Grey ::
A ni ta igra Xbox port? Xbox uporablja AMD gpu? Uff im onto something![]()
Forza Motorsport 7 Built from the ground up for PC
- FHD 111 FPS
- QHD 103 FPS
- 4k 91 FPS
Slaba optimizacija. Does not compute. Nothing to see here.
- QHD 103 FPS
- 4k 91 FPS
Lol.
ComputerBase reached out to NVIDIA and the company confirmed that the results were indeed accurate.
Senitel? ;)
Senitel? ;)
|HP EliteBook|R5 6650U|
SmotaniJanez ::
Sej so accurate, ampak z neoptimiziranimi driverji.. Pač sveža igra in porodni krči.
Ali pa se vama kekcoma zdi povsem normalno, da neka grafa v FHD dosega le ~20% več fps kot v 4k resoluciji?
SmotaniJanez ::
VRAM ti kekec.
D3m0r4l1z3d ::
Hehe, ena igra bo zaenkrat delala pravico Vegi.
A zato Vega v 4k poklekne?
VRAM ti kekec.![]()
- spremenilo: D3m0r4l1z3d ()
D3m0r4l1z3d ::
In the mid-range the GTX 1060 retakes the lead from the RX 580 and the Fury X simply runs out of memory and falls on its face.
Ja, baje bo dx12 rešil Vego. Ne, čakaj malo, isto je bilo pri Fury X pa se je pptem izkazalo, da nima veze. Hitman, RoTR,... hehe, patetičen excuse rdečk, AMD ima Vulkan, konzole, dx12 na svoji strani, lol
Misliš anomalija? Dx12 omenjajo, kot da je nekaj čisto novega.
Počasi se bo začelo dogajati.
SmotaniJanez je izjavil:
Kdo je kekec? Kaj je narobe? Pač surova resnica je prišla na dan.
D3m0r4l1z3d ::
pozabil si, da je potem nvidia na koncu prevzela prednost, malo več boš moral pregledati
ase gremo spet vse na novo: uuuuuu, zakaj toliko dx11 naslovov pri testih Fury vs maxwell, počasi bo s dx12 Fury pridobila več, bla bla bla, 2 leti pozneje, počakmo, z dx12 bo Vega pridobila veliko,... lol
SmotaniJanez ::
Nvidia prevzela prednost? Kje, link?
D3m0r4l1z3d ::
SmotaniJanez ::
Če pogledamo RX 580 in 1060, kaj si lahko mislimo?
Ne hiti z odgovorom, poskusi razmislit, če ne veš, predlagam da greš spat.
m0LN4r ::
Torej Vega HBM se kr ni 4K kartica, 1080Ti pa je
Pa ma Vega tok velik konjev, samo v 4K jim zmanjka kondicije.
MSworks; FORZA MOTORSPORT 7 IS AN XBOX PLAY ANYWHERE TITLE. PLAY IT ON BOTH WINDOWS 10 AND XBOX ONE!
Tralala in potem je v 4K 108Ti king. V FHD pa je med 1080 in 1080Ti 6fps razlike. Bravo MS in Odprtost anje.
A pride tudi kaka PC verzija ala Steam ipd. ali bo samo tale xbox anywhere crap?
https://ref.trade.re/38mvdvxm
Trade Republic 38MVDVXM
m0LN4r ::
PS:
Grey je rekel, da CB testi niso Legit in so NV naravnani. Tako da ne verjet tem rezultatom prevec ane XD
D3m0r4l1z3d ::
A na rx 580 vs 1060 4k Forza 7 si pa pozabil? Lol, od kje si se vzel?
m0LN4r ::
Mimogrede... prednarocilo FM7 Ultimate Edition je samo 99,99 evrov zravn pa Vego64 LC zq 820evrov in imas Top Performance in XBOX igro za slabega jurja (+16 posta).
Nvidijasi smo bolj skromni:
Zravn pa staro graficno skromno igro:
Jebiga Nvidijasi nimamo za microsoft store in amd luksus.
UPS:
UPS:
Preveril si? Dej ne lazi se, ker si ze pateticen. Lahko pa ti podas link, ki trdi, da je za resno poslovno rabo (delo) nujno imeti cimvec jeder (To je bila namrec tvoja trditev).
Tvoaj izjava je pateticna.
Najprej: ne vem, čemu žalitve (ampak tega smo pri tebi že navajeni. Ko ti zmanjka argumentov je to pač tvoj nivo).
Nadalje: ja, sem preveril cene, ker govorimo o tejle tvoji izjavi
za 330 brez dvoma dobis novo z garancijo, moras biti res debil, ce kupis rabljeno za isti denar.
Imaš resne probleme z držanjem rdeče niti.
No, jaz menim, da se skušaš le izogniti odgovoru (ne ratuje ti nabolje).
Zato ne ti nam pridigat o tem kdo daje patetične izjave.
Zato še enkrat: nam lahko daš link, kje se zadevo dobi za 330?
Povsem preprosto vprašanje. Ni?
D3m0r4l1z3d ::
RX 580 8GB so že malo nad 300eur
Ok, če on bom pa jaz.
https://www.mindfactory.de/product_info...
Če se ne motim spet pošiljajo v SLO.
- spremenil: D3m ()
Tu zraven damo 20EUR poštnine.
Pa je malenkost čez 330.
Je pa dobra varianta (še vseeno 330+ pa vseeno dobro).
Edit: a so si le premislili glede pošiljanja v SLO?
- spremenilo: FireSnake ()
D3m0r4l1z3d ::
Od kje d3mu info glede pošiljanja v Slo. Oni sploh niso več pošiljali izven De.
Ne vem, mogoče so si premislili.
Nazadnje sem dobil info, da v SLO ne pošiljajo. Mogoče so to spremenili.
Tam pod ceno piše "Lieferbeschränkungen".
Kolikor sem na hitro prebral naj bi bilo pošiljanje v SLO. Lahko me popravite.
P.S.
Če naročiš med 00:00 - 06:00 je poštnina 0EUR.
P.S.
- spremenil: D3m ()
D3m0r4l1z3d ::
Vse si narobe povzel. Niti ena trditev ne drži.
Aha. Bom pozneje pogledal.
- predlagalo izbris: D3m0r4l1z3d ()
filip007 ::
Ja Linux podpira ven iz Kernela Radeon odprtokodno, hitrejše kot nVdia, ki ima zaprt gonilnik.
Prenosnik, konzola, TV, PC upokojen.
D3m0r4l1z3d ::
Zato je že pred leti Linus sredinca kazal GreenGoblinu
A to rece nekdo, ki bi cakal da nvidia spefena gonilnike.
D3m0r4l1z3d ::
Ja, tako se pač dela, če nisi zadovoljen s trenutnim perfomancom, počakaš na boljše čase, halo.
