Forum » Strojna oprema » AMD Vega GPU
AMD Vega GPU
AMD Vega 10 / Greenland Flagship HBM2 GPU Launching In 2017
AMD Vega 10 GPU Features HBM2 – High-Performance Graphics Cards To Replace Fury Series Next Year
AMD’s goal with Vega 10 would be to replace their Fiji based Fury series with high-performance offerings that feature the second generation High-Bandwidth memory solution. The Vega series of GPUs are based on brand new technology and architecture designs. You may call it a step better than Polaris which itself is a 2.8x leap on AMD’s older 28nm products. Vega is going to deliver better performance per watt than Polaris due to a efficient memory architecture and a fine tuned 14nm FinFET process.
We have little details regarding Vega 10 at the moment but previous leaks suggest that the will feature 4096 stream processors. These are not the current generation stream processors but utilize the advancements made in the IP v9.0 generation of graphics SOCs under development by AMD. It is also noted that this chip is the “Leading Chip” of the first graphic IP v9.0 chip generation. We can expect to see a liquid cooled design and a new dual GPU offering under the Vega family when it launches in 2017.
http://wccftech.com/amd-vega-10-gpu-mil...
tt2 ::
To, potem pa še zraven kak 34inčen 144hz freesync ultrawide monitor, ki izidejo 2017 pa je to to. :D
kateri Q/kvartal naj bi te grafične bile na voljo?
ASUS ROG Strix RTX 2080 Super, Samsung 970 PRO, UltraSharp UP3017, Win 11 Pro
moj oče darko 1960-2016, moj labradorec max 2002-2013
Sej Vega je že zunaj.. Reče se ji Pascal a.k.a GTX 1080.. Sicer nima HBM2 rama, ampak zmogljivost je tam-tam z Vego, predvidoma.
Od AMDja bo bolj zanimiv Zen, ki naj bi ugledal luč sveta Q1 2017.
Napajalc ::
Zgleda se še ne mudi z next gen performansom, imam občutek da prihajajoče igre ne bodo imele kake posebne zahteve za grafiko, od tukaj mogoče tudi razlog da nvidija prisega na večji boost za dx11.
011011100111010101100010
- predlagal izbris: SuperVeloce ()
Koncno konkurenca gtx1080 cez 1 leto? Ampak AMD fani bodo set trdili, da amd ne lovi nvidie z enoletno zamudo.
Napajalc ::
Jah, lahko da so novi gtx podobni gtx 970/80, pač fokus dx 11, kar lahko pomeni crap prej kot si mislimo.
- predlagalo izbris: Macketina ()
Lej, bodimo posteni do sebe in drugih, pa raje recemo, da AMD ne zmore, kot da si zmislujemo neumne izgovore.
Napajalc ::
To bodo pa prihajajoče igre pokazale, z zagotovostjo se ne da trdit ničesar. Lahko da grafika stagnira zavoljo višanja resolucije, kar bi bilo še najbolj logično, obljubljajo že lep čas 4k GPU, pa kar od nikoder nič.
Pridi k meni na pivo bova igrala 4k igerce na 1080.
Napajalc ::
Ne pretiravat, niti ena igra ne dela proper na 4k, average pod 60, kaj šele minimu FPS. To za večino ni 4k kartica, od 4k kartice se pričakuje vsaj nekaj let spodobnega igranja na 4k.
http://www.guru3d.com/articles_pages/nv...
Pridi. Mam tud rdečga. In prepričal se boš. Da mora pa za naslednha 4 leta playat 4k maxed pa praviš ti. Nove kartice hodijo ven skoraj vsako leto ;) Tako da pretiravaš bolj ti. SC Blaclist 4K, ki je še iz dobe voščenih valjov (2013), kartica spi. DOOM nightmare setsi - redko pod 50, večinoma 55-60. Zame je to ok. Za leto, dve bo super.
Napajalc ::
Vsak ima svoja merila, če bi bili minimum FPS namesto average bi še nekak šlo z OC in zmanjšanjem kakih nepomembnih detajlov, pač lock 60 fps je krasno za igrat, slika more bit čista ko suza.
Za hardcore mp šuter ja. Vse ostalo, sploh SP in vse kar ni racing je krasno tudi če ni lock 60. Sploh pa TitanX je za vogalom. 4k@60fps? Check.
Napajalc ::
No ja, so špili ki ne lomijo slike, samo pod 55 fps tako in tako ni za jit. 1200$ za 4k lock fps kartico ki bo pri prvem močnejšem špilu poklenila? nope, to je še vedno OP 1440p zadeva.
D3m0r4l1z3d ::
kdaj v 2017?
Titan X je že zdaj zunaj in ima najboljši p/W
- spremenilo: D3m0r4l1z3d ()
AMD Teases Vega GPU Launch, GTX 1080 Competitor May Be Coming Sooner Than Expected
http://wccftech.com/amd-vega-flagship-g...
VEGA In October...?
With that being said, the company's official roadmap suggested that VEGA would launch in 2017. We've heard some whispers since VEGA's official announcement back in March which suggested that AMD was aggressively attempting to push the launch ahead to October of 2016, rather than early 2017.
VEGA In October...?
D3m0r4l1z3d ::
če bo le 1080 competitor, to očitno ne bo poln Vega čip in verjetno ne hbm.
Alien123 ::
4k pa 1080ka? Mhm malo morgen :D
D3m0r4l1z3d ::
AMD says: r9 390 pa 4k, hell yeah, probaj, samo snemi še drugo stranico in odpri okna, sa bo durhcug
Alien123 ::
anymal butthurt much?
mam balkonska odprta, okno tudi.. ni pene, vsaj vem da ne podpiram monopol..
pa kdo je rekel da bi rad igral na 4k? u mental bruh? .. 4k pa 30 fpsjev? nop..
1440 pa 144hz? jap
1440 pa 144hz? jap
A se bojim, da bo 3d vr explodiral prej, kot si mislimo ...
Da ne bo na koncu kot 3D filmi v kinih ... muha enodnevnica.
Ja, res je.
Eni pa še kar tiščijo glavo v pesek, češ, kako močna je Evropa.
D3m0r4l1z3d ::
1440 pa 144hz? jap
1440p in 144hz na 390, malo morgen
m0LN4r ::
Novi GTXi bodo ob izidu vege ze veterani na trgu.
Nvidija pa za rezervno rukne 1080Ti takrat ven.
1440 pa 144hz? jap
Nene on te je samo spomnil na tist rdec slajd, R9, kjer pise made for 4K gaming :P
https://www.youtube.com/user/m0LN4r
- spremenil: m0LN4r ()
Alien123 ::
cs, rocket league, bf1.. to bo vse lepo preko 100fpsjev dečki..
da si pa zdaj kupiš za 800€ vredno grafično ki nemre 4k pa moraš bit talent
m0LN4r ::
Cakas lahko vedno na nekaj boljsega. Zka bi kupu vego, ce za vego itak pride Volta.
Napajalc ::
Čaka se samo realne cene, nova tehnologija bo prinesla eno stopničko višje zmogljivosti GPU za enak denar in ravno tako kvaliteto grafike, forsiranje zmogljivih GPU brez primernih iger pa pomeni samo dobiček. Sedaj verjetno veš kdaj bo čas za nabavit recmo gtx 1070.
Napajalc ::
Odvisno kdaj bo proper new gen grafika, in pa kakšna bo moč. Če gledaš BF1 bo r9 290-gtx 970 (rx 480) ekvivalent 7970 kot dobra zadeva za bf4, idealna moč (60 fps+) za bf1 bo verjetno ~r9 390x-fury. Torej je moč gtx 1070 neposrečena, op za 1080p in premalo za 1440p.
Idealno bi blo vega 1440p 60 hz za 320e.
Realno bo verjetno gtx 1070 320e 1080p 60 hz.
Torej bo Vega GCN 5.0, če bo še bolj efficent, kot Polaris.
|HP EliteBook|R5 6650U|
- spremenil: D3m ()
Polaris je cez 300 EUR, Vega bo ocitno precej drazja :S. Oz. WTF happend to 200 USD.
D3m0r4l1z3d ::
Vse je ve redu, samo počakat je treba.
hojnikb ::
sepravi glih malo bolše od maxy-a :)
#brezpodpisa
m0LN4r ::
Vega nebo 320EUR se par let.
Sumim, da bo vega next 800EUR GPU od AMDja cez dobrih par mescev.
D3m0r4l1z3d ::
Glede na to, da je najnovejši Titan X na samem vrhu v p/w, bo moral biti Vega že mali čudež, da ga preseže. Vsekakor pa, če bo s hbm2 vsaj 8gb, bo zanimiva konkurenca.
Damn, sami kinezi to razvijajo.
Glej to:
Kitajska izstrelila prvi kvantni komunikacijski satelit na svetu
D3m0r4l1z3d ::
Geforce 1080 reign? The end is nigh!
Rx 490 je že blizu ali pač? Pojavila se je v tpu database, vendar sumljivo nizek pixel fillrate. Naj pa bi imela 8gb hbm2 1024bit in 8,602 GFLOPS.
https://www.techpowerup.com/gpudb/2871/...
D3m0r4l1z3d ::
Sem imel nazadnje 290x in res ne želim preplačevati, verjemi, želim le dober produkt all around, ne da snemam stranice ohišja, kapiš?
Napajalc ::
Zakaj potem nisi nabavil gtx 780 če praviš da r9 290x ni dobra?
D3m0r4l1z3d ::
Nimam izkušenj s 780, zato ne morem komentirat, za msi 290x pa vem in ne priporočam 250w+ grafe brez tru slot tri fan ali vodnega. Poceni je z razlogom.
Alien123 ::
zato pa si zdaj raje na igpuju, bravo.. Anymal bo treba manj žida bit, pa dejansko nekaj kupit, ne pa samo čakat na poceni in dobro..
D3m0r4l1z3d ::
V bistvu poceni ne kupujem več, samo še dobro, tako Radeonke zaenkrat odpadejo, ne mudi se mi pa ker je poletje in ne bom igerc zdaj nabijal, bo pa lepo ob deževnih jesenskih dnevih brnela kakšna rx 490 ali 1070, samo da bo kaj od AMDja do takrat, trenutno so tuga z juga.
D3m0r4l1z3d ::
so bile govorice, da na gddr5x že oktobra, v formi rx 490
