Forum » Strojna oprema » AMD Vega GPU
AMD Vega GPU
AMD RX Vega 56 Ran at 30 FPS on 1080p In Crytek Real-Time Ray Tracing Neon Noir Demo, GPUs With Dedicated Hardware (NVIDIA RTX) & Modern APIs Can Deliver Better Performancehttps://wccftech.com/crytek-neon-noir-r...
France Rejects Genocide Accusations Against Israel in Gaza,
To accuse the Jewish state of genocide is to cross a moral threshold
A ni Vega nekako že pod rušo al kako, kdo še danes sploh kupi to kartico?
Pod rušo?
Očitno še ne.
Meni je zanimivo, zakaj je to možno zdaj? Zakaj takrat, ko so zadevo izdali, o tem nihče ni govoril (pri AMDju).
Pod rušo?
Očitno še ne.
Ta članek ni ravno laskavi za Vego. 30fps na 1080p v "half resolution načinu"? Medtem pa piše:
It is clearly stated by Crytek that RTX graphics cards such as NVIDIA GeForce RTX 20 series which are Microsoft DXR compliant can allow the same effects to run at higher resolution with better framerates. Crytek believes that with proper optimization for RTX hardware, they can achieve full-screen ray tracing effects at 4K as opposed to half-screen ray-tracing on GTX 1080 or a Radeon RX Vega 56.
Kakorkoli. S tem se jaz ne bi hvalil. :)
FlyingBee ::
Vsekakor pohvalno, da se že ob prvi priliki razvija RT, druge bolj zanimive reči na grafičnem področju zaenkrat ni in zanimivo bo spremljati kako se bo vse odvijalo, Navi verjetno ne bo prinesel izboljšave, bo pa leta 2020 kaj novega od obeh taborov.
FlyingBee ::
Seveda je bilo veliko prilagajanja
The raytraced path wasn't running on any modern, lower-level API, such as DX12 or Vulkan, but rather, on a custom branch of Crytek's CryEngine, version 5.5.
Verjetno bo to next console, kjer ne moreš nadgrajevati HWja, kjer so že zdaj magic tricks, da zgleda še kolikor toliko. Konzole pač, splača se jim.
m0LN4r ::
Stanje v evropi za nas:
1x 6pin:
GTX 1660 za 199 EVROV: KFA 1660 dual fan
GTX 1660Ti za 239 EVROV: KFA Dual Fan
2x 8pin:
Najcenejsa Vega56, ki ni blower je 275 EVROV: Asus Trix
Kdor hoce glasnejso karto, ki rabi 2x 8pin, ustvari 2x vec toplote in porabe in je samo tu pa tam zanemarljivo hitrejsa, bo pac moral zapraviti vec.
Za FHD je dovolj tista 1660/Ti, Vega je pa pac malo vec, ni pa dovolj za 1440p, tako da brezveze zapraviti vec, za enako hiter kalorifer.
https://www.youtube.com/user/m0LN4r
In other words. Cena je določena hitrost je pa tudi znana.
Molko si še zaposlen tamm pri trgovcu pri Münchnu?
|HP EliteBook|R5 6650U|
- spremenil: D3m ()
1x 6pin:
2x 8pin:
Zakaj zavajas s 30 EUR nizjimi cenami, kot so na linkih, ki si jih podal?
1x 6pin:
2x 8pin:
lol a datuma nisi videl..
v tej temi sem dal tudi linke za vego 56 po 250€ in vego 64 za 380€.
1x 6pin:
2x 8pin:
244€ vega 56 https://www.mindfactory.de/product_info...
378 € vega 64 https://www.mindfactory.de/product_info...
660 € vega 7 https://www.mindfactory.de/product_info...
dejmo se druge
160 € rx 580 https://www.mindfactory.de/product_info...
114 € rx 570 https://www.mindfactory.de/product_info...
ps pa ne pozabi da dobis zraven dve igri...
- spremenil: Mr.B ()
klinker ::
Se predrago je to, za tako staro pozresno zelezje
Nvidia bi mogla cene se malo dvignit, ker sta 1660/Ti prepoceni, glede na konkurenco
Se strinjam, kar naj dvigne. 1660ti se glede na to kar nudi rtx 2060 ne splaca kupovati. ce bo r5 3600G na nivoju 1650 bo mogla nividia se bolj dvigniti cene.
Dej ne sanjaj no. 2400g komaj 1030ko drzi, zdaj bo pa ta srot na 1650ko prisu, ja
Seveda govorimo o bistveno visjih frekvencah bistveno visjem stevilu jeder in bistveno novejsi graficni.
da blizu bo 1650.
2400g na 1650? Si malo zamešal?
Navi še čakamo.
Navi še čakamo.
- spremenil: D3m ()
da blizu bo 1650.
3600g na nivoju GTX1650? Ti si pozabil vzet antihistamin danes? Dej pomisli malo logično. GPU, ki poganja vse najnovejše igre na 1080p, bodo pri AMDju ponudili takorekoč gratis in s tem kanibalizirali ves entry level market, vključno s pol NAVI karticami?
U nuts?
da blizu bo 1650.
U nuts?
Zakaj je pa naj bi bila majavljena naslabsa, najpocasnjesa navi kartica na nivoju rx 590, ce je market za 1650?
pozabljate da bo r5 3600G imel 2x vec jeder in in boljso graficno in podporo za hitrejsi ram. Da zna se zgoditi kretenom da bo lahko prisel blizu 1650.
Tip zivi v oblakih
No ja, me ne cudi sploh
Seveda bos nasel navi kartico, ki bo zamenjala rx 470 ?
na low 1080p si lahko igral 2400g, ce bos lahko igral na medium z 3600g, potem je nakup 1650 kartice nesmiselen, ker na njej ne mores igrati vse na ultra in imeti fps nad 60
temu se rece budget gaming, a pizda ni temu namenjena 1650 kartica...
Saj pravim, če bo pod 1650 bo to super.
Ze sedaj se da s "spodobnimi" FPS-ji in navitim 2400g igrati na 1080p, testov je dovolj...
3600g ima ne samo ze v osnovi visje frekvence, ne omejujejo ga stiri jedra, druga graficna in hitrejsi ram. Ce bo prisel blizu tega kar je sposobna 1650, potem je / bo nakup 1650 nesmiselen. No vsaj cenovno, ampak tu so intel fani in je normalno da je za 4 generacije stra proc potrebno odsteti premium, ter se zaradi ceneizgovarjati na pomanjkanje.
Tip zivi v oblakih
Pazi, da se ne zaletita med sanjanjem.
To so govorice....The processor would feature a Navi GPU with 20 CUs or 1280 cores.
Kaksne so specifikacije 2400g ?
20 CUs ja. Namenske Navi kartice pa naj bi imele med 32 in 64 CUs, s tem da imajo hkrati višjo frekvenco, svoj ram, itd.
Skratka, 3600g iGPU bo imel nekje polovico zmogljivosti najpočasnejše Navi kartice.
- spremenil: DarwiN ()
m0LN4r ::
1x 6pin:
2x 8pin:
Ker ko das v kosarico jo dobis za 30 evrov manj. Sej smo tu hkrati za to, da objavimo tudi dobre cene, kjer je mozn kupit.
1x 6pin:
2x 8pin:
dejmo se druge
Sej lih to, kdo sploh hoce ta 2x 8pin fen za lase za ta dnar, nihce razen fanbojev, zato da poslusas kako tuli in imas v stirih igrah 3 fpsje vec? lol
- spremenil: m0LN4r ()
m0LN4r ::
Z integrirano ryzen grafiko, brez hitrega dual channel rama, bos lahko igral igre tako kot si lahko s tistim sivim suhim wc papirjem v javnih wcjih ritko obrises.
Vsaka poceni low end poceni graficna ponuja boljso izkusnjo. Ce pa pac nimas dnara, pa sploh ne kupuj racunalnika, bos imel vec od rabljene PS4 pro.
klinker ::
na low 1080p si lahko igral 2400g, ce bos lahko igral na medium z 3600g, potem je nakup 1650 kartice nesmiselen, ker na njej ne mores igrati vse na ultra in imeti fps nad 60.
Ok, 2400g na low lahko igras, 1650 ultra ne gre...3600g na medium spet ok...3600g bo na ravni 1650.
Pa kake ti pises, bog se te usmili
1x 6pin:
2x 8pin:
1x 6pin:
2x 8pin:
dejmo se druge
Kdo pa hoce med nvidia kartico z delovno temperaturo 85°C, in to se preden jo zacnes navijari.
Cene so znane, ce ti niso vsec se pritozi AMD, da je lame ker prodaja pri tej ceni, in ti kupujes raje premium.
Testov je polno, lahko iggras na loe 1080p in manjka med 10-20FPS-ji da bi drzala konstantno nad 60FPS.
1650 na ultra ne mores imeti pri vseh igrah nad 60FPS.
A ti dejansko beres kar ta idiot poleg mnogih drugih tukaj pisejo???
Idiot ti servira sledece...
https://www.anandtech.com/show/12542/ov...
Takih in podobnih testov je polno.Glede na to kaj bo prinesel 3600G, no bomo dobili saj sugestirano cez dva tedna..
If we go back to our Ryzen 2000 Series APU review, it is clear that the Ryzen 3 2200G ($99) and Ryzen 5 2400G ($169) are true winners when it comes to building a gaming system on a budget, without making too much of a sacrifice, especially when focusing on popular gaming titles that do not require ultimate horsepower.
Sedaj pa drzi gobec in si pojdi kupit 85°C on the budget gtx 1650.
sej tud ni karta za povprečje 1080p 60+ ultra
Potem pa definirajte, kdaj je graficna kartica gamerska kartica.
1. koliko FPS mora biti minimum, pri
2. Kateri resoluciji in,
3. nastavitvi med/high / ultra in tudi
4. v koliko igrah mora to doseci.
Sej ne da bi spraseval jaz nimam monitorja z nativ resolucijo 1080p, pac da ne bomo cez 1 mesec imeli debato da je kartica lame ker zmore 75FPS, konkurenca pa 80FPS.
gddr85 ::
za budget gaming in nadomestek kake konzole je ok, ne moreš pa primerjat vego8/11 pa 1650, kot bi rekel, da je npr. 570ka mal boljša od 2400g igpuja
oz. manj kot rtx2060 se itak ne splača, ker je vega11 ravno tako ok
- spremenil: gddr85 ()
Se 1x testi so jasni tako za 2400G kot za 1650. kaj si ti smatras za gaming kartic in kaj ne lahko brez tezav napises v tistih sugestiranih 4 tockah. Do takrat pa velja da je nakup GTX1650, nakup primeren le za najvecje ljubitelje nivide, ker do danes ni in ne obstaja test, kjer bi ti priporocali nakup 1650 kot primer nadgradnje.... Razen tistih fenomenalnih robnih pogoje, ki jih ne izpolni 99,99% slo tech gamer cluba.
Ko ze govorižo o nvidia, prejsni teden je bil patch za telemetrijo sedaj imate pa kar stiri zero days...
Nvidia Warns Windows Gamers on GPU Driver Flawshttps://threatpost.com/nvidia-windows-g...
