Forum » Omrežja in internet » KKS > Triera > UPC > Telemach
Je pri telemachu internet trenutno ok, ker vceraj so pri meni bli problemi?
ASUS ROG Strix RTX 2080 Super, Samsung 970 PRO, UltraSharp UP3017, Win 11 Pro
moj oče darko 1960-2016, moj labradorec max 2002-2013
predi ::
Maribor Pobrežje ima večji izpad danes od šestih zjutraj dalje. Odpravili bodo tekom dneva.
telen ::
A ima danes še kdo visok ping? Kraj: Ljubljana.
Pinging google.com [172.217.20.14] with 32 bytes of data: Request timed out. Reply from 172.217.20.14: bytes=32 time=1658ms TTL=54 Reply from 172.217.20.14: bytes=32 time=2038ms TTL=54 Reply from 172.217.20.14: bytes=32 time=1849ms TTL=54 Ping statistics for 172.217.20.14: Packets: Sent = 4, Received = 3, Lost = 1 (25% loss), Approximate round trip times in milli-seconds: Minimum = 1658ms, Maximum = 2038ms, Average = 1848ms
XS!D3 ::
Nope.
Tudi čez dan nisem opazil kakšnih težav pri delu. Verjetno bolj lokalne težave v vašem koncu.
~# ping google.com -c4 PING google.com (172.217.20.14) 56(84) bytes of data. 64 bytes from ham02s13-in-f14.1e100.net (172.217.20.14): icmp_seq=1 ttl=54 time=14.7 ms 64 bytes from ham02s13-in-f14.1e100.net (172.217.20.14): icmp_seq=2 ttl=54 time=14.8 ms 64 bytes from ham02s13-in-f14.1e100.net (172.217.20.14): icmp_seq=3 ttl=54 time=14.8 ms 64 bytes from ham02s13-in-f14.1e100.net (172.217.20.14): icmp_seq=4 ttl=54 time=14.8 ms --- google.com ping statistics --- 4 packets transmitted, 4 received, 0% packet loss, time 6ms rtt min/avg/max/mdev = 14.727/14.797/14.836/0.095 ms
~# ping 1.1.1.1 -c4 PING 1.1.1.1 (1.1.1.1) 56(84) bytes of data. 64 bytes from 1.1.1.1: icmp_seq=1 ttl=59 time=5.72 ms 64 bytes from 1.1.1.1: icmp_seq=2 ttl=59 time=5.66 ms 64 bytes from 1.1.1.1: icmp_seq=3 ttl=59 time=5.73 ms 64 bytes from 1.1.1.1: icmp_seq=4 ttl=59 time=5.61 ms --- 1.1.1.1 ping statistics --- 4 packets transmitted, 4 received, 0% packet loss, time 8ms rtt min/avg/max/mdev = 5.610/5.679/5.726/0.104 ms
~# ping 193.2.1.66 -c4 PING 193.2.1.66 (193.2.1.66) 56(84) bytes of data. 64 bytes from 193.2.1.66: icmp_seq=1 ttl=56 time=0.755 ms 64 bytes from 193.2.1.66: icmp_seq=2 ttl=56 time=0.707 ms 64 bytes from 193.2.1.66: icmp_seq=3 ttl=56 time=0.791 ms 64 bytes from 193.2.1.66: icmp_seq=4 ttl=56 time=0.832 ms --- 193.2.1.66 ping statistics --- 4 packets transmitted, 4 received, 0% packet loss, time 65ms rtt min/avg/max/mdev = 0.707/0.771/0.832/0.050 ms
Blazz ::
hoj, ima kdo tanov telemachov modem Technicolor CGA2121 in 500 mbit linijo? meni vsakič ko poskusim downloadat in gre nad 30 mega na sec , vrže celoten internet dol in traja 2-3 minute da dobim nazaj internet. in to se dogaja na vsakih 5 min. Če ne downloadam je linija stabilna, brez packetlossov, visokih latenc itd. So mi zamenjali modem z drugim, enakim, in se dogaja isto. Enako je ali je modem v "router" ali "bridge" modeu. Modem sam pa ne pokaže nobenih znakov (npr da bi se restartal) da je kaj narobe. To se je začelo dogajati takoj ko so mi dali ta technicolor modem namesto Ubeeta. Na downstreamu mam 10 db, na upstreamu mam 40db, tako da tudi tu ni nič narobe. Zamenjal sem kable, priklopil gor direkt drug laptop z novim kablom, vedno je ista štorija. Tehniki ne vedo kva je narobe :S
p.s. pa nima veze kaj downloadam, al torrente, al pa kaj iz Steama, weba itd.
- spremenil: Blazz ()
bombicar ::
Boš mogu počakat na firmware upgrade. Do takrat pa reči naj ti dajo nazaj ubee. Drugače pa modem v bridge pa v port 1 prištekaš svoj switch/router pa potem preko tega obremeniš ali kako si to testiral?
Isti problem je biu pri hgw3928s, ko si obremenil linijo nad 250Mbps za več kot 30? sekund se je modem sam od sebe resetiru zato si pač mogu met 3208 ali 3212.
Blazz ::
sem že zahteval nazaj Ubee k sm ga mel v bridgeu, sam so mi tud povedal, da novih več nimajo, da bom dobil rabljenga, upam da bo ok.
testiral sem na miljon načinov. Prvo sm imel v bridgeu pa zadaj Cisco RV325 router (lan 1 iz modema v WAN). Potem sem vzel laptop in ga poču direkt v lan 1 na modemu in spet testiru, nato sm klicu na telemach, ker ko je technicolor v bridgeu sploh ne morš dostopat do njega (noben password ni pravi), da mi ga prestavijo v router mode, in spet testiral zadaj z mojim routerjem in nato še brez direktno v lan 1,2,3... probal sem s 3 računalniki. Vsakič je ista zgodba. Sem pa traceroutal in takoj za modem IPjem (ki je 192.168.0.1 v router modeu) se pojavi Ip 10.243.0.1. in ta je prvi IP ki nima več odziva, in seveda nato vsi ostali IPji navzven.
Btw čist v info, ker telemach marsičesa ne ve (oz njihovi top tehniki):
- če je modem v bridgeu ni šans da prideš notr, se je tehnik sam matral fizično pri meni pol ure)
- če je modem v bridgeu je ip 192.168.100.1 in ne 192.168.0.1 kot vsi pr telemachu trdijo
- tudi če je modem v bridgeu, delajo lan 2 3 4 vhodi, kar so mi tehniki zatrjevali, da je nemogoče, pa se je tehnik na lastne oči prepričal pri meni, da temu ni tako...
- če modemu premikaš nastavitev iz router mode v bridge mode sam, ne bo delovalo, se modem ko dobi povezavo s telemachom, še enkrat restarta in pobera kar je pri njih nastavljeno, kljub temu da so mi nekateri tehniki trdili, da temu ni tako
bombicar ::
Ko je modem v bridgu ti sploh ne rabiš dostopa do modema. Vse ti more handlat naprej tvoj router/switch.
Dela že dela sam je neka fora glede porta 2,3,4 ki se ga trenutno ne spomnim. Za hgw3928s vem da si nekaj časa nazaj dobil drug public IP na drugemu portu.
Ko spremeniš v bridge sam se ti bo modem rebootal med rebootom bo pa potegnil tvoj config file direktno iz DACS-a. Bridge ti more vklopit tehnik/agent direktno v DACS-u.
Nekatere vrednosti ti pač ne moreš spremeniti kot so hitrost, bridge, unifi, static ip ... ker jih zmeraj potegne iz sistema ob prvi inicijalizaciji in ne iz modema zato ti jih tudi povozi
Drugače pa bi to "top tehnik" že moral vedeti. Samo "top tehniki" ne hodijo k strankam pa menjavajo opremo
Blazz ::
dostop do modema bi rad imel v bridgeu (tako kot to dela pri UBEE), da ga lahko restartam remotely, da ne hodim 4 štuke po bajti. Verjemi, smo imeli tehnike na liniji med tem ko je bil tehnik pri meni že 3x, uni k so bli na liniji je vsak malce drugače govoril...
Filipko ::
Telemach končno startal s personaliziranimi profili. Podobno kot NETFLIX. Mislite, da imajo dober algoritem in koliko userjev bo to sploh uporabljalo (ustvarilo profil)?
XS!D3 ::
Jaz sem ga ustvaril, kok se bodo uporabljali različni znotraj gospodinjstva bom pa še videl. V končni fazi večino stvari z mojo gledava skupaj. Mi je pa dark tema super, da v temi ne seka ven tista bela (na OLEDu sploh prav pride), pa tudi novi fonti so mi všečni. Kids modea zaenkrat še ne rabim, deluje pa cool :)
Buggy ::
mene pa moti sedaj s temi profili ali pa je povezano s cim drugim, ker ko cez noc ugasnem box in potem prizgem, ne gre avtomaticno na zadnje gledan program, temvec na menu :S
bombicar ::
ledd ::
Ima ali je imel mogoče še kdo podoben primer. Preko strani speedtest.net mi pokaže samo rezultat za ping (pa še ta ni tako nizek kot bi moral biti), ne pokaže pa izmerjene hitrosti za download in upload? Hvala vnaprej!
bombicar ::
flisko ::
st12 ::
Je kaj novic kdaj naj bi povišali upload? Rečeno je bilo že lansko leto tak čas.
Ali pa če bi vsaj ponujali za doplačilo 20 namesto 10 Mbps za nekih 5-10€. Zdaj je pa samo pri najboljšem paketu, ampak to pride potem že 90€ na mesec.
Orias ::
So obljubljali povišanje uploada. Brez, da bi kaj vložili v omrežje pač ne gre. Veliko operaterjev v tujini ponuja upload hitrosti ( do 50 Mbitov) ponujajo na docsis 3.0. Še SBB v Srbiji je dvignil upload ( v njihovem giga omrežju). In potem se naš Telemach hvali o najboljšem kabelskem omrežju...... .
XS!D3 ::
Sej tudi Telemach ponuja 50Mb/s na docsisu, samo plačat je treba.
bombicar ::
V omrežje so vložili velike zneske(menjava ampliferjov, drop kablov, segmentacije, itd...) Postopoma se vklapljajo dodatne US frekvence za potrebe po večjih upload hitrostih. Vse je odvisno od fiber node-a in stevilo uporabnikov/obremenjenosti na njem.
Tehnično ti tudi ne bom na dolgo razlagal, ker nima smisla. Se dela na tem vendar počasi in z previdnostjo vsaj na našem območju. Ni samo da vklopiš in pozabiš.
yogy ::
Vse lepo in prav. Ampak Telesmeh je večji upload (50Mbit/s) obljubljal do konca lanskega poletja in od tega ni ne duha ne sluha več. Pa ne mi prosim razlagat, da ga že ponuja ampak je treba plačat, ker za to ceno kar zdaj ponuja se imenuje rop. Po moje se bo treba dokončno rešit analognih kanalov, potem pa zna bit kaj iz tega.
Jamranje na forumih ne slišijo.
Odpovedi (no monez!) pa še kako.
bombicar ::
50Mbps ne bos videl v paketu razen kot kaksen add-on. V premiumu bo mogoce 25/30. Analogni kanali nimajo veze z upload-om ampak download-om.
Upload je v early adopters fazi. Če hoces 50Mbps pač moraš plačat. Za tiste ki imajo adsl je že 15mbps majka.
Drugače pa tudi ko bo 30/50 w/e vam spet ne bo dovolj. Sam imam 10mbps pa nimam nikoli problemov. Pač pustim čez noč na serverju in je to to.
- spremenilo: bombicar ()
Kakšnem serverju? Kako spraviš na server?
hojnikb ::
obrobnim celjanom nam kaj druga at this point kot jamrjanje ne ostane. Razn če začnemo vlečt svoj fiber.
boljšo vprašanje je, kako iz svojga serverja streamaš stuff, ki ma večji bitrate kot maš uploada :)
#brezpodpisa
- spremenil: hojnikb ()
yogy ::
@bombicar, če bi dobro prebral moj prispevek bi videl, da sem omenjal kaj je Telesmeh obljubljal in ni izpolnil. Kaj bodo naredili glede uploada v prihodnosti bomo videli. Še enkrat, doplačilo za 50Mbit/s uploada je več kot pretirano v razmerju ponudbe in cene. Če si zadovoljen z 10Mbit uploada oziroma, če ti ta hitrost popolnoma zadošča, super. Je pa nekaj uporabnikov na tem forumu, ki pa jim ne, ki imajo npr. kamere, delijo datoteke preko P2P omrežja, imajo razne IoT naprave, NASe, serverje in si v 21. stoletju želijo večji upload, ki pa ga ni. Poleg tega pa so/smo prikovani na Telesmeh, ker konkurenca stoji oziroma nima interesa, da v določenih območjih napelje optiko. Nihče te ne ogroža, izražamo zgolj osebna mnenja in izlivamo svoja čustva do ponudnika internetnih storitev. Nekaj kar ustreza tebi ni nujno, da ustreza večini na tem forumu.
techfreak :) ::
obrobnim celjanom nam kaj druga at this point kot jamrjanje ne ostane. Razn če začnemo vlečt svoj fiber.Ne rabis biti na obrobju, da je Telemach ali xDSL edina opcija, in tukaj ima Telemach monopol, ker je xDSL precej pocasnejsi. Podobna zgodba je tudi v ostali mestih, ker precej ulic/blokov ni pokritih z optiko.
bombicar ::
Te popolnoma razumem kaj hočeš povedat ampak "normalen" uporabnik uporablja čez dan cca 2-5% svoje zakupljene kapacitete kar je praktično nič in dokler ne bo pri normalnih uporabnikih ta poraba večja tudi ne bodo spreminjali hitrosti. Že zdajle lahko po 90% slovenije spremenijo upload hitrost × 2, ker praktično kjer nima konkurenca optike jih telemach poje.
Jaz osebno sem za to da TM kupi en super docsis 3.1 modem in začne forsirat ofdm za vse premium in full pakete in s tem omogoči hitrejšo in večjo kapaciteto ampak glede na to koliko so vložili v te nove CGA-je bo zgleda treba še malce počakat.
Fsegula62 ::
V Srbiji ima Telemach (SBB) v rednih paketih 50Mbps UL
Cenik: https://sbb.rs/Binary/30965/Ponuda-sa-c...
Gapi ::
XS!D3 ::
Če pustimo ob strani dejstvo, da jih to košta cca. 10% njihove povprečne plače, je predvsem vprašanje kakšno hitrost dejansko lahko dosegaš (s čim na TM načeloma nisem imeli nikoli težav, vedno leto praktično maks). Poznam par ljudi dol, ki imajo SBB, pa vrjemi, da imaš rajši Telemach. Pa BTW, po defaultu si kar lepo za CG-NATom....
st12 ::
Saj to, zakaj če itak noben ne uporablja, kar vsem ne dvignejo uploada za 2x. Pač ne morejo gledat porabe pri vsakem in je tako še najbolj enostavno.
Če bo teh 5% uporabnikov 24/7 izkoriščalo 2x višji upload, bi morale biti kapacitete več kot zadostne.
Vsekakor če bi to naredili, ne bi zaradi tega vsi uporabniki začeli neprestano uploadati na Google Drive. Enako kot če bi povišali omejitev hitrosti na AC iz 130 na 260, bo večina še vedno vozila 100-130, tisti redki so pa že prej več.
Saj vprašanje že sedaj, če je tako da bi lahko kar vsak uporabnik izkoriščal 100% povezave, kot smo videli med čakanjem na delo aprila (ali tudi maja?), to ni možno.
Veron ::
Telemach ima očitno res zelo ohlapna pravila za pogodbene izvajalce.
Imajo očitno neko bazo naročnikov, ki jih na polno klicarijo (avtomatično kliče, deklca v službi ne vrti številk) in seveda to ni klicni center Telemach-a (ampak X firma).
Kljub temu, da smo dali zahtevo za prepoved komercialnih klicev, vsakemu ki je klical rekli, da ne želimo teh klicev... še vedno kličejo (predvsem pred iztekom vezave).
Kako annoying
Klicni center 070888201 pa očitno menja imena firme/lastnika kot spodnje gate. Po kratkem googlnju, ta klicni center obstaja že nakaj časa, lastniki in ime firme pa se pogosto menja... shady
Kako annoying
- spremenil: Veron ()
S!lentHunter ::
Kateri modem+routar, ki ga daje TM je najboljši, oz. ima najboljši wifi,:cisco, ubee...?
AMD Ryzen 5 2600x,MSI 450 Tomahawk,Gigabyte RX580 8GB,16GB DDR4, SSD Samsung
Huawei
Huawei
Yossarian ::
Kaj Comedy Central ni več v programski shemi?
Nikoli se ne prepiraj z idiotom, ker te bo potegnil
strom_15 ::
Program Nicktoons bo zamenjal televizijski program Comedy Central Extra, ki se je odločil, da preneha s predvajanjem v celotni regiji.
bombicar ::
S!lentHunter je izjavil:
Katerkol modem dej v bridge pa si sam kupi AP če se ti gre za wifi.
Yossarian ::
Sranje, eden redkih, ki sem jih gledal
alexz ::
Če imamo sedaj kanal samo za animirane serije bi se spodobilo da takšen material pol umaknejo iz NICK-a kjer trenutno zapolnjuje 50 % programa. Tudi jutrani blok od NICK JR bi morali umakniti.
Ko smo že pri NICK kanalih me na iptv moti da na njih ni možno spremeniti zvoka iz slovenščine v angleščino.
Je na kabelski na EON BOX to možno ?
Veron ::
Telemach je izredno prijazen, da prvo pošlje po pošti in nato še pokličejo, da javijo neke nadgradnje s 4.8.
Spremenile so bodo frekvence določnih kanalov.
Super, hvala za obvestilo. Povprašam, če mi lahko povedo ali pošljejo seznam kanalov in spremenjenih frekvenc. Tega podatka pa nimajo.
Ko se to zgodi, si bom zapisal kateri kanali mankajo, nato pa prosil koga, ki bo dal avtomatično iskanje, če bo lahko posredoval frekvence.
BorutK-73 ::
Če kaj pomaga veron:
https://telemach.si/Pomoc/Novosti-in-Ob...
glej
Nadgradnja digitalne programske sheme D3 na širšem območju Ljubljana Šiška in okolice
ali
Nadgradnja digitalne programske sheme D3 na širšem območju Ljubljana Moste Polje in okolice
Kaj prinaša nova shema EON?
Programi so razvrščeni v 9 žanrskih sklopov, kot so Domači, Filmski, Otroški, Športni in drugi, ki se začenjajo na programskih mestih 1, 100, 200, 300 … Na ta način boste lažje iskali programe znotraj posameznih žanrskih sklopov.
Ker sledimo standardom predvajanja vsebin v visoki kakovosti, bodo programi, ki so bili sedaj v shemi podvojeni v standardni SD in visoki ločljivosti HD, odslej vidni samo še v ločljivosti HD.
glej
ali
- spremenil: BorutK-73 ()
Veron ::
Mi tale obvestilo ne pomagajo, bi potreboval frekvence, na katerih se kanali nahajajo (uporabljamo kartico direktno v TVju)
http://www.kabelska.net/viewtopic.php?t...
Takole. Seznam kanalov, katerim se frekvenca spremeni in nova frekvenca spremenjenih kanalov.
