Python keyError 3
Python keyError 3
filips ::
Imam spodnjo kodo:
import os
import os.path
global classShow
global otherShow
global stevilo
global komentar
global status
global status_message
global value
global file
global string
stevilo=0
status=1
value={}
string=''
komentar={}
def toString(className='',addclass='',addnoclass=''):
    global status
    global string
    global komentar
    global classShow
    global otherShow
    global value
    if status!=0:
        if classShow=='' or otherShow=='':
            status_message=language.showClassShowOther
            status=0
        if classShow==1:
            string += "class "+className+''':
            if komentar!='':
                string += '#'+komentar[0]+"\n\t"
                for k, v in value.items():
                    if(v[1] == ''):
                        string += 'public '+k+"='"+v[0]+'''"
                    else:
                        string += 'public '+k+"='"+v[0]+'" #'+v[1]+'''
                    print (v[2]) #zbriši
                    if komentar[v[2]] in globals():
                        string += '''
	#'''+komentar[v[2]]+'''
        if addclas!='':
            string +='''
    '''+addclass+'''
            string +='''
        if otherShow==1:
            if komentar[0] in globals():
                string += '#'+komentar[0]+''
                if v['1'] == '':
                    string += '''
'''+k+'="'+v[0]+'"'
                else:
                    string += '''
'''+k+'="'+v[0]+'" #'.v[1]
                        string += '''
            if addnoclass!='':
                string +='''
'''+addnoclass+''
        return string
V if stavku:
                        string += '''
želim preveriti če spremennljivka komentar[v2] obstaja in če obstaja naj izpiše neko besedilo. Meni pa napiše napako:
Traceback (most recent call last):
  File "C:\Users\Miha\documents\visual studio 2015\Projects\Python config\Python config\pythonConfig\pythonConfig.py", line 120, in <module>
    toString('className','addclass','addnoclass')
  File "C:\Users\Miha\documents\visual studio 2015\Projects\Python config\Python config\pythonConfig\pythonConfig.py", line 79, in toString
KeyError: 3
Press any key to continue . . .
kaj je narobe sem poskusil ugotoviti s
print (komentar[0] in globals())
pa mi napiše enako napako
Spremenljivke pa imam komentar={0: '00', 1: '01', 2: '02'} in value={'a': ['b', 'c', 1], 'a2': ['b2', 'c2', 2], 'a3': ['b3', 'c3', 3]}
  • spremenil: filips ()
BigWhale ::
A lahko posljes kodo preden jo pozenes skozi code obfuscator?
Tako bo koda malo lazje berljiva.
  • spremenil: BigWhale ()
filips ::
Koda:
import os
import os.path
global classShow
global otherShow
global stevilo
global komentar
global status
global value
global file
global string
stevilo=0
status=1
value={}
string=''
komentar={}
global status
global string
global komentar
global classShow
global otherShow
global value
if status!=0:
status=0
if classShow==1:
if komentar!='':
if(v[1] == ''):
else:
string += '''
if addclas!='':
string +='''
'''+addclass+'''
string +='''
if otherShow==1:
if v['1'] == '':
string += '''
'''+k+'="'+v[0]+'"'
else:
string += '''
string += '''
if addnoclass!='':
string +='''
'''+addnoclass+''
return string
Tabulatorji mi ne primejo
Roadkill ::
Dying over here. :O
Ü
Roadkill ::
Za štart spremeni kodo, da ne boš uporabljal globalov. Ker ne veš čemu so namenjeni.
Lahko tudi probaš razložit kaj naj bi koda počela, ker se tele zmešnjave nikomur ne ljubi brat.
Ü
hruske ::
Tule ima v[2] vrednost 3, ampak ta vrednost kot key ni v dictu komentar.
Samo ... a ta moj odgovor razumeš bolj, kot mi tvojo kodo?
Namreč ... slogovno je tvoja koda grozno neberljiva. Poglej si kak pylint ali flake8, ki ti povesta kako lahko svojo kodo približaš standardom, tako da jo bo znal še kdo kdaj prebrati.
  • spremenilo: hruske ()
Gandalfar ::
# -*- coding: utf-8 -*-
import os
import os.path
global classShow
global otherShow
global stevilo
global komentar
global status
global value
global file
global string
stevilo=0
status=1
value={}
string=''
komentar={}
    global status
    global string
    global komentar
    global classShow
    global otherShow
    global value
    if status != 0:
        if not classShow or not otherShow:
            status_message = language.showClassShowOther
            status = 0
        else if classShow == 1:
            string += "class {}:\n".format(className)
            if komentar:
                string += '#{}\n\t'.format(komentar[0])
                    if (v[1] == ''):
                        string += 'public {}={}\n'.format(k, v[0])
                    else:
                        string += 'public {}={} #{}\n'.format(k, v[0], v[1])
                    if v[2] in komentar and komentar[v[2]] in globals():
                        string += "\n#".format(komentar[v[2]])
                        # itd..
Toliko, da se lahko znebiš teh ''': https://mkaz.tech/python-string-format....
filips ::
Sem popravil kodo, pa mi še vedno ne dela:
    '''change to type string'''
    global status
    global string
    global komentar
    global classShow
    global otherShow
    global value
    if status!=0:
            status=0
        else:
            if classShow==1:
                string += "class {}:\n    ".format(className)
                if komentar!='':
                    string +="#{}\n    ".format(komentar[0])
                    if(v[1] == ''):
                        string += "global {}\n    {}='{}'\n    ".format(k,k,v[0])
                    else:
                        string += "global {}\n    {}='{}' #{}\n    ".format(k,k,v[0],v[1])
                    try:
                        komentar[v[2]]
                    except NameError:
                        komentar[v[2]]=None
                    if komentar[v[2]] is None:
                        pass
                    else:
                        string += "\n    #{}\n    ".format(komentar[v[2]])
                if addclas!='':
                    string +="\n    {}\n    ".format(addclass)
                    string +="\n"
            if otherShow==1:#tu sem ostal
                    string += "#{}".format(komentar[0])
                    if v['1'] == '':
                        string += "\n    {}='{}".format(k,v[0])
                    else:
                        string += "\n    {}='{} #{}".format(k,v[0],v[1])
                    try:
                        komentar[v[2]]
                    except NameError:
                        komentar[v[2]]=None
                        pass
                    else:
                        string += "\n#{}".format(komentar[v[2]])
                if addnoclass!='':
                    string += "\n{}".format(addnoclass)
            return string
Popravil sem if stavek, ki mi dela težave:
                    try:
                        komentar[v[2]]
                    except NameError:
                        komentar[v[2]]=None
                        pass
                    else:
tukaj želim preveriti, če komentar[v[2]] obstaja, pa mine dela
hruske ::
Kdaj ti Python interpreter vrže NameError in kdaj KeyError?
filips ::
V tistem if stavku mi python vrže to:
  File "C:\Users\Miha\documents\visual studio 2015\Projects\Python config\Python config\pythonConfig\pythonConfig.py", line 126, in <module>
  File "C:\Users\Miha\documents\visual studio 2015\Projects\Python config\Python config\pythonConfig\pythonConfig.py", line 83, in toString
    komentar[v[2]]
KeyError: 3
hruske ::
filips ::
V napaki mi napiše da je KeyError 3
hruske ::
Zakaj potem loviš NameError?
try:
    komentar[v[2]]
except NameError:
    komentar[v[2]]=None
filips ::
KeyError sem zdaj popravil.
Zdaj imam to kodo:
def toString(className='',addclass='',addnoclass=''): #popravi vrstni red izpisovanja
    global status
    global string
    global komentar
    global classShow
    global otherShow
    global value
    if status!=0:
            status=0
        else:
            if classShow==1:
                try:
                    komentar[0]
                except KeyError:
                    komentar[0]=None
                if komentar[0] is None:
                    pass
                else:
                    if(v[1] == ''):
                        string += "global {}\n    {} = '{}'\n    ".format(k,k,v[0])
                    else:
                        string += "global {}\n    {} = '{}' #{}\n    ".format(k,k,v[0],v[1])
                    try:
                        komentar[v[2]]
                    except KeyError:
                        komentar[v[2]]=None
                        pass
                    else:
                if addclass!='':
                    string +="\n"
            if otherShow==1:
                try:
                    komentar[0]
                except KeyError:
                    komentar[0]=None
                    pass
                else:
                    if v[1] == '':
                        string += "\n{} = '{}'".format(k,v[0])
                    else:
                        string += "\n{} = '{}' #{}".format(k,v[0],v[1])
                    try:
                        komentar[v[2]]
                    except KeyError:
                        komentar[v[2]]=None
                        pass
                    else:
                        string += "\n\n#{}".format(komentar[v[2]])
                if addnoclass!='':
            return string
Spremenljivke imam value={'a': ['b', 'c', 1], 'a2': ['b2', 'c2', 2], 'a3': ['b3', 'c3', 3]} in komentar={0: '00', 1: '01', 2: '02', 3: None}
S funkcijo toString bi rad da mi vrne tole:
class className:\n    #00\n    global a\n    a = 'b' #c\n    \n    #01\n    global a2\n    a2 = 'b2' #c2\n    \n    #02\n    global a3\n    a3 = 'b3' #c3\n    \n    addclass\n    \n\n#00\na = 'b' #c\n#01\na2 = 'b2' #c2\n#02\na3 = 'b3' #c3\n\naddnoclass
torej bi napisalo:
class className:
    #00
    global a
    a = 'b' #c
    #01
    global a2
    a2 = 'b2' #c2
    #02
    global a3
    a3 = 'b3' #c3
    addclass
#00
a = 'b' #c
#01
a2 = 'b2' #c2
#02
a3 = 'b3' #c3
addnoclass
če pa zaženem to kodo pa mi napiše s čisto premešanim vrstnim redom kot je:
class className:
    #00
    global a3
    a3 = 'b3' #c3
    global a2
    a2 = 'b2' #c2
    #02
    global a
    a = 'b' #c
    #01
    addclass
#00
a3 = 'b3' #c3
a2 = 'b2' #c2
#02
a = 'b' #c
#01
addnoclass
kaj naj naredim, da bo napisalo, tako kot bi jaz želel?
Odgovor prosim čim prej
filips ::
Kako bi naredil da bi vrnilo to v pravem vrstnem redu
Prosim za čimprejšnji odgovor
Slo-Tech userscripts
Oddelek: Izdelava spletišč
267113 (449) deepsick
Python končnica datoteke
Oddelek: Programiranje
51558 (1473) filips
Python napaka: IndentationError: unindent does not match any outer indentation level
131102 (1032) jan_g
[Java]kompailiranje iz cmd
91690 (1414) ragezor
[C++] for {}
292063 (1757) Gundolf
