Forum » Programiranje » Python keyError 3
Python keyError 3
filips ::
Imam spodnjo kodo:
Spremenljivke pa imam komentar={0: '00', 1: '01', 2: '02'} in value={'a': ['b', 'c', 1], 'a2': ['b2', 'c2', 2], 'a3': ['b3', 'c3', 3]}
import os
import os.path
global classShow
global otherShow
global stevilo
global komentar
global status
global status_message
global value
global file
global string
stevilo=0
status=1
value={}
string=''
komentar={}
def toString(className='',addclass='',addnoclass=''):
global status
global string
global komentar
global classShow
global otherShow
global value
if status!=0:
if classShow=='' or otherShow=='':
status_message=language.showClassShowOther
status=0
if classShow==1:
string += "class "+className+''':
if komentar!='':
string += '#'+komentar[0]+"\n\t"
for k, v in value.items():
if(v[1] == ''):
string += 'public '+k+"='"+v[0]+'''"
else:
string += 'public '+k+"='"+v[0]+'" #'+v[1]+'''
print (v[2]) #zbriši
if komentar[v[2]] in globals():
string += '''
#'''+komentar[v[2]]+'''
if addclas!='':
string +='''
'''+addclass+'''
string +='''
if otherShow==1:
if komentar[0] in globals():
string += '#'+komentar[0]+''
if v['1'] == '':
string += '''
'''+k+'="'+v[0]+'"'
else:
string += '''
'''+k+'="'+v[0]+'" #'.v[1]
string += '''
if addnoclass!='':
string +='''
'''+addnoclass+''
return string
V if stavku: if komentar[v[2]] in globals():
string += '''
'''želim preveriti če spremennljivka komentar[v2] obstaja in če obstaja naj izpiše neko besedilo. Meni pa napiše napako: Traceback (most recent call last):
File "C:\Users\Miha\documents\visual studio 2015\Projects\Python config\Python config\pythonConfig\pythonConfig.py", line 120, in <module>
toString('className','addclass','addnoclass')
File "C:\Users\Miha\documents\visual studio 2015\Projects\Python config\Python config\pythonConfig\pythonConfig.py", line 79, in toString
KeyError: 3
Press any key to continue . . .kaj je narobe sem poskusil ugotoviti s print (komentar[0] in globals())pa mi napiše enako napako
- spremenil: filips ()
BigWhale ::
A lahko posljes kodo preden jo pozenes skozi code obfuscator?
Tako bo koda malo lazje berljiva.
- spremenil: BigWhale ()
filips ::
Koda:
import os
import os.path
global classShow
global otherShow
global stevilo
global komentar
global status
global value
global file
global string
stevilo=0
status=1
value={}
string=''
komentar={}
global status
global string
global komentar
global classShow
global otherShow
global value
if status!=0:
status=0
if classShow==1:
if komentar!='':
if(v[1] == ''):
else:
string += '''
if addclas!='':
string +='''
'''+addclass+'''
string +='''
if otherShow==1:
if v['1'] == '':
string += '''
'''+k+'="'+v[0]+'"'
else:
string += '''
string += '''
if addnoclass!='':
string +='''
'''+addnoclass+''
return string
Tabulatorji mi ne primejo
import os
import os.path
global classShow
global otherShow
global stevilo
global komentar
global status
global value
global file
global string
stevilo=0
status=1
value={}
string=''
komentar={}
global status
global string
global komentar
global classShow
global otherShow
global value
if status!=0:
status=0
if classShow==1:
if komentar!='':
if(v[1] == ''):
else:
string += '''
if addclas!='':
string +='''
'''+addclass+'''
string +='''
if otherShow==1:
if v['1'] == '':
string += '''
'''+k+'="'+v[0]+'"'
else:
string += '''
string += '''
if addnoclass!='':
string +='''
'''+addnoclass+''
return string
Roadkill ::
Za štart spremeni kodo, da ne boš uporabljal globalov. Ker ne veš čemu so namenjeni.
Lahko tudi probaš razložit kaj naj bi koda počela, ker se tele zmešnjave nikomur ne ljubi brat.
Ü
hruske ::
Tule ima v[2] vrednost 3, ampak ta vrednost kot key ni v dictu komentar.
Samo ... a ta moj odgovor razumeš bolj, kot mi tvojo kodo?
Namreč ... slogovno je tvoja koda grozno neberljiva. Poglej si kak pylint ali flake8, ki ti povesta kako lahko svojo kodo približaš standardom, tako da jo bo znal še kdo kdaj prebrati.
- spremenilo: hruske ()
Gandalfar ::
# -*- coding: utf-8 -*-
import os
import os.path
global classShow
global otherShow
global stevilo
global komentar
global status
global value
global file
global string
stevilo=0
status=1
value={}
string=''
komentar={}
global status
global string
global komentar
global classShow
global otherShow
global value
if status != 0:
if not classShow or not otherShow:
status_message = language.showClassShowOther
status = 0
else if classShow == 1:
string += "class {}:\n".format(className)
if komentar:
string += '#{}\n\t'.format(komentar[0])
if (v[1] == ''):
string += 'public {}={}\n'.format(k, v[0])
else:
string += 'public {}={} #{}\n'.format(k, v[0], v[1])
if v[2] in komentar and komentar[v[2]] in globals():
string += "\n#".format(komentar[v[2]])
# itd..
Toliko, da se lahko znebiš teh ''': https://mkaz.tech/python-string-format....
filips ::
Sem popravil kodo, pa mi še vedno ne dela:
Popravil sem if stavek, ki mi dela težave:
'''change to type string'''
global status
global string
global komentar
global classShow
global otherShow
global value
if status!=0:
status=0
else:
if classShow==1:
string += "class {}:\n ".format(className)
if komentar!='':
string +="#{}\n ".format(komentar[0])
if(v[1] == ''):
string += "global {}\n {}='{}'\n ".format(k,k,v[0])
else:
string += "global {}\n {}='{}' #{}\n ".format(k,k,v[0],v[1])
try:
komentar[v[2]]
except NameError:
komentar[v[2]]=None
if komentar[v[2]] is None:
pass
else:
string += "\n #{}\n ".format(komentar[v[2]])
if addclas!='':
string +="\n {}\n ".format(addclass)
string +="\n"
if otherShow==1:#tu sem ostal
string += "#{}".format(komentar[0])
if v['1'] == '':
string += "\n {}='{}".format(k,v[0])
else:
string += "\n {}='{} #{}".format(k,v[0],v[1])
try:
komentar[v[2]]
except NameError:
komentar[v[2]]=None
pass
else:
string += "\n#{}".format(komentar[v[2]])
if addnoclass!='':
string += "\n{}".format(addnoclass)
return stringPopravil sem if stavek, ki mi dela težave:
try:
komentar[v[2]]
except NameError:
komentar[v[2]]=None
pass
else:
string += "\n#{}".format(komentar[v[2]])tukaj želim preveriti, če komentar[v[2]] obstaja, pa mine dela filips ::
V tistem if stavku mi python vrže to:
File "C:\Users\Miha\documents\visual studio 2015\Projects\Python config\Python config\pythonConfig\pythonConfig.py", line 126, in <module>
File "C:\Users\Miha\documents\visual studio 2015\Projects\Python config\Python config\pythonConfig\pythonConfig.py", line 83, in toString
komentar[v[2]]
KeyError: 3
Press any key to continue . . . filips ::
KeyError sem zdaj popravil.
Zdaj imam to kodo:
S funkcijo toString bi rad da mi vrne tole:
Odgovor prosim čim prej
Zdaj imam to kodo:
def toString(className='',addclass='',addnoclass=''): #popravi vrstni red izpisovanja
global status
global string
global komentar
global classShow
global otherShow
global value
if status!=0:
status=0
else:
if classShow==1:
try:
komentar[0]
except KeyError:
komentar[0]=None
if komentar[0] is None:
pass
else:
if(v[1] == ''):
string += "global {}\n {} = '{}'\n ".format(k,k,v[0])
else:
string += "global {}\n {} = '{}' #{}\n ".format(k,k,v[0],v[1])
try:
komentar[v[2]]
except KeyError:
komentar[v[2]]=None
pass
else:
if addclass!='':
string +="\n"
if otherShow==1:
try:
komentar[0]
except KeyError:
komentar[0]=None
pass
else:
if v[1] == '':
string += "\n{} = '{}'".format(k,v[0])
else:
string += "\n{} = '{}' #{}".format(k,v[0],v[1])
try:
komentar[v[2]]
except KeyError:
komentar[v[2]]=None
pass
else:
string += "\n\n#{}".format(komentar[v[2]])
if addnoclass!='':
return stringSpremenljivke imam value={'a': ['b', 'c', 1], 'a2': ['b2', 'c2', 2], 'a3': ['b3', 'c3', 3]} in komentar={0: '00', 1: '01', 2: '02', 3: None}S funkcijo toString bi rad da mi vrne tole:
class className:\n #00\n global a\n a = 'b' #c\n \n #01\n global a2\n a2 = 'b2' #c2\n \n #02\n global a3\n a3 = 'b3' #c3\n \n addclass\n \n\n#00\na = 'b' #c\n#01\na2 = 'b2' #c2\n#02\na3 = 'b3' #c3\n\naddnoclasstorej bi napisalo:
class className:
#00
global a
a = 'b' #c
#01
global a2
a2 = 'b2' #c2
#02
global a3
a3 = 'b3' #c3
addclass
#00
a = 'b' #c
#01
a2 = 'b2' #c2
#02
a3 = 'b3' #c3
addnoclass
če pa zaženem to kodo pa mi napiše s čisto premešanim vrstnim redom kot je: class className:
#00
global a3
a3 = 'b3' #c3
global a2
a2 = 'b2' #c2
#02
global a
a = 'b' #c
#01
addclass
#00
a3 = 'b3' #c3
a2 = 'b2' #c2
#02
a = 'b' #c
#01
addnoclasskaj naj naredim, da bo napisalo, tako kot bi jaz želel?Odgovor prosim čim prej
filips ::
Kako bi naredil da bi vrnilo to v pravem vrstnem redu
Prosim za čimprejšnji odgovor
| » | Slo-Tech userscriptsOddelek: Izdelava spletišč | 7113 (449) | deepsick |
| » | Python končnica datotekeOddelek: Programiranje | 1558 (1473) | filips |
| » | Python napaka: IndentationError: unindent does not match any outer indentation levelOddelek: Programiranje | 1102 (1032) | jan_g |
| » | [Java]kompailiranje iz cmdOddelek: Programiranje | 1690 (1414) | ragezor |
| » | [C++] for {}Oddelek: Programiranje | 2063 (1757) | Gundolf |
