pošiljanje XMlja na url
Kibernetik ::
Kakšna ideja kako poslati XML podatke na določen URL preko PHPja. Nikakor mi ne rata, potrebujem za pošiljanje SMSov na portalu smsapi.si. Hvala za pomoč!
kunigunda ::
nekak tko (nism php-jas)
$ch = curl_init();
curl_setopt($ch, CURLOPT_URL,$url);
curl_setopt ($ch, CURLOPT_RETURNTRANSFER, true);
curl_setopt ($ch, CURLOPT_POST, 1);
curl_setopt ($ch, CURLOPT_POSTFIELDS, $xml);
$output = curl_exec ($ch);
curl_close ($ch);
mogoce bos mogu se content-type nastimat
amacar ::
Sej imajo na spletni strani navodila.
//prepare data
$url = 'https://www.smsapi.si/poslji-sms';            //url we are posting to (defined in sms api documentation)
$data = array('un' => urlencode('api_username'),     //api username
              'ps' => urlencode('api password'),     //api pass
              'from' => urlencode('031492148'),      //don't send as int
              'to' => urlencode('031492148'),        //don't send as int
              'm' => urlencode('Testno sporocilo'),  //msg
              'cc' => urlencode('386')               //don't send as int
$response  = doPostRequest($url, $data);
echo($response);
 * Posts $data on $url and returns content of website
 * POST request was made to.
 * @param $url - url where we are posting data
 * @param $data - array with key => value pairs for post
 *                e.g. array('un' => 'example', 'ps' => 'pass', ...)
 * @return string
function doPostRequest($url, $data) {
    // Initialisation
    $ch=curl_init();
    // Set parameters
    curl_setopt($ch, CURLOPT_URL, $url);
    curl_setopt($ch, CURLOPT_AUTOREFERER, true);
    // Activate the POST method
    curl_setopt($ch, CURLOPT_RETURNTRANSFER, 1);
    curl_setopt($ch, CURLOPT_POST, 1) ;
    // Request
    curl_setopt($ch, CURLOPT_POSTFIELDS, $data);
    curl_setopt($ch, CURLOPT_SSL_VERIFYPEER, 0);
    curl_setopt($ch, CURLOPT_SSL_VERIFYHOST, 0);
    // execute the connexion
    $result = curl_exec($ch);
    // Close it
    curl_close($ch);
    return $result;
Kibernetik ::
Ni to prava oblika. Nekako takole stvar deluje:
$xml_data ='xml podatki';
$URL = "http://www.smsapi.si/poslji-masovni-sms/";
			$ch = curl_init($URL);
			//curl_setopt($ch, CURLOPT_MUTE, 1);
			curl_setopt($ch, CURLOPT_POST, 1);
			curl_setopt($ch, CURLOPT_HTTPHEADER, array('Content-Type: text/xml'));
			curl_setopt($ch, CURLOPT_POSTFIELDS, "$xml_data");
			$output = curl_exec($ch);
			curl_close($ch);
Davčna blahajna - PHP - certifikati
Oddelek: Programiranje
51548 (1314) app5771283
Pornhub s HTTPS protokolom nad požrešne ISP-je (strani: 1 2 )
Oddelek: Novice / Zasebnost
5829427 (18084) M.B.
PHP davčna blagajna
189044 (7068) brble
cURL
Oddelek: Omrežja in internet
101324 (1114) d4vid
[PHP] Uporaba cURL s HTTPS
112066 (1809) JercSI
