Forum » Programiranje » java filter excepion handling
BRBR ::
Tole je v filtru, skozi filter gre en .jsp
1. Ne gre v exception
2. strOut = HTML, ki pa iz nekega razloga ni celoten
3. Isti .jsp brez filtra, vse dela OK - HTML = celoten.
4. Ničesar v server logih.
5. Se pravi nekaj mora iti narobe ? znotraj naslednjega try/except. Morda pa ne ujamem vseh exceptionov ?
Copy/paste coda z neta, oracle kolikor se spomnim
GenericResponseWrapper wrappedResponse = null;
byte[] bytes = null;
try
OutputStream out = response.getOutputStream();
wrappedResponse = new GenericResponseWrapper((HttpServletResponse) response);
chain.doFilter(request,wrappedResponse);//throws IOException, ServletException
bytes = wrappedResponse.getData();
catch (Exception ex)
String strOut = new String(bytes);
public class FilterServletOutputStream extends ServletOutputStream {
private DataOutputStream stream;
public FilterServletOutputStream(OutputStream output) {
stream = new DataOutputStream(output);
public void write(int b) throws IOException {
stream.write(b);
public void write(byte[] b) throws IOException {
stream.write(b);
public void write(byte[] b, int off, int len) throws IOException {
stream.write(b,off,len);
public class GenericResponseWrapper extends HttpServletResponseWrapper {
private ByteArrayOutputStream output;
private int contentLength;
private String contentType;
public GenericResponseWrapper(HttpServletResponse response) {
super(response);
output=new ByteArrayOutputStream();
public byte[] getData() {
return output.toByteArray();
@Override
public ServletOutputStream getOutputStream() {
return new FilterServletOutputStream(output);
@Override
public PrintWriter getWriter() {
return new PrintWriter(getOutputStream(),true);
@Override
public void setContentLength(int length) {
this.contentLength = length;
super.setContentLength(length);
public int getContentLength() {
return contentLength;
@Override
public void setContentType(String type) {
this.contentType = type;
super.setContentType(type);
@Override
public String getContentType() {
return contentType;
Spura ::
Ce imas delegate pattern moras delegirat vse methods. Ti ne posredujes flush in close callov, verjetno ker se ti ni dalo vseh metod delegirat.
| » | [JAVA] HTTPS clientOddelek: Programiranje | 3691 (2421) | peterv6i |
| » | Jasper subreportOddelek: Programiranje | 2252 (2001) | nightrage |
| » | tomcat - problem z encodingomOddelek: Programiranje | 2694 (2608) | kopernik |
| » | Java - JBoss - Servlet - getOutputStream() has already been called for this responseOddelek: Programiranje | 1397 (1314) | kopernik |
| » | Kako pošiljanje datotek v JAVI.Oddelek: Programiranje | 2241 (2112) | kopernik |
