Forum » Programiranje » rabim pomoč c++
rabim pomoč c++
kretze ::
zdravo folk kaj gdo ve kaj je tu narobe??
#include <iostream>
#include <stdlib.h>
#include <string>
using namespace std;
void printvals(void(*pfunc)(int & ,int & ),int x, int y)
cout << "x: " << x << "y: " << y << endl;
pfunc(x, y);
void square(int &rx, int &ry)
rx *= rx;
ry *= ry;
void cube(int &rx, int & ry)
int tmp;
tmp = rx;
rx *= rx;
rx = rx*tmp;
tmp = ry;
ry *= ry;
ry = ry*tmp;
void swap(int &rx,int &ry)
int tmp;
tmp = rx;
rx = ry;
ry = tmp;
void getvals(int &rvalOne, int & rvalTwo)
cout << "new value for rvalone :";
cin >> rvalOne;
cout << "new value for rvaltwo :";
cin >> rvalTwo;
int main()
int rvalOne = 1, rvalTwo = 2;
int choice;
bool fquit = false;
void(*pFunc)(int &, int&);
while (fquit == false)
cout << "(0) quit (1) change values (2) square (3) cube (4) swap ";
cin >> choice;
switch (choice)
case 1:
pFunc = getvals;
break;
case 2:
pFunc = square;
break;
case 3:
pFunc = cube;
break;
case 4:
pFunc = swap;
break;
default:
fquit = true;
break;
if (fquit == false)
printvals(pFunc, rvalOne, rvalTwo);
system("pause");
return 0;
Red_Mamba ::
premalo informacij mogoce?
[st.slika https://img.shields.io/badge/Slo-Tech-green.svg test]
Linkedin >> http://goo.gl/839Aua
Mamba's Crypto & ICO's: https://t.me/joinchat/AAAAAExTkO4P4UDy0fIZdg
kretze ::
Error list mi to napako javi: Error1 error C4703: potentially uninitialized local pointer variable 'pFunc' used
Red_Mamba ::
ja pa verjetno tudi pove v kateri vrstici zajamra?
smoke ::
Naredi eno prazno funkcijo in z njo inicializiraj pFunc v defaultu. Problem je, da če program ubere default vejitev v switchu, je pFunc neinicializiran.
Smurf ::
Ni potrebe po prazni funkciji. Zgolj inicializiraj na zacetku kot pFunc = NULL. Potem je pa se lepse, da ko klices funkcijo s tem pointer parametrom, da preveris, ce je razlicen od NULL.
- spremenil: Smurf ()
smoke ::
@Smurf, potem raje "nullptr", glede na to da ima C++. Čeprav, če naredi prazno funkcijo se ifu čisto izogne in ima Null Object pattern.
Smurf ::
@Smurf, potem raje "nullptr", glede na to da ima C++. Čeprav, če naredi prazno funkcijo se ifu čisto izogne in ima Null Object pattern.![]()
A, mea culpa. Narobe razumel prvotni nasvet. Se strinjam, da je to se lepse.
galu ::
Tretiranje potencialne logične napake kot compile error je malo hecno - pametnejša odločitev s strani MS bi bila zgolj izpis opozorila. g++ tega featurja nima in prevede (celo brez opozoril).
Tako to gre.
Mavrik ::
Kodrkoli s pol možganov piše C++ kodo z -Wall -Werror . Ta odpustljivost g++ povrzroča neskončne težave ker se programerjev ne tepe dovolj ko pišejo drek kodo.
galu ::
No, pa prevedi s temi zastavicami, pa javi, če ti vrne kaj napak. Verzija 4.9.2 jih ne (in obstaja še ogromno potencialnih problemov, ki jih spregleda).
Ta odpustljivost je del koncepta jezika C/C++, kjer bi naj programer vedel, kaj dela. Za gledanje pod prste obstajajo boljši jeziki.
Tako to gre.
| » | [c++] konstruktorjiOddelek: Programiranje | 6790 (6119) | AndrejO |
| » | [C] Sinhronizacija procesovOddelek: Programiranje | 1518 (1391) | Cvenemir |
| » | Program v COddelek: Programiranje | 2343 (2182) | darkkk |
| » | Pomnilnik in c++Oddelek: Programiranje | 2598 (2307) | Gundolf |
| » | Dev-C++ in napaka pri prevajanju funkcijOddelek: Programiranje | 1409 (1258) | MartnKrp |
