rabim pomoč c++
rabim pomoč c++
kretze ::
zdravo folk kaj gdo ve kaj je tu narobe??
#include <iostream>
#include <stdlib.h>
#include <string>
using namespace std;
void printvals(void(*pfunc)(int & ,int & ),int x, int y)
	cout << "x: " << x << "y: " << y << endl;
	pfunc(x, y);
void square(int &rx, int &ry)
	rx *= rx;
	ry *= ry;
void cube(int &rx, int & ry)
	int tmp;
	tmp = rx;
	rx *= rx;
	rx = rx*tmp;
	tmp = ry;
	ry *= ry;
	ry = ry*tmp;
void swap(int &rx,int &ry)
	int tmp;
	tmp = rx;
	rx = ry;
	ry = tmp;
void getvals(int &rvalOne, int & rvalTwo)
	cout << "new value for rvalone :";
	cin >> rvalOne;
	cout << "new value for rvaltwo :";
	cin >> rvalTwo;
int main()
	int rvalOne = 1, rvalTwo = 2;
	int choice;
	bool fquit = false;
	void(*pFunc)(int &, int&);
	while (fquit == false)
		cout << "(0) quit (1) change values (2) square (3) cube (4) swap ";
		cin >> choice;
		switch (choice)
		case 1:
			pFunc = getvals;
			break;
		case 2:
			pFunc = square;
			break;
		case 3:
			pFunc = cube;
			break;
		case 4:
			pFunc = swap;
			break;
		default:
			fquit = true;
			break;
		if (fquit == false)
			printvals(pFunc, rvalOne, rvalTwo);
	system("pause");
	return 0;
Red_Mamba ::
premalo informacij mogoce?
[st.slika https://img.shields.io/badge/Slo-Tech-green.svg test]
Linkedin >> http://goo.gl/839Aua
Mamba's Crypto & ICO's: https://t.me/joinchat/AAAAAExTkO4P4UDy0fIZdg
kretze ::
Error list mi to napako javi: Error1 error C4703: potentially uninitialized local pointer variable 'pFunc' used
Red_Mamba ::
ja pa verjetno tudi pove v kateri vrstici zajamra?
kretze ::
line 90
smoke ::
Naredi eno prazno funkcijo in z njo inicializiraj pFunc v defaultu. Problem je, da če program ubere default vejitev v switchu, je pFunc neinicializiran.
Smurf ::
Ni potrebe po prazni funkciji. Zgolj inicializiraj na zacetku kot pFunc = NULL. Potem je pa se lepse, da ko klices funkcijo s tem pointer parametrom, da preveris, ce je razlicen od NULL.
  • spremenil: Smurf ()
smoke ::
@Smurf, potem raje "nullptr", glede na to da ima C++. Čeprav, če naredi prazno funkcijo se ifu čisto izogne in ima Null Object pattern. :)
Smurf ::
smoke je izjavil:
A, mea culpa. Narobe razumel prvotni nasvet. Se strinjam, da je to se lepse.
galu ::
Tretiranje potencialne logične napake kot compile error je malo hecno - pametnejša odločitev s strani MS bi bila zgolj izpis opozorila. g++ tega featurja nima in prevede (celo brez opozoril).
Tako to gre.
Mavrik ::
galu je izjavil:
Kodrkoli s pol možganov piše C++ kodo z -Wall -Werror . Ta odpustljivost g++ povrzroča neskončne težave ker se programerjev ne tepe dovolj ko pišejo drek kodo.
galu ::
No, pa prevedi s temi zastavicami, pa javi, če ti vrne kaj napak. Verzija 4.9.2 jih ne (in obstaja še ogromno potencialnih problemov, ki jih spregleda).
Ta odpustljivost je del koncepta jezika C/C++, kjer bi naj programer vedel, kaj dela. Za gledanje pod prste obstajajo boljši jeziki.
Tako to gre.
[c++] konstruktorji
Oddelek: Programiranje
296700 (6029) AndrejO
[C] Sinhronizacija procesov
71499 (1372) Cvenemir
Program v C
52334 (2173) darkkk
Pomnilnik in c++
242582 (2291) Gundolf
Dev-C++ in napaka pri prevajanju funkcij
181397 (1246) MartnKrp
