Forum » Kaj kupiti » Ati 9500 ali 9600
Ati 9500 ali 9600
WarMaker ::
Katera od navedenih kartic je boljša?
SAPPHIRE ATI RAD9600Pro 128M DDR TvOutDVI 8X ali SAPPHIRE RADEON 9500Pro, 128MB, DDR, DVI, TV-out
boštjan ::
WarMaker ::
frenk:
Jaz zdej sestavljam nov računalnik in zato bi rad vedel, katera od teh dveh je boljša! Kot vidim (hvala boštjan) je Ati 9600 Pro 128 MB boljša kot 9500Pro!
San ::
Ne ni! Od kje ti ta zaključek, sploh znaš angleško?!
Beyon3D: ATI set a tall order for themselves with the R300 based 9500 PRO and in nearly all cases the 9600 PRO falls short of ousting that in performance.
HardOCP: Perhaps the only card that will give the Radeon 9600 Pro a run for its money is the card it is set to replace, the Radeon 9500 Pro. Those who can still find the 9500 Pro for sale would do well to pick one up while they can. As we have seen throughout this review, the Radeon 9500 Pro offers the best overall performance in its category.
AnandTech: The Radeon 9500 Pro is still the best performing solution out there in this price range, however the production run was quite limited and you won't be able to find those cards to be too available in the future so grab them while you can.
Očitno ne!
Očitno ne!
WarMaker ::
Aha! Tega sploh nisem gledal! Pogledal sem samo tabele! Imaš prav 9500 Pro je očitno boljša! Bom verjetno vzel 9500Pro!
boštjan ::
kako lahko recete da je 9500pro boljsa od 9600pro?? po cem to sploh sklepate? srarejsa stvar boljsa od nove?rajt... ok res je hitrejsa, zaradi 8 cevovodov, samo se bo pa 9600pro usen mnogo bols naviju, pa tut bol je optimiziran za use skupi.
ampak zaenkrat se ti useen bl splaca kupit 9500pro ze zarad cene.
boštjan ::
Dr._M, po testih sodeč je 9500pro res bolja,res pa je da se 9600pro hudičevo navija, a na strani(HARDCOP-sem dal link),kjer so jo navijali do skrajnosti so zapisali da upajo da se bo taka tudi prodajala in da je ne bodo omejili,kot so 9500pro,kjer moraš BIOS zamenjat in molit da boš pol lahko navijal, ker se tudi 9500pro zelo dobro navija. Mislim pa da je v tem trenutku najboljša v tem razredu 5600ultra, samo mora bit NOVA VERZIJA. Razlika med staro in novo verzijo NV31. Še TEST starejše verzije.
vidi ::
Kdaj pa kje se bo pa dobila tale FX5600 ultra (t nova), pa kakšna naj bi bila cena pri nas?
Pa še, kje so najcenejše kartice pr ns (glavni uvozniki)?
boštjan ::
vprašaj na mlacom,agt,jae,e-misija,pc hand,comtron.Na enih cenikih je že,samo ne vem pa če je ultra verzija,cena pa je okol 50k
| » | 9600pro ali 5600ultra?Oddelek: Kaj kupiti | 2353 (2035) | DjTonic |
| » | ATI Radeon 9500 Pro ali Gainward FX PowerPack! Ultra/780Oddelek: Kaj kupiti | 1265 (1100) | Laki |
| » | Grafična Geforce ali Ati? (strani: 1 2 )Oddelek: Kaj kupiti | 5501 (4436) | boštjan |
| » | katera grafična??Oddelek: Kaj kupiti | 1757 (1642) | c3R4R |
| » | NV35 ali GeF FX 5900 Ultra (strani: 1 2 )Oddelek: Strojna oprema | 6124 (5414) | Ahiles |
