Forum » Programiranje » c# RSACryptoServiceProvider..SignData(data,"SHA1") kako v Javi?
peterv6i ::
Pozdrav,
za potrebe nekega webservisa moram del xml-ja podpisati s certifikatom..
Imam metodo v c# vendar me zanima kako bi to izvedel v Javi
Torej v Javi bi rad naložil certifikat xy.cer ko poženem kodo in s tem certifikatom podpisal nek String kot je to v zgornji metodi csp.SignData(data,"SHA1")
Ima kdo kakšen primer?
hvala in lp
Peter
private string SignCertificate(string cn,string text)
string potpis = "";
// Open certificate store of current user
X509Store my = new X509Store(StoreName.My, StoreLocation.CurrentUser);
my.Open(OpenFlags.ReadOnly);
// Look for the certificate with specific subject
RSACryptoServiceProvider csp = null;
foreach (X509Certificate2 cert in my.Certificates)
if (cert.Subject.Contains(cn))
if (cert.NotAfter < DateTime.Now || cert.NotBefore > DateTime.Now)
continue;
// retrieve private key
csp = (RSACryptoServiceProvider)cert.PrivateKey;
break;
if (csp == null)
throw new Exception("Valid certificate was not found");
// Hash the data
UTF8Encoding encoding = new UTF8Encoding();
byte[] data = encoding.GetBytes(text);
string hex = BitConverter.ToString(csp.SignData(data,"SHA1"));
potpis = hex.Replace("-", "");
return potpis;
hvala in lp
Peter
| » | Davčne blagajne (strani: 1 2 3 4 … 24 25 26 27 )Oddelek: Programiranje | 389631 (129634) | Macketina |
| » | E-računOddelek: Programiranje | 8851 (5614) | ivanhoe5x |
| » | [JAVA] HTTPS clientOddelek: Programiranje | 3679 (2409) | peterv6i |
| » | [c#] Majhen problemčekOddelek: Programiranje | 1370 (1178) | darkolord |
| » | [C#] DateTime v bazoOddelek: Programiranje | 1713 (1600) | teac |
