c# RSACryptoServiceProvider..SignData(data,"SHA1") kako v Javi?
peterv6i ::
Pozdrav,
za potrebe nekega webservisa moram del xml-ja podpisati s certifikatom..
Imam metodo v c# vendar me zanima kako bi to izvedel v Javi
private string SignCertificate(string cn,string text)
            string potpis = "";
            // Open certificate store of current user
            X509Store my = new X509Store(StoreName.My, StoreLocation.CurrentUser);
            my.Open(OpenFlags.ReadOnly);
            // Look for the certificate with specific subject
            RSACryptoServiceProvider csp = null;
            foreach (X509Certificate2 cert in my.Certificates)
                if (cert.Subject.Contains(cn))
                    if (cert.NotAfter < DateTime.Now || cert.NotBefore > DateTime.Now)
                        continue;
                    // retrieve private key
                    csp = (RSACryptoServiceProvider)cert.PrivateKey;
                    break;
            if (csp == null)
                throw new Exception("Valid certificate was not found");
            // Hash the data
            UTF8Encoding encoding = new UTF8Encoding();
            byte[] data = encoding.GetBytes(text);
            string hex = BitConverter.ToString(csp.SignData(data,"SHA1"));
            potpis = hex.Replace("-", "");
            return potpis;
Torej v Javi bi rad naložil certifikat xy.cer ko poženem kodo in s tem certifikatom podpisal nek String kot je to v zgornji metodi csp.SignData(data,"SHA1")
Ima kdo kakšen primer?
hvala in lp
Peter
Davčne blagajne (strani: 1 2 3 4 … 24 25 26 27 )
Oddelek: Programiranje
1344389605 (129608) Macketina
E-račun
218851 (5614) ivanhoe5x
[JAVA] HTTPS client
173679 (2409) peterv6i
[c#] Majhen problemček
101370 (1178) darkolord
[C#] DateTime v bazo
51713 (1600) teac
