XHTML
XHTML
[MYTiX] ::
Spišem en page u XHTML z doctype od 1.0 transitonal. Pol dodam še CSS sam CSS ne dela. Pol menjam doctype na HTML 4.01 in dela vse uredu. Kaj xhtml ne podpira CSS (skoraj nemogoče)?
Ziga Dolhar ::
Bi nam postregel s svojo kodo oz. povezavo?
p.s.: preskusi w3c css in xhtml validator.
https://dolhar.si/
[MYTiX] ::
S tem doctypom dela:
< !DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
< html>
< head>
< meta http-equiv="Content-language" content="SL" />
< meta http-equiv="Content-type" content="text/html; charset=iso-8859-2" />
< meta http-equiv="Reply-to" content="mperic2@yahoo.com" />
< meta name="keywords" content="igre, emulatorji" />
< meta name="author" content="Matic MYTiX Peric" />
< meta name="publisher" content="Matic MYTiX Peric" />
< meta name="copyright" content="Matic MYTiX Peric" />
< meta name="creation_date" content="1/4/2003" />
< meta name="ROBOTS" content="ALL,INDEX,FOLLOW" />
< meta name="revisit-after" content="1 days" />
< title>Igre< /title>
< link rel="stylesheet" type="text/css" href="css/default.css" />
< /head>
< body class='body'>
Presledek je zaradi tega, ker če ne ne prikaže kode.
  • spremenil: [MYTiX] ()
OwcA ::
Znak < lahko zapišeš kot &lt;, potem ni potrebno uporabiti presledka.
Baja ::
poskusi s tem doctypom:
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN"
"http://www.w3.org/TR/xhtml1/DTD/xhtml1-...
[MYTiX] ::
S tem mi še vedno ne dela. Kaj pa ostali narediste da vam dela?
Ziga Dolhar ::
Uporabi validator.
https://dolhar.si/
glavic ::
da ne odpiram nove teme...
kako bi naredil valid xhtml ...
problem je ko hocem edino (glavno) tabelo postavit na center ?
kako ? center ni valid style="align:center" ????
Musselli bizi
darh ::
margin: auto
Excuses are useless! Results are priceless!
alesrosina ::
<table align="center">
david ::
@ASPmaster: to NI valid XHTML :)
splet01.net
Baja ::
narediš css fajl pa notri napises
.nasredino {align: center;}
ko naredis tabelo pa napises
<table class="nasredino">
  • spremenil: Baja ()
glavic ::
align: center je prvo kar sem probal
margin: auto je valid in dela ..
Musselli bizi
darh ::
Itak. >:D
[MYTiX] ::
CSS v IE5 ne dela najboljše. naprimer margin: auto ne da na sredino.
To sm opazu na šolskih računalnikih.
Kej je boljše dodat še alidgn='center' al pustim valid in nej uporabniki preklinjajo M$.
kopernik ::
centriranje tabel tako, da deluje v vseh browserjih in je tudi valid:
Center with CSS
  • spremenil: kopernik ()
glavic ::
da ne odpiram nove teme =>
kako naj naredim bookmark v xhtml 1.1 da bo valid
[a name="#skok"]aaa[/a] ne dela ker je atribut name ne obstaja vec .....
Musselli bizi
darh ::
<a id="#bukmark">Diz iz a BukMarkTM</a>
  • spremenil: darh ()
glavic ::
xbite ponovno na udaru ...
samo znak # ne sme bit notr ===> column 9: character "#" is not allowed in the value of attribute "id"
Musselli bizi
darh ::
zatipkal sem se oziroma preveč skopiral ko sem preizkušal če res dela ;) Se opravičujem.
<a id="bukmark">Diz iz a BukMarkTM</a>
CSS in začetniški problemi
Oddelek: Izdelava spletišč
71894 (1710) t3hn0
Doctype - kateri HTML doctype
172791 (2457) gregy
izdelava podstrani
122532 (2362) Bob Rock
Google prikaze cuden opis strani-kako popraviti index.html?
101430 (1239) PhotoBlaz
Kakšen program mi svetujete ? (strani: 1 2 )
887921 (7109) webfreak
