Forum » Strojna oprema » AMD Radeon R9 400 Series
buttplugs ::
Se pravi, ko bo njihova cena brez davka številsko enaka naši z davkom. 199USD = 199EUR.
D3m0r4l1z3d ::
RX 480: nekje so morali šparati, da so ceno pri 199 dolarjev obdržali
AMD Radeon RX 470 Could Surprise with Pricing http://www.techpowerup.com/
by btarunr Thursday, June 23rd 2016 08:25 Discuss (37 Comments)
AMD could deal yet another shock to NVIDIA after the Radeon RX 480, with its smaller sibling, the Radeon RX 470. This card is expected to be priced at $149 for the 4 GB variant, and $179 for the 8 GB variant. The card is rumored to feature 2,048 stream processors, spread acrosss 32 compute units, down from the 2,304 stream processors of the RX 480. Its memory ticks slower, at 7 Gbps, with a memory bandwidth of 224 GB/s. The most spectacular specification, however, is its typical board power, which is rated at 110W. The card should be faster than at least the R9 380X, and at its given specs, offer a very interesting option for 1080p gamers, at $149.
- spremenilo: D3m0r4l1z3d ()
Napajalc ::
D3m0r4l1z3d je izjavil:
To bo idealno za univerzalen vodni blok, rami so hlajeni z "back plate".
011011100111010101100010
Napajalc ::
Dvomim, nekam majhna kartica je, bi/bo pa univerzalc pasal gor, je čas da so šaltal nazaj na modularen cooler. Dost manj zajebancije.
~1.25 je nek nepisan default, h kateremu gravitira ta par.. In z nekaj sreče dosežemo to razmerje v naslednjem mesecu. Takrat zna bit 199$ = 199€.
Dream on.
Izgleda, da so se debilni Anglezi odlocili za Brexit, kar pomeni, da bo EUR tudi padel in vibstvu je ze mocno padel :S
GenZNPC ::
2 leti ne smes gor montirat vodnega, ker pol gre garancija. Najprej mora 2 leti zdrzat na stock.
skibidi
Sploh pa kaj boš dajal vodno na 470, 480.. ?
Škoda časa.
Škoda časa.
mihec87 ::
Če že imaš narejen loop sistem v kišti z zdajšnjo kartico zakaj ne... Sicer večina vodnih je vgrajenih "because i can" pa mod scena... Kaj vse se je včasih počelo na s-t..
Napajalc ::
eh, to je še r9 290 komplex..
Ah, sej vidiš kako je pri nvidiji, trotlanje ali pa premium kartica oz vodno hlajenje. "noben" neve zakaj so ukinli vapor chaber.
Napajalc ::
Čudi me da še noben ni pogruntal da je AMD ponovno inovativen, napajalni sklop je postavil za čipom = bolj učinkovito hlajenje.
Ahim ::
mihec87 ::
1 ali 2 večja ventilatorja sta lahko dosti tišja kot 1-2 na cpu ter 1+ malih brenčačev na gpu....Seveda če ni ok narjeno je tako zračno kot vodno daleč od dobrega...
Mitja358 ::
hojnikb ::
vodno hlajenje nikakor nemore bit _neslišno_, medtem ko zračno je lahko kamot (enostavno izklopiš vente in pustiš da konvekcija naredi svoje.
btw, giveaway 480k
https://www.reddit.com/r/pcmasterrace/c...
Holy crap, 87C
btw, giveaway 480k
New AMD RX 480 CrossFire benchmarks hit the web, exclusive first look at new overclocking tool
Holy crap, 87C
#brezpodpisa
- spremenil: hojnikb ()
hojnikb ::
so what če je crossfire ?
Če bi amd lepo pošlihtal fan speede oz. throttlanje, nebi blo 87c
#brezpodpisa
mihec87 ::
In kaj idlaš na namizju ob tihi kišti(saj ne govorimo o r-pi kjer je par w za odvest)-nismo v temi z low power htpcji itd....
hojnikb ::
Razn če tvoja mašina dela 95% časa na 100%, potem je idle acoustics še kako važn. Razn če si napol gluh od kakih referenčnih kart, potem pa itk nima veze.
#brezpodpisa
+ tega je crossfire.. eh hojnik, da ti nebo nvidia zmesala mozganov
Ma nisem fan nikogar, ampak včeraj sem gledal review SLI 1070. Obe kartici je pol ure gnal na na polno. Če se spomnim je bilo 79 max T in se ni več višala.
- spremenil: Machete ()
zzbil ::
Pomoje brezveze watercooling za navijanje na midrange grafi, potem raje daš denar za en "rank" boljšo grafično..a se motim?
Alien123 ::
Ne vem. Ne najdem clipa, ker nisem bil loginan.
Ne.
Ne.
sebek1 ::
Če hočeš tišino v loadu se vodno splača, črpalko lahko daš na minimum okoli 1000rpm (sicer maš pol par stopinj več samo nima veze) in bi morala bit neslišna, ventilatorje daš na 500rpm. Dual slot pri grafični ima premalo železa za 200watov hladit, kolikor sem gledal vse gtx1080 laufajo z okoli 2000rpm v loadu.
Napajalc ::
Verjetno še ni imel v rokah kaj drugega kot pumpo za ribce, pozabil da 1x 12 cm radjator na fury x dela tišje in hladneje kot superioren hladilnik na gtx 970 z "160w".
hojnikb ::
naj bo še tako fancy pumpa, neslišna v pravem pomenu besede ne bo. Pa nimam nič proti vodnemu hlajenju (ga mel tut sam neki časa), ampak je zadeva letela ven, ker enostavno mašina ne laufa kej dosti na 100%, da bi to mel smisel.
#brezpodpisa
Pa mamo tale brexit. Ja anglež je...
Smo pač stopili par let nazaj. Nič hudega. Bomo ponovno kupovali 280X namesto 1070. :)
Drug teden bo šel evro že nazaj gor. Verjetno tud funt.
buttplugs ::
Funt je padel za 11%, evro pa niti za 5%. Trump seveda srečen, ker bo lahko prijateljstvo z briti bolj tesno.
- spremenilo: buttplugs ()
