Forum » Strojna oprema » AMD ZEN - nova X86 Jedra
ziga1990 ::
^^niti ne, si ne more take taktike privoščiti sedaj ko je AMD spet v igri
Ja ampak tako bo, saj so že napovedali da bodo ostali na isti 14nm arhitekturi.
Intel bo zdaj primoran napet mišico in razkrit karte.. Nekaj se že šušlja, da bi naj Coffee lake s 14nm++ procesom prestavili v 2H 2017, kar je lahko as soon as julij, čeprav bolj realno proti koncu leta. In če tokrat resnično pohitrijo stvar za 15%, plus 6 jeder in konkurenčne cene, so spet na vrhu.
Hydros ::
Intel bo spustil cene če nimajo odgovora za ryzen in naslednji release bo verjetno 6c/12t consumer i7 in 8c/16t+ za enthusiast i7
seveda če je performance ryzena legit
Zen ma še nekej prostora pr frekvenci, in verjetno pri ceni. Tistih 10% lah dobijo not na 14nm....z frekvenco, ne rabijo letat na 10nm..ceno, pa po letih suše,,,
Intel, nooo, bo zgleda kmal drugi na vasi..... LOL.
- spremenilo: Telbanc ()
Intel, nooo, bo zgleda kmal drugi na vasi.....:)) LOL.
Samo v najbolj mokrih sanjah amd fanboyev.
AMD Ryzen 1600X $260 New Benchmarks, Matches Intel’s $430 i7 6800K
http://wccftech.com/amd-ryzen-1600x-cin...
mpressively, the 1600X which carries a similar price-tag to the unlocked Kaby Lake Core i5 7600K but manages to punch two hundred dollars above its weight and slightly outperofrm the much more expensive $430 i7 6800K. This is despite running at 100Mhz below the Intel Broadwell-e six core. This suggests that the Zen microarchitecture may be a much more formidable IPC contender than we previously thought. Outperforming Broadwell core for core and clock fore clock. Very impressive indeed.
AapocalypseE ::
Another interesting bit that we have reported on in one of our Ryzen exclusives a while back is Ryzen's amazing XFR feature, short for Extended Frequency Range. Which allows every Ryzen CPU to automatically overclock itself and exceed its default boost clock speed whenever the thermal environment allows. This means that if you invest in a cooling solution that's better than AMD's Wraith, your Ryzen chip will automatically operate at higher clock speeds than what's written on the box, rewarding you with more performance.
V stolpcih piše: XFR Unlimited Turbo - Cooling dependent
Me res zanima kako ta unlimited turbo boost deluje.
D3m0r4l1z3d ::
V tretje gre rado, phenom II 1090t kot 6jedrnik in fx 8150 kot 8 jedrnik me nista prepričala, ko sem top desktop cpu za igre kupoval, mogoče pa bo Ryzen 6/12 ali 8/16 prepričal. Cene bod retailerji nabili, če je res dober, tako da je trenutno ravno glede cen velika negotovost, še posebej izstopa primerjava s cenami, ki jih ima Intel zdaj, ker so lahko le AMDju v prid v prihodnje.
Zakaj tile leakani benchmarki niso še kaj iz iger, samo sintetika?
- spremenilo: D3m0r4l1z3d ()
Hydros ::
če bo performance res tak kot je prikazano tukaj ima Intel kar nekaj dela pred sabo da bo spet brez konkurence oziroma bi moral spustiti cene kar najbrš ne bo težava saj predvidevam da so do sedaj prodajali CPUje z ogromnim profitom vprašanje je če bo AMD lahko naredil naslednjka Ryzenu ki bo konkuriral Intelu ali spet 5 let ne bo novega CPUja od AMDja
Intelidiote že grabi panika.
Zdaj je pravi čas za upgrade saj so cene DDR4 ramov in Z170 matičnih plošč zelo nizke.
Hitro nižajte cene. To bo vse vredno 100€ čez dva tedna. :)))
Pozabljata da rekordne frekvence(ala 5.5Ghz haswell) so zgolj to, rekord in ne nekaj kar deluje uporabno, stabilno in na vseh čipih, torej takih ne moreš za XFR uporabit.
- spremenil: Lonsarg ()
Pozabljata da tele rekordne frekvenca so zgolj to, rekord in ne nekaj kar deluje uporabno, stabilno in na vseh čipih.
Kje to piše, link če lah daš, da se napasemo.
AapocalypseE ::
Po teh testih sodeč bi še overclockan 1600X bil na nivoju stock 6900K.
Me zelo zanima kaj bo s tega
A si mislu po dva komada 6700k skupaj 100 evrov? Ali celo enega?
D3m0r4l1z3d ::
Heheh, zdaj bo 6700k že passe, vreden le še 150eur, nov. Nice, AMD, thank you for the music.
Kupim I7-4790k za 100€, če se želi kdo znebit tega antičnega pleha.
Moram dat oglas.
Moram dat oglas.
AapocalypseE ::
Torej, R5 1300 naviješ na clocke 7700K in sta podobno hitra. Edino, da 1300 stane 175$, 7700K pa 329$.
Za ceno 7700K se bo dobil 1700, ki je na nivoju 6900K.
- spremenil: AapocalypseE ()
AapocalypseE je izjavil:
Verjetno se še matrat ne bo treba, AMD se bo kar sam "navil"....zgleda da se začenja nova doba, doba "po Intelu"...
Po moje bo folk pobesnel (tisti ki so pred kratkim kupli kaj od Intela), ko bo moral intel spustit cene za 50%, poleg tega, zgleda da bo še zadaj, poleg tega, so Intelovi proci naenkrat postali požrešni in tehnološko zaostali.
Tisti pa ki so počakali na Zen, zgleda da bojo zadeli terno.
SuperVeloce ::
kar naj folk besni, bodo vsaj malo občutili, kaj je to free economy. Predolgo je cene določeval proizvajalec in ne trg... Kaj je šele moralo delati AMD fanom, ko so kupovali dual-core ze lepe denarce, potem pa je intel uletel s core 2 arhitekturo za pol cene (enako za kakšne kupce P4 EE).
Če rabiš, kupiš. Če ne, čakaš... in se lahko načakaš.
- spremenil: SuperVeloce ()
AapocalypseE ::
R3 1100 129$ = 7600K 242$
R5 1300 175$ = 7700K 339$
R5 1500 229$ = 6800K 434$
R7 1700 319$ = 6900K 1089$
D3m0r4l1z3d ::
Xfr je pa še za proizvajalce hladilnih sistemov, ohišij,... za pritegniti. Hat trick.
Mogoče, čez pol leta po izidu, ravno za dolge deževne jesenske popoldneve
AapocalypseE ::
Če primerjam dolar z našimi SLO cenami je nekako tako:
7600K 242$ - 280€
7700K 339$ - 410€
6800K 434$ - 500€
6900K 1089$ - 1200€
Me zanima kakšne bojo dejanske cene ryzena.
7600K 242$ - 280€
7700K 339$ - 410€
6800K 434$ - 500€
6900K 1089$ - 1200€
IMO ste malo preveč optimistični glede navijanja. Če bi se ZEN navijal na 4,5-5Ghz, potem ne bi vsi po vrsti imeli osnovnih frekvenc med 3 in 3,6Ghz.. Pomoje bo ~4Ghz kar zgornja meja za večino teh cpujev, mogoče z izjemo tistih najdražjih (1800x bi naj bili hand picked primerki).
edit: Še malo heca
Prodajam ga zaradi neuporabe in nakupa slabšega.
edit: Še malo heca
- spremenil: DarwiN ()
AapocalypseE ::
Lepo se sliši, da bi se navijali 4 - 4.5GHz
Mi je dovolj, če bo tak performance.
Samo cena še mora bit podobna tej, ki jo zdaj navajajo.
R3 1100 129$ - 180€
R5 1300 175$ - 230€
R5 1500 229$ - 280€
R7 1700 319$ - 370€
R3 1100 129$ - 180€
R5 1300 175$ - 230€
R5 1500 229$ - 280€
R7 1700 319$ - 370€
ziga1990 ::
R3 1100 129$ - 180EUR
R5 1300 175$ - 230EUR
R5 1500 229$ - 280EUR
R7 1700 319$ - 370EUR
Če so leaki resnični naj bi se ES Ryzen navijal na 4.3-4.5Ghz z zračnim hlajenjem na vseh jedrih.
Za cene je pa tako, da za 1700,1700x in 1800x so trenutne cene kar točne zaradi veliko leakov cen in se je dobila neka osnova a za druge Ryzene cena še ni čisto realna
- spremenilo: ziga1990 ()
Hydros ::
edit: Še malo heca
Procesor je stabilen in brez napake delujoč navit na 4700 ghz, hlajen z vodnim hladilnikom.
Wrop ::
edit: Še malo heca
Precej drag obtežilnik za papir.
m0LN4r ::
Zgleda se bo nam i5/123xvy/i7 lastnikom splacalo se eno leto pocakat na intelov tock tock.
Intel ze polira svoje 2x"kaby" jedra.
https://www.youtube.com/user/m0LN4r
- spremenil: m0LN4r ()
l.2019 pride vun Zen+ na 7nm, lah pol počakajo še na Zen+.
ZEN - ZEN+ bo kot Phenom - FX
Verjetno je na netu kakšna študija o tem, pa bi prosil link, ali je to zraslo na tvojem vrtu??
Jasno da takega redizajna, kot je bil Zen ne delaš pogosto in bodo iteracije Zen arhitekture 5-10 let.
Hydros ::
problem je da bo intel do 2019 releasal 2-3 nove generacije in če bojo zen samo prestavl na 7nm in ne bojo spremenil arhitekture ter povečal IPC bo Intel spet na vrhu ker bodo zagotovo povečal IPC oziroma dodal kako jedro ali dve
Iteracija arhitekture JE povečevanje IPCja, samo pač enako kot Intel v majhnih procentih. Intel itak povečuje zgolj 2-5% na iteracijo in procent pada in pada in limitira proti nič.
Za take velike skoke koz je AMDjev Zen pač rabiš redizajn iz praktično nule, oziroma takih skokov pri siliciju več ne bo.
Ima velik vrt veš.
|HP EliteBook|R5 6650U|
D3m0r4l1z3d ::
Vrt že, a od kje 7nm leta 2019?
Mogoče vsaj še eden, sicer skok bo le iz tehnologije iz 2011, glede na Intel bo lovljenje repa..
_koki_ ::
Upam, da bo AMD ZEN+ s prehodom iz 14nm -> 7nm izdal 16C/32T procesorje za mase, kar bi bil verjetno logičen korak pri "pol" manjšem proizvodnem procesu!
Ne vem, prehod iz 14nm na 7nm bo zanmarljivo ali sploh ne pocenil tranzistorje, torej 16 core zadeva bo koštala za izdelavo enako kot danes samo malo manj elektrike bo ponucala.
Predator X ::
Lahko že prednaročite sestavljen Ryzen računalnik (klikni Konfiguireren in skrolaj navzdol).. Zanimive so predvsem cene Ryzenov v evrih (treba upoštevat, da so napihnjene za ~10-20%, kot običajno velja za te nemške strani, ki sestavljajo konfige):
ziga1990 ::
Fino torej bo na mindfactory 1700X stal okoli 450€.
Mislim da je 1700X boljši nakup kot pa 1800X
Predator X ::
ziga1990 ::
Predator X je izjavil:
upam da bo res 420.
i7 7700K bo tud droppal pod 250EUR al pa še nižje in tud i5 7600K pod 170-180EUR.
Niti ne ker vprašanje je koliko bojo Ryzeni dobri v igrah
