Ukrajina Part II
Ukrajina Part II
Lonsarg je izjavil:
Glede na dogaja je v Mariupol se vidi zakaj je nasilno zavzetje mesta kot je Kijev popolna utopija (ne samo za Rusijo, pac nasploh).
V modernih vojnah se vecja mesta pravzame zgolj tko da se pridobi vsaj pol prebivalcev na svojo stran (kar so recimo Americani dokaj pogosto uspevali v svojih okupacijah). Ce je 90% prebivalstva ostro proti pac ne gre.
A zato so Mosul zravnali z zemljo, ker je bilo manjše mestece s samo 1,5 mio. prebivalcev?
Hitch marca 2005
Christopher Hitchens warns about Vladimir Putin
Fritz je izjavil:
Lonsarg je izjavil:
Si prebral sploh kaj je napisal!
koyotee ::
Omejeno rusofilsko razmišljanje, mu oprostimo.
Rear DVD collector!
JTD power!
cias je izjavil:
What happens to weapons sent to Ukraine? The US doesn't really know
Lepo da so Ameri tako radodarni še v času rekordne inflacije.
Izvirni članek je tukaj:
https://edition.cnn.com/2022/04/19/poli...
Bolj kot to kam gre vso to orožje, je pomembna naslednja trditev:
Because the US military is not on the ground, the US and NATO are heavily reliant on information provided by Ukraine's government. Privately, officials recognize that Ukraine has an incentive to give only information that will bolster their case for more aid, more arms and more diplomatic assistance.
"It's a war -- everything they do and say publicly is designed to help them win the war. Every public statement is an information operation, every interview, every Zelensky appearance broadcast is an information operation," said another source familiar with western intelligence. "It doesn't mean they're wrong to do it in any way."
For months, US and western officials have offered detailed accounts about what the West knows about the status of Russian forces inside Ukraine: how many casualties they've taken, their remaining combat power, their weapons stocks, what kinds of munitions they are using and where.
But when it comes to Ukrainian forces, officials acknowledge that the West -- including the US -- has some information gaps.
Torej ZDA odkrito priznavajo, da je vse kar pride iz Ukrajine info-ops ali po domače propaganda. Koliko je noter primešane resnice je bolj vprašanje. Osebno do ene mere verjamem videoposnetkom, vse ostalo pa je pod vprašanjem.
Kar se tiče dogajanja na bojišču, nič posebej novega. Boji v Mariupolu še vedno trajajo, verjetno ne bodo več dolgo. V Donbasu je na frontnih črtah precej živo, ruska artilerija je zelo aktivna, njihove enote pa poskušajo prebiti obrambo na več smereh. Za razliko od začetka vojne so sedaj bolj počasni in sistematični, zato imajo manj izgub.
Drugače pa je danes sodišče v VB odločilo, da se Assangea, ki je razkrival vojne zločine ZDA, izroči tej isti državi. Fino, anede.
Fritz je izjavil:
Lonsarg je izjavil:
Sem. Zakaj so potem Mosul zravnali s tlemi? Vsako, še tako veliko mesto lahko zavzameš, če imaš dovolj sil za napad in si ga pripravljen uničiti. Kako pa misliš, da so zasedli Berlin leta 1945. Ob podpori Nemcev?
  • spremenilo: Fritz ()
Fritz je izjavil:
cias je izjavil:
Pozabljaš Čehe, Slovake, Poljake, Fince, Baltik, ki sigurno bolj poznajo Ruse in siuacijo kot USA in če oni rečejo, da je panika, potem sigurno je in USA in NATO stojita zadaj! Kaj si naj en Moldavec misli, ko država prepove "navijanje" in kazanje podpore Rusiji, tako da prepove javno kazanje črke Z in V, ter svetnika, da ne bi prišlo do napetosti v državi in ti Rusi rečejo, da se pazi, ker te lahko zravnajo z zemljo!?
Fritz je izjavil:
cias je izjavil:
Fritz je izjavil:
Lonsarg je izjavil:
Kaj ni tam ISIS zasedel mesta in teroriziral ljudi, ter si naredil svojo državo? Kaj niso klicali tam na pomoč? Ali je to spet zahodna propaganda? Ne vem razjasni!
PrimoZ_ ::
Fritz je izjavil:
Lonsarg je izjavil:
O glej mojstra. A si še zaposlen v slo vojski?
Zravnali so mesto z 1,5 mio. prebivalci, katerega so napadali in skušali zavzeti ter potem zavzeli. To je odgovor Lonsargu, ki je trdil, da se Kijeva ne bi dalo zavzeti in da ZDA to počnejo drugače. Če bi Rusi tja privlekli dovolj sil in bi ga bili pripravljeni ob odporu tudi podreti, bi ga lahko zavzeli. Vsako mesto se da zavzeti, tako ali drugače. Z dovolj ljudi in resursov je marsikaj možno.
8 minut, trigger warning za amerofobe.
Ukraine’s Damage to China | Peter Zeihan
PrimoZ_ ::
Fritz je izjavil:
sir_mha ::
Od navadnih smrtnikov ima v tej vojni redkokateri realno predstavo o žrtvah. Prvič, nedvomno je veliko žrtev, drugič, vseeno so toliko disciplinirane vojske, da močno otežujejo objave posnetkov. Ukrajinci imajo pa seveda več žrtev med civili, to je logično.
Fritz: Kijev lahko pade le z jedrskim orožjem. Zahod ne bo dovolil padca Kijeva čeprav rusi tja navlečejo vse kar imajo. Na konvencialni način nikoli!
  • spremenil: endelin ()
Fritz je izjavil:
Ok to verjamem ja, ampak meni še sedaj nekaj ni jasno, sem delal v Kijevu, z vsakim drugim, predvsem pa tam na ulicah umetniki, so bili vsi skoraj Rusi, v teh vzhodnih mestih, pa naj bi bilo še veliko več Rusov, nekje do 13 miljonov rusko govorečih ljudi po vsej Ukrajini in to sedaj Putler čisti z altiljerijo? Američane še lahko razumem, da tolčejo Arabce, to je pa kot, da bi USA napadla Veliko Britanijo. Se ne more niti primerjat z Srbijo, Bosno, Albanijo, to so vse vsaj druga vera.
sir_mha je izjavil:
Po mojem imajo Ukrajinci bistveno več žrtev med vojaki kot med civilisti. Tisto mletje artilerije v Donbasu terja svoj davek. Je pa res, da o Ukrajinskih izgubah ni veliko podatkov.
Ukraine claims Russian FSB arrested a Pro-Russian separatist leader in Donbas in the latest fallout over its failed invasion
Nkvd začel cistit al kaj?
Fritz je izjavil:
Če boš svoj sestavek še enkrat prebral, boš v njem našel precej rasizma, nekako v tem slogu:
https://twitter.com/inanoveritas/status...
sir_mha ::
Fritz je izjavil:
sir_mha je izjavil:
Artiljerija res dela veliko žrtev. O tem krožijo tudi posnetki, redno na Telegramu. Rusi na začetku spopadov niso veliko objavljali posnetkov, ampak sedaj se pa bolj trudijo kot Ukrajinci. Ne da ti ne bi želeli dvigovat oz. zbijat morale, ampak se je dal razbrat, da ne želijo izdajat kakršnihkoli informacij, ki bi jih Rusi lahko uporabili. Redno pokažejo le civilne žrtve, ki niso sporne v smislu, da bi razkrile kakšne vojaške informacije.
Število žrtev med ukrajinskimi vojaki je zagotovo enormno.
PrimoZ_ ::
Russia - 3011, of which: destroyed: 1593, damaged: 47, abandoned: 243, captured: 1128
Tanks (523, of which destroyed: 264, damaged: 10, abandoned: 39, captured: 210)
Lepo, lepo :)
Zanimiv članek za razumevanje mednarodnih odnosov in 'rules based international order' o katerem govorijo ZDA.
https://www.msnbc.com/opinion/msnbc-opi...
But as effective as Zelenskyy has been in drumming up Western support, Ukraine's message has been far less compelling to audiences in the Global South, where many countries have declined to join Western campaigns to sanction Russia's economy and isolate it diplomatically. This was vividly clear at the Doha Forum last month in Qatar, where Zelenskyy and Ukrainian Deputy Foreign Minister Emine Dzhaparova were given a big platform. A powerful communicator in her own right, Dzhaparova -- a Muslim Tatar from Crimea -- played on themes favored by Western leaders: This war is ultimately not about Ukraine but about the survival of the "international rules-based order." President Joe Biden and European leaders have repeatedly framed the conflict in these terms, as well.
But therein lies the disconnect with much of the Global South. In conversations with diplomats and analysts from across Africa, Asia, the Middle East and Latin America, it was evident to me that these countries largely sympathize with the plight of the Ukrainian people and view Russia as the aggressor. But Western demands that they make costly sacrifices by cutting off economic ties with Russia to uphold a "rules-based order" have begotten an allergic reaction. That order hasn't been rules-based; instead, it has allowed the U.S. to violate international law with impunity. The West's messaging on Ukraine has taken its tone-deafness to a whole new level, and it is unlikely to win over the support of countries that have often experienced the worse sides of the international order.
Fritz je izjavil:
Fritz je izjavil:
Ni rasizma, samo razmišljanje, na začetku sem še mogoče minimalno verjel Putlerju, da hoče zaščititi svoje ljudi in mesta v katerih živijo, sedaj je več kot očitno jasno, da si hoče prilastit samo zemljo in uničit "sosedo", ter si napumpat ego, ki mu ga primanjkuje zaradi malega tiča, pa če pocrka še polovica Rusov v Rusiji!
Fritz je izjavil:
https://twitter.com/War_Mapper
Ne vem a za tebe pravijo, da si v vojski? Pa ti kot vojak res verjameš, da bodo lahko Rusi držali ta pridobljena ozemlja v prihodnje? Ukrajinci imajo veliko propagando, da dobijo čimveč orožja, toliko kot ga obljubljajo in koliko gre še tako brez javnosti not, verjetno to ne rabijo samo za obrambo, ampak za kako "Olujo" v prihodnje?
Anney ::
https://siol.net/novice/svet/rusija-nob...
Tule se čuti totalna nemoč rusije.
Anney je izjavil:
Tudi tako se lahko gremo, važno je da v Ukrajino pridejo PzH 2000. In še par Excaliburjev, prosim lepo.
Germany will provide Ukraine with ammunition and training for heavy artillery as Chancellor Olaf Scholz comes under pressure to give more support to the effort to fend off Russian forces.
The training and ammunition are for the PzH 2000, a self-propelled, rapid-fire artillery system, which the Netherlands is sending to Ukraine, according to a senior government official.
The training could be provided in Poland or Germany, but not in Ukraine because of ongoing attacks from Russia, said the official, who asked not to be identified because talks between NATO allies and Ukraine are confidential.
PrimoZ_ ::
Anney je izjavil:
Imajo tanke in tope.
Pol pa kompenzirajo z letečimi dildoti :)
Anney je izjavil:
Zdaj mora kazati moč, da nebi Finska in Švedska šle v Nato. Ampak na to lahko Putin kr pozabi, tele neumnosti Rusov bodo Finci in Švedi izkoristili in vstopili v Nato.
X670F | 7700X | 2x16Gb | 6000Mhz/CL30 | RTX3090FTW3 | HP X27i | Phanteks NV7|
TezkoDihanje ::
8-O Kaj zdaj to gledamo?
Wher this SAM of the S-200 going?Russia, Tver.
https://twitter.com/Milkydru_HF/status/...
There is also "Katyusha" which was used at WW2.
PrimoZ_ ::
https://mobile.twitter.com/micahflee/st...
I don't think people fully appreciate just how much, after invading Ukraine, people are hacking Russia. There are multiple hacks a week and it's only increasing. For first time in internet history Russia is fair game for cyber attacks, and this is what it looks like.
TezkoDihanje je izjavil:
Naj bi šli na parado, kolikor sem bral! Do 9. maja morajo priti v Moskvo, še prej pa jih morajo sprati in pobristi, ter namazati z lakom!
TezkoDihanje ::
Pa saj Tver je čisto zraven Moskve.
Bo bbbbbbb razložil kako se to prevaža :D
l0g1t3ch ::
Parada 9. maja bo letos prava zgodovinska poslastica.
Kar me spomni na...
Russia - 3020, of which: destroyed: 1595, damaged: 47, abandoned: 243, captured: 1135
Dobr jih klestijo :)
  • spremenilo: l0g1t3ch ()
Saj tej veš, da je lepo, če si malo prej tam, kot pa da zamujaš! :D
korenje3 ::
scythe je izjavil:
Anney je izjavil:
Sarmat 2 je v izdelavi že več kot 10 let. Planiran test je pa tudi več kot pol leta.
Aston_11 ::
l0g1t3ch je izjavil:
Parada ponosa z vladrjemovc na čelu!
sir_mha je izjavil:
Fritz je izjavil:
sir_mha je izjavil:
Artilerija dela veliko žrtev predvsem, če oprema in vojaki niso vkopani. Potem ena granata povzroči šrapnele 50-100m okoli. Če pa so vojaki in oprema vkopani, sploh če ima rov grudobran - t.j. naprej zmetano zemljo v v vrečah ali zbito med deskami, pa artilerijska granata praktično ne more prileteti v rov.
Če je rov pravilno skopan - na cik cak, z premiki - četudi udari v rov - potem premik zadrži udar.
Nenehno obstreljevanje sicer povzroči tudi nevrološke efekte - ki so jih prvič zaznali v 1. sv.v. - kjer so na začetku mislili, da vojaki simulirajo, ko se tresejo zaradi bližnjega udara granate. No, danes se tudi ve, da če si daš glušnike na čelado (kar dvomim sicer, da majo to tam), potem se efekt tresenja praktično odpravi.
Ukrajinci so se ob frontni črti v Donbasu zelo vkopali in vojaki in oprema in strelivo. Tako da dvomim, da bodo Rusi na ta način anulirali frontno črto Ukrajincev.
Voss je izjavil:
dexterboy je izjavil:
Glede na to, kako si vsi ŽELITE nadaljevanje vojne, ne bodite presenečeni, če nekega dne začnejo rasti gobe na obzorju...
Vojno si želijo zgolj in samo Rusi. Prav pride še ZDA seveda, ker so itak daleč od tega ognja.
Seveda zagovarjamo upor Ukrajincev. Kaj pa naj? Naj podpiramo, da Rusija enostavno ukrade ozemlje Ukrajine? Kje se ustavi? V Bukarešti? Na Dunaju? V Parizu?
Ukrade? Ukrajina je de-facto ruska kolonija. Lahko se soočimo z realnostjo in jo naredimo nevtralno, ali pa alternatovno ruse prisilimo, da jo porušijo do tal. To, da jo bomo ukradli rusom, je pač povsem nesprejemljivo - in o tem ni nikoli bilo dvoma.
Kje se ustavi? Očitno precej na začetku Ukrajine. Pa če za trenutek odmislimo NATO - se ti zdi realno, da pridejo do Dunaja oziroma Pariza? Ali zgolj ponavljaš pravljice, s katerimi te gospodar straši in sili v (povsem nepotrebno) militarizacijo?
What could possibly go wrong?
TezkoDihanje ::
Poldi112 je izjavil:
Here we go again...
Lonsarg je izjavil:
Traparija. Američani so "uspevali", ker imajo totalno vojaško nadvlado, ter ker masovno podkupujejo lokalce. Še v Afganistanu so plačevali talibanom za varen prehod, medtem ko so desetletja sistematično lagali o napredku.
Here we go again...
Sam vem, da je resnica za ovce težko prebavljica, ampak je pomembna.
  • spremenil: Poldi112 ()
Motion ::
Voss je izjavil:
K sreči ukrajince boli kurac kaj si ti in podona manjšina misli. Maš srečo da živiš v slovenji in ne v jugi 60 let nazaj. Bi že končal kje v rovu.
  • spremenilo: Motion ()
l0g1t3ch ::
Voss je izjavil:
Ti si zblojen.
Pacient gobav.
Ruska kolonija, japajade.
Rusi si bodo polomili zobe tam, da se še 30 let ne bodo sestavili.
A misliš da je vredno tega?
TezkoDihanje ::
Ovca ruska zaudarja ti iz ust.
Motion je izjavil:
No, roko na srce se tudi sam ne sekiram sila. Malo se mi smilijo, da so se pustili tako na suho nategniti, ampak hej, če so hoteli demokracijo in izvolili komika, pa naj sedaj uživajo v tragikomediji svobode.
Če bodo dovolj patriotski, jim z obilno zahodno pomočjo uspe izgubiti celo državo.
K sreči? Meni se zdi bolj k žalosti.
Za ruse je vsekakor vredno - kot že ničkolikokrat rečeno - na ključni varnostni interes pač ne moreš postaviti cene.
Rusi bodo z okupacijo preprečili širitev NATO. Edino odprto vprašanje ostaja, ali:
- bo zahod dovolil Ukrajini, da prizna nevtralnost "osvobojenih" regij in s tem obdrži avtonomijo
- ali pa bomo ruse prisilili, da iz Ukrajine naredijo S. Korejo, v zameno, da jih shiramo
Če se Assange ne bi šel privat vendete proti ZDA, bi bili Wikileaks lahko podobni DDoSecrets.
https://twitter.com/micahflee/status/15...
https://threadreaderapp.com/thread/1516...
Distributed Denial of Secrets has been archiving these dumps and making them torrents. DDoSecrets has been around for a few years but made a big splash in 2020, during BLM protests by publishing hacked data on hundreds of US local/federal police sites
https://theintercept.com/2020/08/17/blu...
Twitter permanently banned the @DDoSecrets account then, and also took the extraordinary step of banning links to ddosecrets dot com itself. Go ahead and try tweeting that URL, it won't work.
Anyway, DDoSecrets has 7 Russian datasets from March and another 20 from April (so far)
817gb from Roskomnadzor, agency that monitors and censors mass media (!)
79gb from Transneft, world's largest oil pipline company, state-controlled
15gb from Rosatom, the state nuclear energy agency and major exported of uranium
2.4gb from RostProekt, a construction company
110gb from MashOil, manufacturer for drilling, mining, and fracking industries
22gb from the Central Bank of Russia
5.9gb from Thoriz Corp, investment firm owned by an oligarch billionaire
52gb from Marathon Group, another investment first owned by another oligarch
15gb from the Russian Orthodox Church's charitable wing
65gb from Central Legal Services, mostly emails
483gb from Mosekspertiza, state-owned firm
786gb from VGTRK, state-owned broadcaster that runs dozens of TV/radio stations (!)
244gb from Petrofort
145gb from Aerogas, oil and gas industry
35gb from Forest, logging firm
116gb from Tver Governor's office, appointed by Putin
150gb from the city of Blagoveshchensk
Whew... there's still a lot more. It's going to take months and years to look through all of this data. It's hard to picture how this will affect Russia going forward. It's massive.
446gb from the Ministry of Culture (!)
221gb from the education department of Strezhevoy
440gb from Technotec, oil and gas industry
726gb from Gazprom, oil and gas manufacturer
400gb from Continent Express, travel agency
222gb from Gazregion, construction company that does gas pipelines (hacked by 3 different hacktivists at the same time lol)
107gb from Neocom Geoservice, oil, gas, and drilling engineering
1.2gb from Synesis Surveillance System
9.5gb from General Dept of Troops and Civil Construction (works with ministry of defense)
160gb from Tendertech, financial and banking processing firm
Those last four datasets: those were from TODAY. I know there are several more in the DDoSecrets backlog as well. It's insane.
This isn't all that DDoSecrets does at all. It's just been particularly slammed by hacktivism against Russia since the illegal invasion of Ukraine. Here's a great overview from @illegaldaydream, a member of the collective
https://backdrifting.net/post/057_what_...
After January 6, DDoSecrets published 5gb of hacked data from the Oath Keeper militia and shared it privately with journalists, which triggered dozens of investigations around the country
https://www.npr.org/2021/11/05/10520980...
During the far right anti-vax Canadian "Freedom Convoy", a hacktivist hacked the far right fundraising site GiveSendGo and leaked all their data to DDoSecrets, which shared with journalists. This also triggered dozens of news articles
https://theintercept.com/2022/02/17/fre...
Even since Russia's war against Ukraine started, DDoSecrets published 4TB of data from "Mining Secrets", a major collaboration of 65 journalists and 20 newsrooms
https://forbiddenstories.org/case/minin...
Anyway, I've been working on downloading as much of the hacked Russian data as I can and making it searchable for Russian-speaking journalists. If you have the time and tech skills, you should too! The data is available to everyone
And if you want to support DDoSecrets, go to ddosecrets dot com and click "Donate" on the left.
The collective works on a shoestring budget, doesn't get paid, and spends very little time fundraising because they're too busy with everyone hacking Russia
Stikalo ::
Poldi112
a si kaj moker go ga vidiš a?
Hočeš reči, da je prav, da ga leta vlačimo po zaporih za izmišljenimi izgovori, ker si je drznil objaviti umazano perilo izbrane lukte kapitala?
Zanimiv pogled na novinarsko svobodo.
Ejga, Finska in zelo verjetno Švedska gresta poleti v NATO. Ko se nagoni Rusijo pa še Ukrajina. Winning.
791 / 859
