OnePlus One
OnePlus One
Mat3v7 ::
Dobil invajt, dobi ga kdor prvi piše na ZS.
plizzzzzz ::
upss zgleda jim je prodaja padla ko tolk invajte talajo... :)
Opkow ::
Vendar izgleda, da smo vsi dobili samo po enega in se to s 24-urnim rokom.
Sem mislil, da bo trajal vsaj par dni.
kratos ::
https://account.oneplus.net/invite/clai...
Namesto obeh ? je ista črka.
Opkow ::
Kot kaze, je tukaj v obtoku prevec prostih invitov.
Ker imam se vedno viska. :)
mat3 ::
Koliko časa imajo veljavnost ti inviti ? Mam namen nakupovat...
AMD Ryzen 7 3700X, 32 GB DDR4-3600 MHz G.Skill TridentZ Neo
500GB Samsung Evo Plus, Crucial P2 500GB, GTX 1660 Super, 4x 3TB HDD
http://www.bozic17.blogspot.com
Opkow ::
Pri meni je bilo 24 ur.
kratos ::
Mojega ni več.
you!!! ::
Ma kdo mogoče še kakšen invite?
hurter11 ::
You have a new invite!
Dear fanboy/girl,
Whoop whoop! You have just received an invite to purchase the OnePlus One.
To use this invite, please follow this link to claim it as yours (you have less than 24h to do so): https://account.oneplus.net/invite/clai.... If you haven't yet registered your account, no problem. Just follow this link: https://account.oneplus.net/sign-up
Remember that this invite can only be used for orders shipping to Austria, Belgium, Canada, Denmark, Finland, France, Germany, Hong Kong, Italy, Netherlands, Portugal, Spain, Sweden, Taiwan, United Kingdom, and United States.
The invite will expire 24 hours from when we sent this email, not necessarily when you received it, please claim it as soon as possible as expired invites are not re-activated.
Enjoy!
marjetica007 ::
Še kakšen invajt viška? Hvala.
AlesV ::
Zdravo.
Kot marsikdo tukaj tudi sam iščem invite za 64G. Če ima kdo kakšnega, se priporočam. Hvala.
Klemen97 ::
Super , to je pa to ko negledam maila usak dan-.- in zej se lahka j..
mat3 ::
Čez 7 dni naj bi šli na pre-order sistem...
Opkow ::
paramedic86 ::
Tako, še moji vtisi po enotedenski uporabi.
Na telefon sem takoj napopal Orzly tempered glass in Diztronic case. Po 5 minutah, ko sem prižgal telefon mi je updejtalo na 38R verzijo. Je zelo hiter in odziven, prej sem imel galaxy s2, tako da razlika je očitna. Glede kamere sem navdušen, kar se tiče dnevnih slik, nočne ali pa indoors pa ne tako zelo. Kamera se mi je parkrat tudi sesula, tako da to mi ni všeč. Včeraj sem iz Dalvik prešaltal na ART, neke posebne razlike ne opazim, tako pri bateriji kot pri odzivnosti ne. Če že, se mi zdi da mi na ART Facebook počasneje odpira in GTA San Andreas noče zagnati, medtem ko na Dalviku je to boljše delalo.
Druga stvar, ki me je zmalo zmotila je to, da ima večina ljudi na 38R zelo dolg SOT, tam okoli 6 ur. Jaz osebno sem danes ob enih zjutraj izklopil telefon, zjutraj ob sedmih, ko sem ga začel uporabljat je bil na 100%, trenutno, torej ob 11:34 pa je na 80% s 54min in 30 sec SOT. Sem vključujem 15 min pogovorov, 10 min burskanja po spletu, nič iger, nekaj slik in vsesplošno brskanje po telefonu. Na koncu dneva imam ponavadi še 40% baterije, sam SOT pa je na okoli 2-3 ure. Je pa res, da ko sem naredil update, sem samo rebootal telefon, to je pa to.
Pogovori so jasni, slike nasplošno dela zelo lepe, ponoči je pač druga zgodba. Imam pa na 4g omrežje in mi nikoli ne poveže na 4g, samo h+.
kako je kaj pri ostalih s SOT in pri kakšni uporabi? Ima še kdo vklopljen ART namesto Dalvik?
zanko123 ::
Mam eno vprasanje, 1+1 sem narocu v ameriko in z podjetjem amforward preusmeru posilko v evropo. Zdej me zanima koliko bo carine pa davka ... glede us polnilca bom pa ze zrihtu :)
Thunder wave ::
22% davka na vrednost telefona in poštnino. Carine pa mislim, da ni.
PINki ::
Pyromanic ::
zanko123 je izjavil:
Zakaj pa nisi uporabu cheaper & more, kjer bi poslal u nemčijo in ne bi bilo treba plačat davka.
Je bilo že velikrat rečen o tej firmi, v tem topicu.
Uni k pa prosjo za invite, pa mal pjte na domačo stran od one plus, ker bojo imel v ponedeljek za 1 uro odprt preorder.
tireleap ::
Ali je že kdo uporabil http://www.cheaperandmore.com/ za nakup oneplus one
Matevz96 ::
tireleap je izjavil:
Človeška lenoba ne pozna meja Cheaper&more je bila v tej temi omenjena že n-krat, nazadnje v postu direktno pred tvojim!
tireleap ::
Sem opazil,
Ali denar plačaš trgovini ali cheaper & more?
kratos ::
Najprej trgovini potem cheaper&more, preberi malo, če prebereš 5 strani boš vse izvedel.
A lahko eden naredi test hitrosti SD kartice?
kratos ::
Opo nima sd kartice...
zanko123 ::
Hvala za info :) invate sem dobil oz. Opacil zadnji moment in nisem spodaj na uradni strani opacil da se da spremeniti jezik strani zato sem mev kot moznosti shippinga zgol canado in usa :/ zato sm pol na hitr neki zmuckov :) a telefoni za usa in eu trg se kaj razlikujeta?
kratos ::
Telefon ne, vendar boš dobil usa polnilec.
kratos je izjavil:
Interni flash je definiran kot SD kartica ...
paramedic86 ::
PINki je izjavil:
Uporabljam dalvik
https://forums.oneplus.net/threads/test...
Ja, sem ravno danes bral tole temo....bom probal še kakšen dan ali 2 ART da vidim kako bo, trenutno ga probam spraznit.
- 15h40min od zadnjega polnjenja
- SOT 2h40min
- gaming 46min
- pogovori 25min
- nekaj sms-ov
- nekaj slik
- 40 min video playback
- idle: 13h
- ostalo (brskanje po netu itd)
- svetlost na cca 45%
Stanje baterije: 38%
damjan1980 ::
Lepo prosim ce ima kdo kaksen invite viska, bi bil zelo hvalezen
sheldon ::
Če je možno dobiti kakšen invite bi bil zelo vesel :)
djready ::
Baje bo 27 oktobra za eno uro se dalo naročiti telefon brez invita.
http://www.gsmarena.com/oneplus_one_pre...
Asus M5A97 R2.0, Fx 6300 4.4Ghz, XFX 280x OC BE, 8GB Ram, XFX 550w, Win7
damjan1980 ::
ja, na preorder, invajti pa bodo se vedno veljali
http://oneplus.net/blog/2014/10/get-rea...
Nesta ::
Trenutno sem brez telefona. Ima kdo kaksen invite. Oz kako bi ga lahko dobil? :)
hvalaa
djready ::
damjan1980 je izjavil:
Ne, Naročiš ga brez invite in čakaš v vrsti, če pa dobiš invite pa ti pošljejo telefon takoj.
you'll be able to pre-order its first smartphone, no invite needed.
If you do pre-order the OnePlus One and then receive an invite, you'll have your phone shipped immediately. Otherwise, you'll have to wait in the pre-order line
  • spremenil: djready ()
zanko123 ::
Mam eno vprašanje.
Ker se želim izogniti prevelikem davku sem podjetku ki mi bo poslal telefon, prosil da pogledajo in skinarejo če so v paketu kakšni računi itd. dobil sem odgovor da v paketku ni nobenega računa. Zdej me zanima če ste uni k že mate OPO, dobil račun zdravn?
kratos ::
Cariniki niso neumni, tudi če nebo računa imajo internet in ga znajo uporabljat, če ti bodo paket odprli in videli kaj je not boš plačal davek + carinjenje. Za račun bodo pa že tebi rekli prek maila če ga res ni not, dokler jim ga ne izstaviš pač ne dobiš telefona.
Runnagain ::
Sam nisem zraven dobil nobenega računa.
paramedic86 ::
Jst tut nisem dobil računa....
zanko123 ::
kratos je izjavil:
Glede tega kok so neumni to prepust men :D
mal mi je brezveze plačat tok velk davk ...
Kokr js vem se davek+carina določi na podlagi potrdila (račun) tko da če je na računu manjša vsota nimajo pravne podlage da mi dajo davek+ carino na podatke na internetu.
  • spremenilo: zanko123 ()
first_line ::
kratos je izjavil:
Ja napiš jim, da si dal 20,99€, ker je itak ponaredek in ti ne bo treba plačati DDV pa stroškov.
k3k3tz ::
Predn kvasiš neumnosti... Uradni list
Pa ne misli, da na carini ne znajo pogledat na oneplus.net in ugotovit, da si si zaslužu še kakšno globo za prirejanje podatkov in listin.
sam pravim
XeRoX1987 ::
Prosim ce ima kdo od vas kaksen invite viska, bi bil fuullll hvalezen =)
zanko123 ::
Se strinjam z odgovori.
cena bo okoli 100€
ne mislm tok pretiravat xD
Stvar je v tem da če js dobim OPO ceneje v tujini mi ne morejo dati davka na ceno telefona ki je v redni prodaji ...
kratos ::
Zato pa pošlješ račun trgovine ter računa paypala oziroma kjer si že telefon kupil in oni znajo preverit, niso ravno nesposobni. Sem dal že ogromno tega čez tako da imaš največje šanse da ne plačaš tako da paket "spregledajo" in negre čez postopek carinjenja (kar se večkrat zgodi pri manjših paketih).
Pač to kar boš plačal se reče davek na neumnost, če bi se prej pozanimal kako in kaj bi se temu elegantno izognil tako kot večina :) Pa brez zamere to ne leti nate saj še zdaleč nisi edini ki se je tako nategnil, imaš pa vsaj v dobrem eno šolo za drugič.
k3k3tz ::
Če si ga naročil preko C&M (iz oneplus.net), po izkušnjah tukajle, ne boš plačal nobenih dajatev. Z eBay-a ali Aliexpressa pa odvisno od sreče.
Ne, temu se reče DDV, ki ga je pač treba plačat za vse pošiljke, ki pridejo izven EU. Kako se temu "elegantno" izognit pa... prosim razloži.
kratos ::
Naročiš telefon iz nemške strani oz. bolj natančno odpošljejo ti iz Anglije, tako kot nas je večina naročilo.
  • spremenil: kratos ()
Yossarian ::
Prodam tovarniško zapakiranega. Cena po dogovoru.
BlueBerry ::
Tudi jaz bi lepo prosil za invite, če še kdo ima kakega.
andreja1962@gmail.com
Hvala.
14 / 34
Oneplus X (strani: 1 2 3 4 … 10 11 12 13 )
Oddelek: Mobilne tehnologije
638126599 (63584) cryptozaver
OnePlus Two (strani: 1 2 3 4 5 6 7 )
34685912 (54624) Yossarian
One Plus one
344542 (3238) Zaphod_B75
OnePlus One bo na voljo brez povabil (strani: 1 2 )
Oddelek: Novice / Android
5229371 (24226) kronik
Težave s prednaročili OnePlus One pomenijo ponovitev (strani: 1 2 )
6431523 (27890) Uporabnik
