Forum » Programiranje » [c#] izbris vsebin v vseh gradnikih
japol ::
Kako najlažje izbrišem vsebino v vseh gradnikih, ne glede na to ali se nahajajo na panelih, groupboxih,...?
japol ::
Trenutno imam rešeno tako:
Imam Meni.sc in v njem kodo:
ampak iščem način, da mi ne bo potrebno pisati za vsak panel, groupbox, itd.
public void Novo(Form1 f1)
foreach (Control c in f1.Controls) // le na formi
if (c is TextBox || c is ComboBox)
c.Text = "";
foreach (Control c in f1.groupBox1.Controls) // le v groupboxu1
c.Text = "";
foreach (Control c in f1.panel1.Controls) // le v panelu1
c.Text = "";
// itd..............
zenb ::
private void button1_Click(object sender, EventArgs e)
IEnumerable<Control> controlList = GetControls(this);
foreach (Control c in controlList)
c.Text = "";
public static IEnumerable<Control> GetControls(Control form)
//Sprehodimo se skozi controle
foreach (Control childControl in form.Controls)
{ //Če ima controla otroke, potem se prehodimo še skozi otroke
foreach (Control grandChild in GetControls(childControl))
yield return grandChild;
//vrnemo še kontrolo
yield return childControl;
EDIT: bolj šolski primer
List<Control> controlList = GetControls(this);
c.Text = "";
public static List<Control> GetControls(Control form)
List<Control> controlList = new List<Control>();
controlList.Add(grandChild);
controlList.Add(childControl);
return controlList;
To bi moralo delovati
- spremenil: zenb ()
| » | C#, TextBox in PopUp formaOddelek: Programiranje | 1420 (1314) | MarCar |
| » | C# textbox polnjenjeOddelek: Programiranje | 1941 (1806) | Mitja Bonča |
| » | C# ProgramOddelek: Programiranje | 3504 (2427) | Spura |
| » | razložitev nekaterij elementov v visual studio 05Oddelek: Programiranje | 2597 (2402) | darkolord |
| » | [VB express edition] problemOddelek: Programiranje | 1753 (1656) | frudi |
